This thread is privately moderated by chuck George, who may elect to delete unwanted replies.
Old Jan 26, 2010, 09:30 PM
chuck George is offline
Find More Posts by chuck George
Trader Rating: 15
USA, NH
Joined Sep 2004
Trader Rating: 15
Sold
FIY SU-47-Haoye SU-27 Twin-BAE Hawk 90mm EDF
Free Shipping ... PM Me...Prices are on RCG Only
NEW Fly It Yourself SU-47 Twin EDF Receiver Ready
$160.00 FREE SHIPPING CONUS
Specification:
ARF KIT Receiver Ready
Length: 1024mm /40.31"
Wingspan: 750mm / 29.52"
Flying Weight: 700g / 24 oz.
Power System: twin EDF55 with brushless motor
Battery: 2200mAh3s 15c
Servo: 9g Servo 3pics
Electronic Speed Controller: twin 18A ESC
Feature:
Forward swept wing configuration and canard layout
Auto inlet door
Steerble nose wheel and ailevator mix control
High efficient EDF system
Haoye SU-27 Twin 68mm Ducted Fans or Pusher
$80.00 FREE SHIPPING CONS
The SU-27 is designed as a high performance fighter with a fly-by-wire control system. Its high maneuverability makes the Su-27 one of the most imposing fighters ever built. The development of the Su-27 fighter plane was completed in the early 1980s, and the plane subsequently set more than 40 world records of altitude and take-off-speed.
You will need Two (2) ESC Speed controls and Two (2) EDF Motors or Pusher Setup
This is where you can Taylor the Power System for the Type of Flying
you want from Stock Setup to All Out Performances....It's all up to YOU.
The Included Twin Fans are Haoye 68mm Units ...Nice Ones...5 blade ducted fan unit.
Specifications:
Length: 900mm/35.4 In
Wing Span: 670mm/26.4 In
Wing Area: 12dm
Height: 320mm/12.6 In
Weight: 230g/ 8.11 (plane only)
AUW: 730g/ 25.7
ARF version:
Includes 2 @ Fan units without Motors!
5 blade ducted fan unit For use with Haoye SU-27 68 dia x 58mm (H)
Landing Gear
English Manual
This model can be flown with pusher power or ducted fan power system comes with both Prop or TWIN 68mm Fans...Really Good Fans...Not the Usual, Haoye Fans 68 4 Spoke/ 5 Blade Brush Ducted Fan HY003-00105-5B ***Nice Ones***.
The manual is based on instruction for pusher power system or ducted fan system. Comes with glue, pushrods and control horns.
This model can be flown with pusher power or ducted fan power system.
Package contents:
Assembly instructions in English, painted foam fuselage, foam wings, tail plane and fin, small items, linkage hardware pack
Including nylon control horns, Haoye EDF 2@ Fan 68mm and Landing Gear included.
Includes SU-27 Undercarriage non retractable 1 nose gear 2 main gear and 2 Haoye Ducted Fan 68mm W/O Motor -
Includes SU-27 Undercarriage non retractable (steerable)
Front Nose Wheel: L38W51H120mm, D368mm
back main gear: L40W25H100mm, D45/5018.5mm
Items not included:
- 4-8 Channel and above Remote Control
- Servos x3
- 4-8 Receiver
- Push Power System
- Brushless Motor 28-47-09C
- 11.1V Li-Po Battery
-Brushless Motor x2
-11.1V Li-Po Battery x2
Haoye BAE Hawk 90mm EDF
$85.00 FREE SHIPPING CONS
Product Information:
Red Arrows BAE Hawk painted version of the Hawk is the perfect EDF Jet for EDF first timers. Made out of foam, the plane comes mostly assembled. The red and white painted fuselage allows modeler a faster build and is scale like of the Red Arrows BAE Hawk. Suitable for EDF and push prop power.
This model can be flown with push power or pull power or ducted fan power system, can be upgraded.
The manual that comes along consists of instruction of push power system or ducted fan system only.
Pack contents:
Assembly instructions in English, white foam fuselage, foam wings, tail plane and fin, small items, linkage hardware pack including nylon control horns, Haoye EDF Fan 90mm and Landing Gear included.
Includes BAE Hawk Undercarriage non retractable 1 nose gear 2 main gear and 1 Haoye Ducted Fan 90mm W/O Motor - 89 6 Spoke/ 5 Brush Duct.
RC functions:
- Ailerons
- Elevator
- Rudder / Nose steering
- Throttle
Specifications:
Wing Span.....................: 960mm (37.8'')
Wing area......................: 16.9sq.dm
Weight (empty)..............: 350 grams
Length...........................: 1030mm (40.6'')
Items required (not included):
- 4-8 channel remote control
- Servos x 3pcs
- Speed Control 60A for Brushless Motor
- 4-8 Channel Receiver
- Push Power System:
- Outrunner Brushless Motor
- 14.8V 4000mAh 15C Li-Po Battery
- 11x4.7" Propeller
Electric Ducted Fan Power System:
- Brushless Motor
PM Me...
Chuck
chuck George is offline Find More Posts by chuck George
Discussion BAE Hawk Full Composite for 90mm EDF Kerberos Electric Ducted Fan Jet Talk 79 Oct 15, 2010 12:57 AM
Video Twin 90mm Sukhoi SU-27 Flanker maiden tom bacsanyi Electric Plane Talk 8 Mar 10, 2010 07:15 PM
Sold FIY SU-47-Haoye SU-27 Twin-BAE Hawk 90mm EDF chuck George Aircraft - Electric - Jets (FS/W) 1 Jan 18, 2010 12:20 PM
Discussion First Twin EDF: Sapac F-22 vs. FIY SU-47 Smokescreen38 Foamy EDFs 7 Jun 03, 2008 07:58 PM
Want to fly a twin 90mm EDF SU-27? mario alvarez Electric Ducted Fan Jet Talk 4 Sep 02, 2005 10:10 PM
