Old Mar 31, 2010, 02:00 PM
motorhead is offline
Find More Posts by motorhead
motorhead's Avatar
Kansas, USA
Joined Sep 1999
I will be doing both a 32" flat foamy and a 42" with an airfoil wing.
I will definitely be posting. I am one that likes to keep things open source and I post plans for all my kits.
motorhead is offline Find More Posts by motorhead
Old Mar 31, 2010, 02:29 PM
yardboz1 is offline
Find More Posts by yardboz1
yardboz1's Avatar
LaSalle, Illinois
Joined Sep 2007
Thanks for the heads up Mike. Can't believe I missed both of these threads! Will definitely be building one as soon as I finish up my 42" Edge.
Sterling
yardboz1 is offline Find More Posts by yardboz1
Old Mar 31, 2010, 04:54 PM
jetinteriorguy is offline
Find More Posts by jetinteriorguy
Burke, VA
Joined Sep 2009
Are the ready yet? LOL!!! Can't wait.
jetinteriorguy is offline Find More Posts by jetinteriorguy
Old Apr 02, 2010, 04:25 PM
JaggedEdge is offline
Find More Posts by JaggedEdge
Buildin'em and flyin'em
JaggedEdge's Avatar
United States, NY, Erie
Joined Dec 2007
Couple pics of my progress. Should have this one ready tonight.
All the pieces are cut and cf rods glued in place. Since my sheets weren't long enough I decided to add wingtips rather than adding the fuse. glued using 5 minute epoxy. I extended the rod for the wings to help secure the wing tips.
Beveled the ail/elev edges with sandpaper.
Will be running a GWS EP8040 prop with a hextronik 1300kv motor on 25c 3s 850mah pack.
Brushless Outrunner Motor - hexTronik 24gram 1300kv
Kv - 1300rpm/v
Max Load: 7.5A
No Load Current: 0.7A
Suggested Lipo: 3 cell 11.1v
Thrust: 400g+
Suggested Prop: 8x3.8
Weight: 20g
JaggedEdge is offline Find More Posts by JaggedEdge
Old Apr 02, 2010, 10:25 PM
JaggedEdge's Avatar
Joined Dec 2007
Airframe almost completed.
Hot glue hinges worked great.
Thanks again spitfire222.
Old Apr 02, 2010, 10:30 PM
yardboz1 is offline
yardboz1's Avatar
LaSalle, Illinois
Joined Sep 2007
Lookin' good so far! What paint scheme are you planning?
Sterling
Old Apr 04, 2010, 11:26 AM
JaggedEdge's Avatar
Joined Dec 2007
Sterling
Stock red/black/white.
I put some simple landing gear on mine.
Complete auw with landing gear 11.3 oz or about 320 grams.
I'll get some pics soon.
Old Apr 04, 2010, 11:36 AM
JaggedEdge's Avatar
Joined Dec 2007
Hope to do paint soon.
Plan on making gear removable.
Old Apr 05, 2010, 08:46 AM
Spitfire222 is offline
Find More Posts by Spitfire222
You know how we do
Spitfire222's Avatar
United States, VA, Centreville
Joined Jan 2010
Looking great JaggedEdge! I'm interested in seeing your motor mount set-up in pic #2 above. This is my first outrunner-powered foamie, and I tried mounting the motor the way I've seen countless other people do it. But whether I use epoxy or Gorilla Glue, more than half the time I land, the motor mount rips out. Not sure of it's my landing style or the mounting style, but I never had that problem with my geared inrunner foamies with stick mounts. Maybe I need to add more foam to the mounting area for more gluing surface?
Here are 2 pics from this weekend, showing the launch. Unfortunately, a gust wind came up right on launch. I didn't increase throttle fast enough and it got "pushed" into the ground. I think I might go ahead and build a new one.
-Vincent
Spitfire222 is offline Find More Posts by Spitfire222
Old Apr 05, 2010, 03:14 PM
yardboz1 is offline
yardboz1's Avatar
LaSalle, Illinois
Joined Sep 2007
-Vincent
Go for it Vincent! Greatest thing about these, it's only foam!
Sterling
Old Apr 06, 2010, 10:59 AM
JaggedEdge's Avatar
Joined Dec 2007
Sorry about the mishap. Yay for foamies.
As far as the motor mount.. I cut out 4 triangles of foam and glued them 45 degrees from the fuse and wings to support the square of foam. I poked some holes in the square piece of foam and then epoxied the ply mount to the foam. I'm pretty sure the holes in the foam gave some extra strength.
This 1300kv motor doesn't give as much vertical as I'd like. Will probably pick up the 1500kv and see how it does. Maybe I should look into cutting out some weight.
-Vincent
Old Apr 06, 2010, 03:25 PM
JaggedEdge's Avatar
Joined Dec 2007
A lot like this DW foamie:
http://static.rcgroups.com/forums/at...g?d=1187190374
Old Apr 07, 2010, 04:30 PM
JaggedEdge's Avatar
Joined Dec 2007
Removed the landing gear and got the weight down to 10.7ounces or 303grams.
Old Apr 07, 2010, 07:35 PM
You know how we do
Joined Jan 2010
Thanks for the pics with the motor mounts. I'll try that on the next one. Are you planning on painting before or after the maiden?
Old Apr 08, 2010, 11:38 AM
JaggedEdge's Avatar
Joined Dec 2007
I flew it a couple times.
Had to sort out the elevator and ailerons to get the throws even.
Hope its calm enough after work to check it out again.
Build Log RCBirdz ( Eagle ) - Build Thread with Free Plans rcbirdz Foamies (Scratchbuilt) 106 Jun 15, 2014 07:19 AM
New Product Pilot RC's SBach 342 30cc!! FlattyFlier Scale Fuel Planes 28 Dec 29, 2010 08:28 PM
New Product the first 100cc Sbach 342 in the world(pics and video) pilot-rc Giant Scale Airplanes 0 Sep 18, 2009 06:03 AM
Discussion Two Seat Sbach 342 james-bai Fuel Plane Talk 1 Jul 21, 2009 12:05 AM
Discussion Sbach 342 power system? 150grams BpPilot Indoor Pattern/F3P 5 Apr 11, 2009 08:06 PM
