Old Jan 22, 2010, 05:20 AM
nitroplanes is offline
Find More Posts by nitroplanes
Joined Jul 2005
AirField RC 70MM F4E Phantom Figher Jet Unboxing Overview
F4 Phantom Figher Jet Unboxing Overview (5 min 32 sec)
http://www.nitroplanes.com/airfield.html
nitroplanes is offline Find More Posts by nitroplanes
Old Jan 26, 2010, 11:55 PM
Joined Jul 2005
F4 Phantom Brushless EDF Jet Maiden Flight
The brand new AirField F-4 Phantom is a high performance RTF brushless motors EDF Jet. High scaled electric ducted fan F-4 Phantom with real scaled fuselage proportion. Able to do aerobatics such as rolling, looping, and inverted flights with ease. The AirField F-4 Phantom comes with front steering landing gear and every flight is an excitement and with excellent speed that tops other EDFs. The F-4 Phantom has a high capacity Lipo Battery that gives you a longer flight time
F4 Phantom Brushless EDF Jet Flight and Review (8 min 50 sec)
http://www.nitroplanes.com/93a04-air...angel-rtf.html
Very high quality molding, lots of detail, good paint, good water transfer decals, clear canopy with cockpit deck, easily removable or replaceable landing gear, full flying stab, easy fan access for maintenance, lots of nice features.
In the air, it's pure dynamite, and very fast. It's a whole level of performance above the rest of the RTF EDF jets...
Roll rate is tremendous, vertical performance is awesome, and downright speed, well...most EDFs, you fly around at full bore all the time, with this one, you want to save full throttle for verticals and high speed passes, and throttle back to half or two thirds to keep the thing manageable the rest of the time, it's mighty quick.
With the landing gear on, off pavement, it has no bad habits at all. The gear comes on and off with a with a built in clip to the main wings.
F4 Phantom Specifications:
Wing Span: 720mm (28.4inches)
Flying Weight: 850g (29.9ounces)
Length: 1100mm (43.3inches)
Transmitter: 4CH
Receiver: 6CH
Servo: 9g X 5
ESC: 45A
Battery: 14.8V/2100MAH/20C Lipo Battery
Old Feb 11, 2010, 01:16 AM
flyandi is offline
Find More Posts by flyandi
United States, CA, Aliso Viejo
Joined Aug 2009
I am debating to get one - however does anyone has already some Flight Experience?
Any chance to get a photo of the actual battery compartment - I wonder if a 4S 3600 will fit?!
flyandi is offline Find More Posts by flyandi
Old Feb 19, 2010, 08:29 PM
TonyTypeS is offline
Find More Posts by TonyTypeS
United States, CA, Hacienda Heights
Joined Jun 2004
A 4s 3600man will not fit. You will have to cut away some foam inside for the battery to fit. The stock 4s 2200mah pack is about 32mm wide and it's a tight sqeeze in the battery compartment
TonyTypeS is offline Find More Posts by TonyTypeS
Discussion Nitro Planes FMS / AirField 70MM F-4 EDF Jet FlyBoyTha1 Foamy EDFs 1619 Jan 15, 2016 10:31 AM
Discussion Nitro Planes New Airfield 70MM F-16 EDF Jet FlyBoyTha1 Foamy EDFs 29 Sep 24, 2010 02:10 AM
Discussion New AirField 70MM F16 EDF Jet RTF nitroplanes Nitro Planes 1 Jan 23, 2010 11:43 AM
