This thread is privately moderated by _Lunchbox_, who may elect to delete unwanted replies.
Old Jan 28, 2010, 09:24 PM
Liquidity is offline
Find More Posts by Liquidity
YardGoat lives with mama
Joined Feb 2007
Now that you have his number, lets send him 17 anchovy pizzas
Liquidity is offline Find More Posts by Liquidity
Old Jan 28, 2010, 09:38 PM
jkarpy is offline
Find More Posts by jkarpy
jkarpy's Avatar
USA, FL, Orlando
Joined Aug 2006
Originally Posted by rcproptester View Post
I talked to James. I can fix the problem I created. I debonded the W1A from the wing and will glue it THE CORRECT WAY when the debonder dries out of the wood.
As far as the LE goes, I missed the step where you put the LE crutch in. I installed a stringer in its place, and I think it is too glued in to try and take it out. After talking to James, I can slightly modify a 1/8 x 3/16 stick and use it for the LE. It will require a little sanding, but I will make it right.
Use the 3/16 X 3/16 for the leading edge. That is the way it is normally. You just may need to knock down one corner so it fits against the birds-mouth of the ribs.
jkarpy is offline Find More Posts by jkarpy
Old Jan 28, 2010, 09:39 PM
jkarpy is offline
jkarpy's Avatar
USA, FL, Orlando
Joined Aug 2006
No not anchovy!
Old Jan 29, 2010, 04:31 AM
_Lunchbox_ is offline
Find More Posts by _Lunchbox_
Hodgehound # 3
_Lunchbox_'s Avatar
Adrian, GA
Joined Mar 2005
Originally Posted by jkarpy View Post
use the 3/16 x 3/16 for the leading edge. That is the way it is normally. You just may need to knock down one corner so it fits against the birds-mouth of the ribs.
ok.
_Lunchbox_ is offline Find More Posts by _Lunchbox_
Old Feb 01, 2010, 07:22 PM
bildo baggins is offline
Find More Posts by bildo baggins
Chillin till SEFF
bildo baggins's Avatar
Warner Robins, GA
Joined Aug 2003
Done yet?
bildo baggins is offline Find More Posts by bildo baggins
Old Feb 01, 2010, 07:24 PM
Hodgehound # 3
_Lunchbox_'s Avatar
Adrian, GA
Joined Mar 2005
no. I plan on working more tomorrow
Old Feb 01, 2010, 07:56 PM
rcHeli101 is offline
Find More Posts by rcHeli101
United States, NC, Raleigh
Joined Oct 2009
So you are saying that the LE and TE pieces should be inserted all the way into the notch? I did insert them all the way into the notch. I also test fit everything before I glued. However, when I looked at the wings after I glued them I realized that they were identical. I think I should have turned around W1A on one of the wing halves.
Here are a couple close up pictures for you to look at...
I did practically the same thing; lots of errors throughout. However, I put on my surgeon's mask and took things apart as needed...not fun. In the end, I named it FrankenStick as there was something broken in about every area! But...it all worked out well and you cannot really see the inconsistencies. More importantly, it flies great!
Jeff
rcHeli101 is offline Find More Posts by rcHeli101
Old Feb 01, 2010, 07:57 PM
Joined Oct 2009
If you can find someone with 2 left wings, then you can make me a SSX Biplane
That's funny stuff! LOL
Old Feb 01, 2010, 08:01 PM
Hodgehound # 3
_Lunchbox_'s Avatar
Adrian, GA
Joined Mar 2005
Jeff
Yeah, they are good flying planes...
FOr some reason, I always end up making at least 1 mistake when I build a plane from a kit.... whether it is a MRC plane or not
Must be something wrong with me...
Old Feb 02, 2010, 07:35 PM
Joined Feb 2007
any work tonight?
Old Feb 02, 2010, 07:37 PM
Hodgehound # 3
_Lunchbox_'s Avatar
Adrian, GA
Joined Mar 2005
no. I didn't get home till 7.
I am tired and am about to go to bed.... Maybe tomorrow I'll build the tail upside down.
Old Feb 02, 2010, 07:41 PM
Joined Feb 2007
i thought you were eating pie all day..
Old Feb 02, 2010, 07:43 PM
Hodgehound # 3
_Lunchbox_'s Avatar
Adrian, GA
Joined Mar 2005
No, all those texts I was responding to, I was doing while working.....I even worked till after 5, and was 2 hours from home...
Old Feb 05, 2010, 08:56 PM
Joined Feb 2007
And then!!!!!
Old Feb 05, 2010, 08:58 PM
Joined Feb 2007
James do you have another plane I am buy and send to Jeff to build for me for SEFF when he gets done with this and the Groovy 3d .
Maybe something not advertised
Sold Millenium X-gear Carbon Fiber Landing gear for Slow Stick Scirocco14 Aircraft - General - Miscellaneous (FS/W) 2 Jan 11, 2010 10:38 PM
For Sale Millennium RC Slow Stick outflying3d Aircraft - Electric - Airplanes (FS/W) 0 Jul 11, 2009 01:21 PM
Article Millennium RC Slow Stick X Kit Review Tram Parkflyers 81 May 23, 2009 09:23 AM
Discussion AP Slowstick - Millennium RC: Slow Stick X Hellsiege Aerial Photography 1 Aug 18, 2008 12:11 PM
