Old Jan 25, 2010, 02:07 PM
KMKAZE is offline
Find More Posts by KMKAZE
Question gravity.
KMKAZE's Avatar
Kane County, Il
Joined Sep 2000
Gyro on fixed wing question...
My buddy gave me a gyro, and I am thinking about putting it on my .40 size sport plane just to see what it does.
The ailerons are on seperate channels for flaperon function, so I don't see how I would use the gyro with the ailerons.
So I'm thinking about trying it on the elevator. I think it would allow me to push the CG back farther than would normally be acceptable. Has anyone tried this?
And as far as gyros on nitro planes...will the vibration of the fuselage mess with the function of the gyro? Or should the gyro be well padded to protect from vibration?
Thanks!
KMKAZE is offline Find More Posts by KMKAZE
Old Jan 25, 2010, 08:34 PM
jppizhere is offline
Find More Posts by jppizhere
Sanford, NC
Joined Apr 2007
Don't know about gyros on nitro planes, but gyros on helis are typically mounted with double sided foam tape to help vibration isolate them.
jppizhere is offline Find More Posts by jppizhere
Old Jan 27, 2010, 03:45 AM
screwup is offline
Find More Posts by screwup
no gap is too 'small'
screwup's Avatar
Melbourne, Australia
Joined Feb 2009
i put a gyro on my elevator and when the plane speeds up it startss to bob up and down really fast..
screwup is offline Find More Posts by screwup
Old Jan 27, 2010, 06:25 PM
Sanford, NC
Joined Apr 2007
Mounted the gyro the wrong direction maybe?
Old Jan 27, 2010, 08:07 PM
screwup is offline
screwup's Avatar
Joined Feb 2009
mounted it every way but still does it .. lucky to get it back in one piece
Old Feb 01, 2010, 05:55 PM
MyMassMail is offline
Find More Posts by MyMassMail
Trail Starts/Ends Here...
Joined Aug 2006
Use a Heading Hold type on the RUDDER...
Originally Posted by KMKAZE View Post
My buddy gave me a gyro, SNIP SNIP SNIP, I'm thinking about trying it on the elevator. I think it would allow me to push the CG back farther than would normally be acceptable. Has anyone tried this?
SNIP SNIP SNIP
Good evening,
This subject came up about a year ago and intrigued me at the time. Do a search ('taildragger rudder gyro' will probably work) and you'll find the following consensus...
Best use is on the RUDDER of a TAILDRAGGER with a short overall fuselage that wants to ground loop in a heartbeat. Especially if you have not mastered their setup.
The heading hold type SHOULD be able to be turned OFF after takeoff for the safest flight but rudder commands WILL override the heading hold type gyro if left on.
Have fun figuring out what type you have and possibly experimenting with it.
MMM
MyMassMail is offline Find More Posts by MyMassMail
Discussion Gyro on a fixed wing plane???? ernie5229 Electric Plane Talk 8 Dec 14, 2007 01:09 AM
Discussion Gyro stabilizers in fixed wing A/C. rayspan United Kingdom 1 Aug 14, 2006 05:48 AM
PG-03 Gyro in Fixed Wing workshop GWS (Grand Wing Servo) 5 May 24, 2005 09:25 PM
GWS PG-03 Gyro Jitter on Fixed Wing workshop Radios 0 May 23, 2005 06:00 PM
Tip stall fixed on Wally Wing stevem1928 Parkflyers 10 May 28, 2003 06:07 PM
