Old Aug 07, 2011, 09:58 AM
Aero Andy is offline
Find More Posts by Aero Andy
ExPat
Aero Andy's Avatar
Spain, Murcia, Mazarrón
Joined Apr 2010
OK guys, the maiden went well, up to a point. The good news is it flies, and I've plenty of power, the bad news is, it wants to turn left all the time until I give it WOT, then it straightens up. So, it's just as I described earlier, the right hand motor is starting up first, and through the throttle curve it's increasing in RPM slightly ahead of the left motor. When WOT is reached the the left motor catches up and the RPM's are identical, so it's this start-up lag which is the issue.
I have four spare 10g motors and three 6A plush esc's, and in an effort to get any two motors to start at the same time, I've tried combinations of all kinds. The esc settings are all identical, but still I'm having no luck.
Regards
Andy
Aero Andy is offline Find More Posts by Aero Andy
Old Aug 07, 2011, 11:00 AM
headlessagain is offline
Find More Posts by headlessagain
Reap the wild wind
headlessagain's Avatar
Bristol,UK
Joined Feb 2007
Looks like your out of options, time to go for differential control as used in the "The Twins"
Head
headlessagain is offline Find More Posts by headlessagain
Old Aug 07, 2011, 11:14 AM
ExPat
Aero Andy's Avatar
Joined Apr 2010
Head
Yeah, looks like the only option, unless I want to fly in circles all day....
Andy
Old Aug 07, 2011, 08:46 PM
pjdog is offline
Find More Posts by pjdog
Jack
pjdog's Avatar
United States, FL, Hudson
Joined Feb 2010
Howdy Andy:
Seems like if your going to mess with multi-motored planes that a tachometer is a must.
In the old days when I was doing Nitro models I had a C-119 with a pair of OS Max .15's. Bought them both on the same day and broke them in the same way at the same time. It was real easy to get them to run and idle identical. But with electric's it seems to be a different game.
I'm waiting on a tachometer now from Tower hobbies to insure that my motors are turning the same RPM.
Can't wait to see your video.
Jack
pjdog is offline Find More Posts by pjdog
Old Aug 08, 2011, 04:08 AM
WMD is online now
WMD
Find More Posts by WMD
WMD
WMD's Avatar
Bradford, UK
Joined Jan 2010
Hi Andy,
I dunno. I've only ever built one twin, so far, and this is it. Maybe I just got lucky, but I had no issues with power offset/balance, I just installed 2 x CF 2812 motors, 2 escs, and it worked first time.
My motors do not start exactly together, but that is just a momentary thing, I just ignore that and set off. In the air, all is good. I think I wrote earlier that at one point when throttling back I managed to stop one motor and not the other by mistake, then throttled back up and found myself flying on one engine for a few seconds. But flight was still smooth, still controlled.
I don't think the start time difference of the motors matters, because you can just push past that to get them both going. What matters I think is that they have a (broadly) similar response together up through the throttle range. Surely switching motors around if you have - 4 spares - would at some point fix it? Mind you throttle diff control would be a cool thing to do too.
Steve
WMD is online now Find More Posts by WMD
Old Aug 08, 2011, 11:45 AM
ExPat
Aero Andy's Avatar
Joined Apr 2010
Steve
These motors are driving me crazy, but I'm not giving in...
I'm a stubborn bugger and I'm determined to get it right, this plane will fly properly, even if it drives me into an asylum.
A challenge is a challenge, bring it on...
Andy
Old Aug 09, 2011, 08:11 AM
nkkromhof is offline
Find More Posts by nkkromhof
NKK for short...
nkkromhof's Avatar
United States, IN, Mitchell
Joined Oct 2010
Silly question, you have calibrated the throttle range on both ESC's, right?
Did a quick scan of the last couple of pages and didn't see it mentioned...
It may be necessary to do them both separately, unplug one, calibrate; unplug and plug the other one in and repeat.
Regards
Andy
nkkromhof is offline Find More Posts by nkkromhof
Old Aug 09, 2011, 09:34 AM
ExPat
Aero Andy's Avatar
Joined Apr 2010
nkkromhof
Well what can I say my friend, except THANK YOU. You were spot on with the idea to calibrate the throttle range on esc's individually, it took me only a minute to do, and now both motors are starting at the same time, and running at the same RPM.
Many thanks again, I really appreciate your help.
Andy
Old Aug 09, 2011, 09:52 AM
pjdog is offline
Jack
pjdog's Avatar
Joined Feb 2010
Yea - Me too. Thanks nkkromhof.
That may also help my twin motored F&L. I had used to different size props for the maiden flight and had trouble. After correctly that I still noticed that the motors start at a split second different. I don't have a tachometer yet but they do seem to pull the same now. But the calibrate the ESC's both separately is a smart idea.
Jack
PS: I love Indiana.
Old Aug 09, 2011, 10:03 AM
NKK for short...
nkkromhof's Avatar
Joined Oct 2010
Glad I could help
It's nice to be right every once in a while!
Edit: I have no idea why it makes a difference to do them individually, but it's the same for tricopters and quadcopters, you have to do them individually there too.
Old Aug 09, 2011, 02:56 PM
Reap the wild wind
Bristol,UK
Joined Feb 2007
Glad I could help
I guess I got lucky with my ME-262 tractor twin but your advice will be remembered for my next build. Thanks a lot
Head
Old Aug 10, 2011, 12:05 AM
ExPat
Aero Andy's Avatar
Joined Apr 2010
Head
Isn't it amazing, I spent hour after hour swapping motors and esc's, trying to programme mix the throttles on my tx, and then "nkkromhof" come up with a simple fix. I love this site, if you don't know something, just ask, someone else will, and can help you out.
How's sunny Bristol
Andy
Old Aug 10, 2011, 01:36 AM
Reap the wild wind
Bristol,UK
Joined Feb 2007
Hi Andy
Up early again I see Bristol weather, cloudy bright with light winds. Looks like I might fit in a quickie over the park. My Freeair Fokker D V11 needs a work out.
http://www.flyingtoys.com/reviews/QEFI0909.pdf In fact it's exactly the same plane as featured in the article. The reviewer, John Stennard, is a member of my club and he sells off unwanted review planes from time to time. How about a Phase3 F-16 for £25?
Well my brother has been building and flying RC models of all types for years and it was the first time he had heard of nkkromhof's tip. I must have just been lucky with my tractor ME-262.
I'm subscribing to 86 threads. Some because I might learn something new and others because I'm interested in the build and I always try to offers advice where sought. This might just be sign posting to other threads or from my own experiences.
My build of Lee's F&L is a survivor, having been built in August 2008. I still subscribe to that thread and post when appropriate.
Head
Old Aug 10, 2011, 06:12 AM
ExPat
Aero Andy's Avatar
Joined Apr 2010
Hi Head
I didn't know you were friends with John from Q&EFI, I've been a subscriber of that magazine for years. John writes a lot of interesting stuff, and all you fellow club members are really lucky to have him selling off unwanted planes so cheap...now I'm really jealous.
Happy flying mate
Andy
Old Aug 12, 2011, 09:46 AM
ExPat
Aero Andy's Avatar
Joined Apr 2010
Hi guys, just wanted to let you know that I flew my Jackal this morning, and now my motors are spinning at the same RPM (thanks again nkkromhof), it flies great, in fact it flies amazing..
Thanks Steve for the design, I've added LG and posted some finished pictures below, I'll shoot a video next time I get chance to fly. Also, I thought I'd do something a little different with the paint scheme, I didn't have anything in civilian livery, so decided on British Airways colours.
Regards
Andy
Yippee! Jimmy J-Flyers "J-Bug" My own front yard flyer...RET Old Timer style, Plans & Video. Jimmy JFlyer Foamies (Scratchbuilt) 1878 May 28, 2016 11:36 PM
Build Log 1957 Tri-Pacer parkflyer 36 1/2" span B. Bradley Scale Kit/Scratch Built 73 Jan 30, 2011 06:36 PM
Discussion Depron Seadart easy build waterplane parkflyer ***PLANS*** vleisie Foamies (Scratchbuilt) 24 Dec 24, 2010 09:52 AM
Wanted Plans for Fairchild Packet (Flying Boxcar)twin engined control line control l mchandrayan Aircraft - Fuel - Airplanes (FS/W) 3 Oct 10, 2005 08:44 PM
Plans for sale,Parkflyer Tiger Moth,F-14 Tomcat twin EDF bipeflyer Aircraft - Electric - Airplanes (FS/W) 1 Jan 16, 2002 11:57 AM
