Found this HE TX photo in someone's posting; couldn't find it via HH/JR -- website or via manual.
Still not sure what happens w/Flap Trim in HE mode -- the switch is changed to flight mode; the trom button is lsted as HOV TRIM on HE. Lool what they usta do for the 652; too bad they don't today! As I said been tyring to get a 400 3D going and have found HH CS useless -- The Manual is right!!! When I asked how is it possible since the RX is 6 ch, and the function they said worked per the manual used #7 -- click! |
Durango Colorado
Joined Sep 2001
I fly my helis on an air version dx7 now and I use the rudd rate switch on the right for throttle hold. I have my brain trained to use it and if I upgrade to the 9503 I would want it to be in the same position. So does it matter if it's air or heli in setting up this switch?
Latest blog entry: FPV mQX
Here's what I've learned so far about Air TX w/Heli:
A -- Flap switch becomes Flight Mode B -- Gear switch still does #5 C -- Mix switch does throttle hold Still haven't figure our what these do in Heli mode on an Air TX: Flap Trim Trainer button Aux 2 & trim Left & Right knobs/sliders This pdf might be of help too. |
Because they were designed as 72mHz radio first and the weight of the antenna made the hook needed higher on the facia of the radio. They were upgraded to 2.4 later. The new 11x is a brand new design and is balanced correctly for 2,4 as it was designed from the start for 2.4.
Latest blog entry: Mystery summit FPV adventures
Durango Colorado
Joined Sep 2001
Joined Jul 2005
JR DSX-9 compatible with Jeti Duplex?
Hi,
does anybody know, if the JR Transmitters are compatible with the Yeti Duplex System ? Regards Paul www.mac-fly.eu |
Well, I took the plunge into 2.4 and supported my local hobby shop. She's just coming off the first charge now
![]() Question: Would I use a "Y" Harness for the flap servos, or plug each into a different channel? Directions don't say. And where is the directions for the timer function? I must have missed it in my haste. |
| Thread Tools | |
| Sold Spektrum SM3001 DSM 2.4GHz Racing Micro Receiver | reddyrightnow | Cars - Motorcycles (FS/W) | 0 | Jan 25, 2010 01:25 PM |
| Sold JR X9303 2.4 DSM Helicopter Radio/TX with R921 Receiver | broncoholic | Aircraft - General - Radio Equipment (FS/W) | 1 | Jan 15, 2010 08:52 AM |
| Sold Spektrumized JR XP 6102 2.4ghz DSM | fixed3d | Aircraft - General - Radio Equipment (FS/W) | 3 | Dec 05, 2009 03:01 PM |
| Sold Spektrum AR6000 Rx. 2.4GHz DSM. | Backwing | Aircraft - General - Radio Equipment (FS/W) | 1 | Nov 17, 2009 08:05 AM |
| Sold Spektrum DX6i 2.4Ghz Transmitter with Blade 400 programming. $105 shipped Cont. U.S. | LESLIEx317537 | Aircraft - General - Radio Equipment (FS/W) | 5 | Apr 23, 2008 10:43 AM |
