Old Jan 23, 2010, 07:34 PM
The Don is online now
Find More Posts by The Don
Wonderfully Wicked
The Don's Avatar
Willoughby, Ohio
Joined Jan 2002
Build Log
Wicked Powered Starmax A-4 EDF
Got this in the mail yesterday It is the A-4 from Starmax in Blue Angels color scheme. This is a small sized EDF and uses a 55mm fan unit. I originally ordered this from Banana Hobby:
http://www.bananahobby.com/1968.html
but they called and told me after I ordered it the Blue Angels color scheme was out of stock and it would be a few weeks before the next shipment arrived so I went ahead and ordered the airframe only version from Aerial Hobby as they had the Blue Angels color in stock.
The kit is very nice. I like the fact the fuselage halves are not glued together so you can work out your radio installation ahead of time. The stock 55mm fan is cross between teh GWS fan and the EDO type fans. The mountng systme is similar to the EDO style so a Wicked EDF motor with an EDO plug will mount up to this motor. The stock rotor plug included is not for a 3mm shaft motor and was probably meant to mount on a 2.3mm shaft inrunner.
My only dislike of this model is the ducting sizes. The inlets and outlets are rather large for the 55mm fan. I measure the outlet at a whopping 125% FSA and the inlets about 135% FSA. I almost feel this model was initially designed for a bigger fan unit and then it was suddenly changed. At 64mm the areas would be 100%FSA inlet and 90%FSA outlet and for a 60mm fan they would be 113% outlet and 125% inlet. For this first build I am going to use the stock an but I will also install a tailpipe. The outlet for this fan should be about 1.7-1.75" diameter and the current diameter is 2.13" so somethign needs to be done. Juts fo rthe heck of it I tried to stick the Wicked 60mm EDF fan in and it looks like it will go in pretty easy so I may do a seconds build dependingonthis one goes.
My plan is to install the Wicked 5400 motor in the stock fan and run on a 3S2200 lipo. The battery will fit nicely and the GWS EDF55 on 3S is about 400 watts with the Wicked 5400 so I expect similar but will post data shortly.
The Don is online now Find More Posts by The Don
Old Jan 23, 2010, 08:22 PM
Sammy70 is offline
Find More Posts by Sammy70
JOHN 3:16
Sammy70's Avatar
Central Ohio
Joined Feb 2008
Looks like a cool little bird Don. 400w should be WOW in this tiny thing I can't believe I missed these when they were on sale at Aerial
Keep the pics/info coming!
Sammy70 is offline Find More Posts by Sammy70
Old Jan 23, 2010, 09:04 PM
Wonderfully Wicked
The Don's Avatar
Willoughby, Ohio
Joined Jan 2002
They still are you have to log in first.
Old Jan 23, 2010, 09:14 PM
Sammy70 is offline
JOHN 3:16
Sammy70's Avatar
Central Ohio
Joined Feb 2008
Created an account and just added the white one to the cart--$59.99 = no sale for me
Old Jan 23, 2010, 09:20 PM
Wonderfully Wicked
The Don's Avatar
Willoughby, Ohio
Joined Jan 2002
Are you sure you are logged in? Does it show your name and address on the right by "shipping estimator"
Don
Old Jan 23, 2010, 09:25 PM
Sammy70 is offline
JOHN 3:16
Sammy70's Avatar
Central Ohio
Joined Feb 2008
Don
Yep, logged in. No, it doesn't show my name/address over there. Hmmm, maybe it takes their system a while to recognize you?
Old Jan 23, 2010, 09:30 PM
Wonderfully Wicked
The Don's Avatar
Willoughby, Ohio
Joined Jan 2002
Confusing does it show this on your screen after you log in?
Don
Old Jan 23, 2010, 09:33 PM
Sammy70 is offline
JOHN 3:16
Sammy70's Avatar
Central Ohio
Joined Feb 2008
Yes...
So if you put the white one in your cart right now it's at what price?
Have you already purchased from them in the past? I think it said I was a "silver" member. Maybe you're gold or platinum
Old Jan 23, 2010, 09:39 PM
corsair nut is online now
Find More Posts by corsair nut
fly like an EAGLE ;)
corsair nut's Avatar
tehachapi, CA
Joined Jan 2006
dang....i say stuff the 60mm in there don! this is a tiny model...im sure its going to ROCK!!! yeah....typical chinese inlets/tail pipes...this is what ive been screaming about...you know how much BETTER it would perform with properly sized ducting? geez, people just on me for saying things like this....aparently, they enjoy lackluster performance! :O
PS....got a BI3600 im sticking in my RCL cougar..1300W is nice, but its a draggy airframe, so it really cant use all the power. a nice 850W will be just about as fast, and way less amps. im really bummed you stopped selling that one...maybe you can bring it back in the future (one of my dads purple ones...ps....were still flying the crap out of them with no issues
corsair nut is online now Find More Posts by corsair nut
Old Jan 23, 2010, 09:40 PM
Wonderfully Wicked
The Don's Avatar
Willoughby, Ohio
Joined Jan 2002
That was my first buy but I do have 200+ reward points maybe that puts me to a new price level? Not sure
Old Jan 23, 2010, 09:45 PM
Sammy70 is offline
JOHN 3:16
Sammy70's Avatar
Central Ohio
Joined Feb 2008
Wow, how did you get 200 points before buying anything?
Oh, please feel free to delete all these posts of mine that are littering your build thread...
Old Jan 23, 2010, 09:46 PM
Wonderfully Wicked
The Don's Avatar
Willoughby, Ohio
Joined Jan 2002
If they fly this on the stock outlet it will be a dog with that 125% FSA outlet, the outlet is almost the size for a 70mm fan! I am on the fence for this build, I typically like to use the stock fans before going the mod route so people know what to expect just dropping a motor in. I may fly stock fan first then go to the other fan to see how it compares.
I can still get them but too scared to sell them
Old Jan 24, 2010, 12:50 PM
Wonderfully Wicked
The Don's Avatar
Willoughby, Ohio
Joined Jan 2002
A little dab of weight and the fan is balanced! I ran it up with two lipos, my new 30C 2200 3S lipo showed 460 watts and 41.8 amps at start up and 430 watts and 40 amps when settled. I then tried an older 3S2200 lipo around 20C rate and got 430 startup watts that settled down to 380 watts.
Old Jan 24, 2010, 04:09 PM
Sammy70 is offline
JOHN 3:16
Sammy70's Avatar
Central Ohio
Joined Feb 2008
I forget the specs size-wise on this one, do you have any pics with other popular planes for reference? A little smaller than a HP F-16 right?
Old Jan 25, 2010, 09:00 PM
Wonderfully Wicked
The Don's Avatar
Willoughby, Ohio
Joined Jan 2002
It is a tiny model. Small like the Alfa A-4, I will try and get a photo.
Build Log Wicked Powered XB-70 EDF Build Log The Don Don's RC 101 Dec 10, 2014 12:44 PM
Build Log Wicked powered Windrider BD-5J EDF Jet The Don Don's RC 118 Oct 31, 2014 10:01 AM
Build Log Wicked Powered EDO F-4 Phantom The Don Don's RC 16 Oct 17, 2011 07:10 AM
Build Log Wicked EDF Powered Hobby Lobby SU-34 build thread The Don Don's RC 55 Dec 17, 2010 12:49 PM
Discussion Wicked powered Alfa A-4 Splat762 Don's RC 26 Nov 21, 2008 08:25 PM
