Old Jan 25, 2010, 10:22 PM
scolen3 is offline
Find More Posts by scolen3
Lencl
scolen3's Avatar
United States, WA, Puyallup
Joined Jul 2008
Help!
Why is my helicopter wobbling at lower RPMs?
I just finished building my TREX 450 and for some reason the head seems fine at higher rpms, but when near the lower speeds, the head begins to oscillate hard. The video explains all.
Do you guys think its something with the shaft, even though its a new shaft?
In the video, notice how it gets really bad when I throttle down.
http://www.youtube.com/watch?v=rxISBmRpL44
scolen3 is offline Find More Posts by scolen3
Old Jan 25, 2010, 10:46 PM
bad400 is offline
Find More Posts by bad400
crashs come easy patience dont
bad400's Avatar
USA, MI, Shelby Township
Joined Jan 2009
check to see if the main blade`s are to tight first.
if you can move them by hand farely freely not where they`ll blow in the wind but not tight enough you have to force them to move.
then loosen the jesus bolt in the head hub and check to see if the hub is seated on the shaft correctly.
then check the main shaft.
then check the swashplate center bearing, if you crashed hard this could have gotton damaged.
bad400 is offline Find More Posts by bad400
Old Jan 25, 2010, 10:51 PM
MakMov is offline
Find More Posts by MakMov
Excellence is Expected
MakMov's Avatar
Aurora, Colorado
Joined Nov 2005
That is what I was kind of thinking too. Blades might be too tight.
It would be nice to see a little more.
MakMov is offline Find More Posts by MakMov
Old Jan 25, 2010, 10:58 PM
scolen3 is offline
Lencl
scolen3's Avatar
Joined Jul 2008
Ok, i am going to try with a spare align shaft I had. The shaft is new and perfectly straight. Will post results in a moment.
Old Jan 25, 2010, 11:07 PM
Xrayted is offline
Find More Posts by Xrayted
Closed Account
Joined Dec 2007
Assuming nothing bent or poorly set up, this can be pretty typical on spin up and spin down if the blades are either too loose or too tight. Sometimes what you are seeing are the blades spinning out with inertia to their proper lead/lag position and then they smooth out. Once the RPM comes down they go out again because the inertia is reduced. This will be especially apparent if the spool up is not slow and smooth because the rotor "kicks" on startup and moves the blades out of their straight out position momentarily.
I had this fairly bad on a 500 of mine and my blades were too loose. I snugged them down just a bit so they would not fold or move when the rotor started moving but they were still moveable with force from my hand. I would pull them out straight before spoolup and the problem went away.
Xrayted is offline Find More Posts by Xrayted
Old Jan 25, 2010, 11:16 PM
scolen3 is offline
Lencl
scolen3's Avatar
Joined Jul 2008
Here is a video up close with a new shaft and without the main blades. The wobble is not a huge amount but still noticeable. I don't understand what could be possibly going wrong.
http://www.youtube.com/watch?v=QF90Ex--1xk
i don't think this is bad enough to be a problem, but I am fairly new to helicopters. It just seems that everything is set up perfectly, and I am worried that anything might be going wrong.
Old Jan 25, 2010, 11:21 PM
Xrayted is offline
Closed Account
Joined Dec 2007
rotor wobble 2nd test (0 min 56 sec)
Maybe pull the entire head while still on the main shaft and balance the entire unit on the shaft with flybars and blades. Its the long way home but Ive had to do it before to get rid of any unbalance or vibes. Make sure the flybar is set directly center with same amount of bar on each side and the paddles are not off in weight from each other.
Your vid doesnt look that bad to me really and I dont think i would have noticed it. You cant always rely on looking at the head button movement as they may not have drilled it perfectly center. Its not a precision part so it may not always appear to spin true.
Old Jan 25, 2010, 11:22 PM
scolen3 is offline
Lencl
scolen3's Avatar
Joined Jul 2008
Yes, I replaced the shaft, then balanced the blades perfectly by screwing them together then balancing them. A few pieces of tape later, and the thing is perfectly smooth. thanks for the answers guys.
Old Jan 25, 2010, 11:26 PM
MakMov is offline
MakMov's Avatar
Aurora, Colorado
Joined Nov 2005
Take the head apart. There is a known machining defect where the the dampers seat on this head.
Old Jan 25, 2010, 11:29 PM
scolen3 is offline
Lencl
scolen3's Avatar
Joined Jul 2008
Can you explain in further detail?
Old Jan 25, 2010, 11:39 PM
MakMov is offline
MakMov's Avatar
Aurora, Colorado
Joined Nov 2005
Yes, it's not machined square. Nothing you can do about but verify that is the problem.
I will try and find the tread again but it was some time ago showing pictures of the EXI head stripped down. Clearly a machining defect that causes the feathing shaft to be cocked off from 90 degrees to the main shaft at a neutrual position.
It might have been at Xheli's forum, which has been redone but not archived.
It sould be pretty obvious without even measuring it. The one I saw was very obviously not machined square.
Old Jan 25, 2010, 11:53 PM
scolen3 is offline
Lencl
scolen3's Avatar
Joined Jul 2008
I will check it, but I would not be surprised if they revised it. I don't have the stock metal head, with the plastic arms, but the full metal upgrade. Although they might be using the same parts though, I don't know.
Old Jan 26, 2010, 12:11 AM
MakMov is offline
MakMov's Avatar
Aurora, Colorado
Joined Nov 2005
This is where the problem has been.
For whatever reason from time to time they get this hole machined off center which causes all kinds of problems.
I am sure they use the same head block for the full metal upgrade.
This one is okay.
Old Jan 26, 2010, 12:25 AM
ModeTwo is offline
Find More Posts by ModeTwo
British Columbia
Joined Oct 2008
Check to see if your main gear isn't out-of-round and also if your mesh is correct.
ModeTwo is offline Find More Posts by ModeTwo
Old Jan 26, 2010, 12:29 AM
scolen3 is offline
Lencl
scolen3's Avatar
Joined Jul 2008
I just checked, and from what I can see, fortunately, it looks like my block was drilled straight.
Discussion Why do we use lower frequencies kyle7119 FPV Talk 4 Dec 27, 2009 08:39 PM
Help! HELP, Atlas outrunner, noise at certain RPMs??? SwissBoy Power Systems 5 Sep 30, 2009 10:48 AM
Discussion My motor is spinning at how many rpms???!! eMikey Castle Creations 1 Sep 22, 2009 12:48 PM
Discussion Now, So why Do My Lower Extremities Itch more on My Left Side ? robinflyer Life, The Universe, and Politics 33 Sep 18, 2009 10:36 PM
Discussion Why aren't RPMs and prop size ever listed in electric motor specs?? rcmigpilot Sport Planes 10 Aug 01, 2009 02:27 AM
