Old Oct 15, 2012, 10:01 AM
twinkle is offline
Find More Posts by twinkle
It can't rain all the time
twinkle's Avatar
United Kingdom, Peacehaven
Joined Mar 2009
wing section
Originally Posted by M4d_D View Post
hi,
this is a really great looking plane
i am thinking of building one myself, has anyone ever tried a kfm3 airfoil in it ?
cheers
Cannot see a problem I have used a kfm2 and a built up section and aero andy and several others have used KFm on some
The KFm3 would make the wing a lot stronger as my camo jeckel gets" KFm cracks "on the thinner section go for 3 thicknesses two thickness back to the ailerons and it should work well with a carbon spar buried in the middle
See the first page for the photos of finished planes
regards emma
twinkle is offline Find More Posts by twinkle
Old May 11, 2013, 02:07 AM
Ponappa is offline
Find More Posts by Ponappa
India, KA, Bangalore
Joined Dec 2012
Jackal / Jackel look alike Alenia C-27J Spartan
Please check this lot of google images....
https://www.google.co.in/search?q=C-...rg.mozilla:en-
USfficial&source=lnms&tbm=isch&sa=X&ei=5tSNUdXOF oOVrAfnmIC4DA&ved=0CAoQ_AUoAQ&biw=1304&bih=638
http://en.wikipedia.org/wiki/Alenia_C-27J_Spartan
Ponappa
Ponappa is offline Find More Posts by Ponappa
Old May 29, 2013, 02:18 PM
mikicad67 is offline
Find More Posts by mikicad67
Italy, Lombardy, Saronno
Joined Jul 2012
C27J Spartan Italy by Michele
Ponappa
Hello, Im Italian ...my C27J spartan 63"
youtube
C27J Spartan 63' (5 min 19 sec)
C27J Spartan 63" - Finalmente (1 min 32 sec)
Hello
mikicad67 is offline Find More Posts by mikicad67
Old May 31, 2013, 11:49 PM
brett.c is offline
Find More Posts by brett.c
Foam is where the heart is
brett.c's Avatar
Australia, NSW, Sydney
Joined Aug 2010
Miki, nice effort there mate.
You went to a lot of effort with the CAD drawings etc.
I just start with a 3 view, calculator, some foam and a knife.
And make lots of mistakes along the way
Twins can be very addictive.
This is my latest effort and 3rd twin so far.
I used the Jackal wing as the basis.
brett.c is offline Find More Posts by brett.c
Old Jun 01, 2013, 07:03 AM
CaseySP is offline
Find More Posts by CaseySP
CaseySP's Avatar
Canberra Australia
Joined Feb 2007
Both the Spartan and the Bronco look great! Good idea to re-use WMD's wing design - works great and is very easy to build, wouldn't bother with KFM2.
CaseySP is offline Find More Posts by CaseySP
Old Jun 01, 2013, 08:19 AM
twinkle is offline
twinkle's Avatar
Joined Mar 2009
looking good
Hi Folks
that is a nice looking twin , I still have my 3 at home but not a lot of hours on any of them at the moment as the weather has been foul
regards emma
Old Jul 02, 2013, 05:34 PM
CaseySP is offline
CaseySP's Avatar
Canberra Australia
Joined Feb 2007
Almost 18 months old and still as good to fly as ever.
Tried an under-wing mount for the video camera. Not very exciting, just liked how it captures the nose leg cycling up and down .
As you can see by the landing it's not steerable - and the rudder can't overcome the grip of the astroturf strip .
Jackal at BMAC 30 June 2013 (1 min 54 sec)
Old Aug 05, 2013, 08:06 PM
mbpetri is offline
Find More Posts by mbpetri
Marty Petri Sr.
mbpetri's Avatar
Thailand, Uttaradit, Bo Thong
Joined Jun 2007
I like the original Jackal Twin Wing Design... Simplicity. Also great that you did the design in Sketchup. I just completed a Foamie Hog Bipe design in Sketchup also.
http://www.rcgroups.com/forums/showt...1959522&page=1
Marty
mbpetri is offline Find More Posts by mbpetri
Old Aug 08, 2013, 10:08 AM
Extreme Sports is offline
Find More Posts by Extreme Sports
Extreme Sports's Avatar
South Africa, GP, Johannesburg
Joined May 2012
Correx version
Here is another Jackal/ Partenavia inspired variant. Was about to build a B25 as a first twin, but found this thread and used this design as the basis instead - seemed simple to build and a proven performer.
Basically its a 125% Jackal with the fuselage widened to be closer to the P68's dimensions and a Twin Otter nose and (all terrain!) wheels added. The nose wheel castors and differential thrust allows for ground manoeuvring. I also made the wing chord constant as I have separate ailerons and flaps...the outer end of the Jackal's tapered flaperons just looked too small for ailerons. Construction is primarily 2mm correx (its much cheaper than Depron here and suited to building a fuselage with a rounded cross-section).
AUW with the standard Jackal power set-up is around 870-880g. The two E-Max's provide way more power than needed.
Extreme Sports is offline Find More Posts by Extreme Sports
Old Aug 09, 2013, 03:21 AM
CaseySP is offline
CaseySP's Avatar
Canberra Australia
Joined Feb 2007
Very nice looking Partenavia/Twotter!
Old Jan 26, 2014, 05:14 AM
CJGFX is offline
Find More Posts by CJGFX
CJGFX's Avatar
France, PACA, Grasse
Joined Dec 2006
I've been looking at this plane for a while now and finally got most of the parts together to start building. It's ashame the thread has been quiet for a while, so hopefully I can try and get it going again. It's a great looking plane, the only thing I may do is to widen the body a little to fit a bomb drop or GoPro camera bay.
The one thing I'm struggling to find it the counter rotating prop.... Anyone know where i can find them in Europe, OR has any one had success with the two props swinging the same way?
I'll hopefully make a start in the next couple of weeks.....
CJGFX is offline Find More Posts by CJGFX
Old Jan 26, 2014, 05:37 AM
twinkle is offline
twinkle's Avatar
Joined Mar 2009
Originally Posted by CJGFX View Post
I It's ashame the thread has been quiet for a while, so hopefully I can try and get it going again. It's a great looking plane, the only thing I may do is to widen the body a little to fit a bomb drop or GoPro camera bay.
Giantshark has the props in stock and they are NOT expensive get a couple of pairs at a time they are about 2E a pair , also have the 2812 2822 motors in stock ,
with both props going the same way you will get a torque swing on power up
see post earlier in the thread
I still have all 3 of mine , been sidetracked for a while building recumbent trikes ( see blog )
They are good fun machines
regards emma
Old Jan 26, 2014, 06:55 AM
headlessagain is online now
Find More Posts by headlessagain
Reap the wild wind
headlessagain's Avatar
Bristol,UK
Joined Feb 2007
HobbyKing also stock standard ans contra rotating props in their Europe warehouse
http://www.hobbyking.com/hobbyking/s...ropellers.html
Andy
headlessagain is online now Find More Posts by headlessagain
Old Jan 26, 2014, 11:55 AM
CJGFX is offline
CJGFX's Avatar
Joined Dec 2006
Thank you Emma
I've looked again of the Giant Shark website and still can not find the right props, if you find th send me a link. I got all the electronics already from there, great service.
I like you variations on this plane that you made, I'm hoping that I can get a bomb dropper to work out OK.
I'll have to do an order from HobbyKing Europe, I just hope that there don't take the usual week to put them in the post!!
Cheers for you help all....
regards emma
Old Jan 26, 2014, 01:43 PM
twinkle is offline
twinkle's Avatar
Joined Mar 2009
Thank you Emma
this is what I used plenty of power with 2812 motors and 1800 3s lipo
after takeoff you can go down to 1/2 throttle and still climb
http://www.giantshark.co.uk/product/...ating-sf-props
The 3 jackal / jeckel and camo jeckel are still in service , and the MIG is still unfinished but if I dont build another model I have enough for the next 10 years
Still got a pair of slec bombs to fit on the camo one they will look like tallboys
now I have another pair of trike wheels to build
Yippee! Jimmy J-Flyers "J-Bug" My own front yard flyer...RET Old Timer style, Plans & Video. Jimmy JFlyer Foamies (Scratchbuilt) 1868 Mar 04, 2016 04:42 PM
Build Log 1957 Tri-Pacer parkflyer 36 1/2" span B. Bradley Scale Kit/Scratch Built 73 Jan 30, 2011 06:36 PM
Discussion Depron Seadart easy build waterplane parkflyer ***PLANS*** vleisie Foamies (Scratchbuilt) 24 Dec 24, 2010 09:52 AM
Wanted Plans for Fairchild Packet (Flying Boxcar)twin engined control line control l mchandrayan Aircraft - Fuel - Airplanes (FS/W) 3 Oct 10, 2005 08:44 PM
Plans for sale,Parkflyer Tiger Moth,F-14 Tomcat twin EDF bipeflyer Aircraft - Electric - Airplanes (FS/W) 1 Jan 16, 2002 11:57 AM
