Wow .. thats a lot of thrust ...
I guess I need to be a little careful since I am only using a 10 AMP Esc. |
Latest blog entry: 72" Extra Flying
USA, TN, Gallatin
Joined Aug 2009
The 2203-1350 or 1600 series with the 10A esc would be ideal for the 27". Wamsy's 2205 is just overkill. Wonderfully insane and fun overkill!
The 2210-1080 looks great for the EPP 34" that weighs in at 10oz and flies with a 3S pack. I was frying its cheap 1380kv motor on 3S last night after a long hover-walk down the runway and back. I could smell it in flight. ![]() I just maidened another depron 27" that I built for a buddy. It was too windy to do anything other than harrier from side to side across the yard, but it does that so well! |
My ESC or motor never got warm though ....
Probably because it was sooooo overpowered that it normally didn't need to be flown over half throttle.
Omaha Nebraska
Joined Apr 2008
There will be a 2204 soon, maybe a month, will have an 8mm bearing tube for those type of mounts. Also will have an adaptor that will fit DD props and GWS SF props. |
Omaha Nebraska
Joined Apr 2008
8x4 GWS DD 7.9V 5.3 amps, 11.3 ounce thrust, hardly pushing the motor, but if you want something that flies a 3D 6oz plane with just the amount of thrust needed then this may be a good one. Then again a light 2204 may be the better motor. Ken |
USA, TN, Gallatin
Joined Aug 2009
Oops, I was wrong. No account needed. Order placed.
In other news, I got one of the 10g motors that I ordered for my 20" Sbach and it didn't include the prop saver that was shown in the picture when I ordered it. That makes it useless until I find something that fits. Edit: Had a prop saver that fit but the new motor sucked terribly and got hot within seconds. I believe it is defective. I'm starting to think this little version is not worth the effort but I did shave some weight off of it with the new motor, esc and battery. The flying wieght is now 3.4 oz, down from 3.8. |
USA, TN, Gallatin
Joined Aug 2009
Alrighty! After further consideration, I ordered a 2215-1150 / FM-30 combo for the 34" EPP Sbach. The 2210 is slightly smaller than the 370 I have on it now and although I have no doubts that it's a much stronger motor, I didn't want to fry it with a 10x4.7 prop on 3S.
That should be a good setup. |
USA, TN, Gallatin
Joined Aug 2009
If it's too much, there's always a bigger foamy! 42 inches of depron Sbach would be so much fun!
Oh, update on the 20". A Rimfire 200 did the trick without adding any weight. Flies great but has incredible amounts of torque roll during flight when I goose it. I guess an 8" prop is a bit large for a 20" plane but the little motor handles it well! I ordered some smaller props along with the new motor for the larger plane. Being so much smaller, I need faster reflexes to fly it. It harriers nicely and flies a lot slower now. Very solid. Hovers are tricky with that prop. It's fast too. Full throttle in the yard is not possible. I'm gonna try to get some video of it this evening if the wind settles down.
USA, TN, Gallatin
Joined Aug 2009
Here is video of the 20" Stormbach with a Rimfire 200 and a GWS 5043 prop. I didn't think it would fly worth a darn with such a tiny prop.
http://www.youtube.com/watch?v=kq6BVZC3Cf4 |
It does look fast though. |
USA, TN, Gallatin
Joined Aug 2009
It was a LOT faster with the bigger prop. Like... flappy control surface fast. I like it better like this. That little plane took a lot of trial and error but I think this is a good setup for it. It still needs a tiny bit of right thrust but not as bad as it did with the bigger prop. I've got GWS 6x5 SFs on the way for it.
I've still got one more thing I'd like to try and that is to swap the electronics to the other side so I can put the battery, which is heavier, on the side opposite the torque. I don't know if that will help, but I don't see how it could possibly hurt. |
| Thread Tools | |
| Build Log RCBirdz ( Eagle ) - Build Thread with Free Plans | rcbirdz | Foamies (Scratchbuilt) | 77 | Aug 06, 2012 08:29 PM |
| New Product Pilot RC's SBach 342 30cc!! | Mchone, Jake | Scale Fuel Planes | 28 | Dec 29, 2010 08:28 PM |
| New Product the first 100cc Sbach 342 in the world(pics and video) | pilot-rc | Giant Scale Airplanes | 0 | Sep 18, 2009 06:03 AM |
| Discussion Two Seat Sbach 342 | james-bai | Fuel Plane Talk | 1 | Jul 21, 2009 12:05 AM |
| Discussion Sbach 342 power system? 150grams | BpPilot | Indoor Pattern/F3P | 5 | Apr 11, 2009 08:06 PM |
