Espritmodel.com Heli Air
Old Jan 26, 2010, 08:49 PM
cbear's Avatar
jacksonville florida
Joined Feb 2005
aleron conection help
i need help conecting the alerons on my new dlg, i have a conector that came with the kit that has 4 pins, i want to have alerons and flaps- flaperons and be able to reflex the wing up to leave the down air , can someone post a pic of how this works with one servo in each wing,4 wires from the wing going to the reciever , thanks
cbear is offline Find More Posts by cbear
Old Jan 26, 2010, 09:34 PM
Steve
USA, PA, Marysville
Joined Nov 2009
if no one has a diagram I,ll send a pic of a complete harness
saddlesore is offline Find More Posts by saddlesore
Old Jan 26, 2010, 09:36 PM
soarluck's Avatar
Canada .the great
Simple really ....look at it this way ..three wires on each servo two are to power the servo [black/red] the colour wire is the signal wire ..treat the signal wire as the wire that gets the commands from the receiver
the power wires /black/red can be connected together from both servo`s then you only need 4 wires from there [2 signals and a black and a white]
If you want to you could run all servos off just one plug on the rx but the signal wires need the proper port
SL
soarluck is offline Find More Posts by soarluck
Old Jan 26, 2010, 09:49 PM
cbear's Avatar
Joined Feb 2005
got it thanks guys
Old Jan 26, 2010, 09:52 PM
Joined Dec 2009
soarluck said it right, I just figured I'd paint something up quick.
DKryst111 is offline Find More Posts by DKryst111
Old Jan 26, 2010, 09:54 PM
Joined Dec 2009
p.s. I use a bigger servo in my oppisite from the peg wing for balance purposes =P
Old Jan 26, 2010, 10:03 PM
Steve
USA, PA, Marysville
Joined Nov 2009
its a little fuzzy
Old Jan 27, 2010, 09:23 AM
Chuck 'Em and Chase 'Em
Fly2High's Avatar
Long Island, NY
Joined Aug 2005
Aradhana has the connector diagramed and photographed here superbly. All his instructions are top notch
http://www.rcbuilder.com/lh_guide/ma...er_harness.htm
I think this will answer all your questions.
Good Luck
Frank
Fly2High is offline Find More Posts by Fly2High
Old Jan 27, 2010, 10:33 AM
Guz
Gutless wonder
Guz's Avatar
Tempe, AZ
Joined Dec 2005
Basic schematic
Guz is offline Find More Posts by Guz
Question Aleron throw differential bondohead Electric Plane Talk 16 Jan 04, 2010 09:02 PM
Discussion Conection break down ? Palo Gabris Batteries and Chargers 0 Oct 03, 2009 06:04 PM
Question removing a cig lighter conection lilpip Batteries and Chargers 2 Sep 25, 2006 07:23 PM
Stuttering starts = poor conection Larry3215 Power Systems 0 Jun 24, 2004 12:36 AM
Urgent!!!! FMA mini 20 ESC conection to the motor spy0o7 Power Systems 5 Jul 08, 2001 07:13 AM
