Old Jul 31, 2012, 09:37 PM
SniperWj is offline
Find More Posts by SniperWj
The Sarawak KoloMee
SniperWj's Avatar
Singapore
this hows mine work on my jet
assan gear & door sequencer (0 min 22 sec)
yiming
SniperWj is offline Find More Posts by SniperWj
Old Dec 06, 2012, 12:35 PM
TTRotary is offline
Find More Posts by TTRotary
Rangers Lead the Way
Joined Mar 2010
Who sells these in the USA? Hobbyking is out of stock.
TTRotary is offline Find More Posts by TTRotary
Old Apr 06, 2013, 07:34 AM
beetyii is offline
Find More Posts by beetyii
Make the best of all you have
beetyii's Avatar
Essen/Germany
Joined Dec 2006
Is the CE marking a real one or does it mean "china export"
Rolf
beetyii is offline Find More Posts by beetyii
Old Apr 15, 2013, 12:06 PM
nageotte is offline
Find More Posts by nageotte
I can fix it.
nageotte's Avatar
Cochranton, Pa.
Joined Nov 2005
Where can I find a manual?
nageotte is offline Find More Posts by nageotte
Old May 03, 2013, 08:25 PM
beetyii is offline
beetyii's Avatar
Essen/Germany
Joined Dec 2006
Got my sequencer today and after adjusting everything works, but the door servos are jittering in both end positions.
Any ideas ?
Rolf
Old May 14, 2013, 01:17 AM
ASSAN is offline
Find More Posts by ASSAN
CHINA
Joined Apr 2005
Any ideas ?
Rolf
both side can be set. you need narrow your scope,like from +-100 to +-70 etc.
ASSAN is offline Find More Posts by ASSAN
Old Jun 27, 2013, 04:08 PM
RPASCHOAL is offline
Find More Posts by RPASCHOAL
Joined Aug 2011
Meng , i need to buy some of those sequencers ... where can I find it ?? HK is backordered forever !!
RPASCHOAL is offline Find More Posts by RPASCHOAL
Old Jun 27, 2013, 10:48 PM
ASSAN is offline
CHINA
Joined Apr 2005
sorry, we have some late.
but there will have more stock next week, we will ship them hundreds next week's early.
i am sorry for your trouble.
meng
Old Sep 06, 2013, 05:34 PM
esulit is offline
Find More Posts by esulit
esulit's Avatar
Philippines, NCR, Taguig
Joined Nov 2011
Hello Meng,
I am testing the sequencer now. I am using futaba 14 sg with R6106HFC Rx I have my power on channel 3 and I have the sequencer on ch 5. I connected 2 servos 1 on door and 1 on gear. I tried to arm it by switching 3x but it doesn't work. Any ideas on how to fix this?
I actually bought 3 of them but I cannot get any to work.
Regards,
Eric
esulit is offline Find More Posts by esulit
Old Sep 07, 2013, 06:44 AM
nageotte is offline
I can fix it.
nageotte's Avatar
Cochranton, Pa.
Joined Nov 2005
Do the digits on the sequencer light up?
Old Sep 07, 2013, 08:23 AM
esulit is offline
esulit's Avatar
Joined Nov 2011
Yes it is flashing. But I couldn't get it to arm even when I flick the switch back and forth 3x. Sorry I forgot to mention that.
E
Old Sep 07, 2013, 09:34 AM
nageotte is offline
I can fix it.
nageotte's Avatar
Cochranton, Pa.
Joined Nov 2005
I had trouble with mine but it all boiled down to a failure on my part to read every word in the instructions. Then I was able to program to meet my every need. So... we will check every item off as we go. Have you read the instructions in detail?
Old Sep 07, 2013, 04:33 PM
esulit is offline
esulit's Avatar
Joined Nov 2011
Yes and its a challenge to read. So let me go through it again.
Old Sep 12, 2013, 10:18 PM
ASSAN is offline
CHINA
Joined Apr 2005
you mentioned you use CH5 as a swtich. you need on/off ch5 three times quick after power on Tx/Rx.it's will make your gear alive.
yours,
meng
Old Sep 13, 2013, 06:01 AM
nageotte is offline
I can fix it.
nageotte's Avatar
Cochranton, Pa.
Joined Nov 2005
put a servo directly on channel 5 and make sure the gear switch is indeed on that channel. That you can run that servo with the switch you are using.
Video RCBee gear door sequencer test run ralf dvorak Electric Plane Talk 0 Dec 14, 2009 03:58 PM
For Sale BN UP3 Retract Valve with Gear Sequencer jetfan20 Aircraft - Fuel - Jets (FS/W) 1 Nov 09, 2009 05:18 AM
Question Door sequencer Daryl Wallis57 Scale Sailplanes 2 May 16, 2008 06:47 PM
For Sale EMS Gear Door Sequencer New In Packaged Tumbler Aircraft - General - Radio Equipment (FS/W) 0 Sep 25, 2006 11:24 AM
