Now you're talking my language. Lots of hardware hanging out on display. I'm not sure how to do that *and* have belly landings too. Visually, if not functionally, I'm hoping the sponsons that I'm doing now as a test will look like they could be either landing gear fairings or perhaps some kind of weapon mount.
I do like the idea of using the 6th channel to release bombs and/or fuel tanks from under the wings. That'd work. |
Ok, sponsons are finished now. 3 layers of 6mm deprom to make the thickness, then a cosmetic sheeting of 3mm depron that forms the slope down from the top. Sanded and fibreglassed with WPU.
This makes the effective width of the fuselage now 90mm at the widest part of its footprint. Have just thought to myself, this would all have been rather simpler if I'd just built the whole fuse wider to start with. 90mm wide instead of 54mm. Doh. |
Staffordshire, England
Joined Feb 2005
I like the wing section. I have been playing with the idea of a similar section but haven't tried it yet. I certainly looks better than a flat sheet and is easy to bevel the LE to fit. Did it give a good rate of climb and a better glide engine off?
The wing section is great. I'd say the glide with power off is twice as good as a flat section. This is first time I've done it exactly this way, but I'm sold on it now. Rate of climb is just down to the thrust available I'd say. Either way she goes vertical if you point her upwards and open the throttle.
The glasscloth I got a while back, mail order from here - http://balsamart.co.uk/store/index.p...&cPath=109_199 - it's in a bag I labelled as Flair 25gm=0.9oz - What's glass tissue like? is it lighter? |
Ok, all done. Nose has been lowered, sponsons have added, prop rotation reversed. She's ready for more take-off trails now.
AUW has now gone up to 512g what with all that extra foam, glue and fibreglass. Mind you she flies so nicely I'm tempted to stick in the bigger battery and she if she stays up there all day. What I mean is I don't think weight is an issue. Yet. |
Jackal_09_B - Have updated the Sketchup drawing, so here's the latest version. It now shows sponsons drawn at correct size and placement, shows flat belly and lower nose, also I have corrected the tail width now (12mm), and the drawing now shows scale thickness to all tail surfaces parts.
Also been thinking about a low-tech camera mount for shooting on-board video, using the Kyocera Finecam SL300R. It's just a simple cradle to help angle the lens down 3 degrees from horizontal, and some extra strong rubber bands. Best make sure the landings are smooth with this arrangement.
On board video - flight test number 1 here is a total 2min 10sec of twin engined pov video fun. How many trees in the way?
![]() http://s896.photobucket.com/albums/a...Vid_test_1.flv The next one will show me sticking her into one of them there trees. |
| Thread Tools | |
| Yippee! Jimmy J-Flyers "J-Bug" My own front yard flyer...RET Old Timer style, Plans & Video. | Jimmy JFlyer | Foamies (Scratchbuilt) | 1626 | Today 10:49 AM |
| Build Log 1957 Tri-Pacer parkflyer 36 1/2" span | B. Bradley | Scale Electric Planes | 73 | Jan 30, 2011 06:36 PM |
| Discussion Depron Seadart easy build waterplane parkflyer ***PLANS*** | vleisie | Foamies (Scratchbuilt) | 24 | Dec 24, 2010 09:52 AM |
| Wanted Plans for Fairchild Packet (Flying Boxcar)twin engined control line control l | mchandrayan | Aircraft - Fuel - Airplanes (FS/W) | 3 | Oct 10, 2005 08:44 PM |
| Plans for sale,Parkflyer Tiger Moth,F-14 Tomcat twin EDF | bipeflyer | Aircraft - Electric - Airplanes (FS/W) | 1 | Jan 16, 2002 11:57 AM |
