Old Jan 22, 2010, 03:01 AM
ASSAN is offline
Find More Posts by ASSAN
CHINA
Joined Apr 2005
Gear and Door Sequencer
hi, guys,
here is our new developed Gear and Door Sequencer.which can be used in any type air model.
hope you like this. thanks.
meng
www.assan.cn
ASSAN is offline Find More Posts by ASSAN
Old Feb 24, 2010, 10:46 AM
zikkmu is offline
Find More Posts by zikkmu
France, Aquitaine, Mont-de-Marsan
Joined Aug 2008
Great! But I can't find it on www.assan.cn
Where can it be bought?
zikkmu is offline Find More Posts by zikkmu
Old Feb 28, 2010, 02:44 PM
Rocketman1092 is online now
Find More Posts by Rocketman1092
Purdue Engineering
Rocketman1092's Avatar
United States, CA, San Diego
Joined Jan 2005
Yes, please give us an update regarding availability and cost!
Rocketman1092 is online now Find More Posts by Rocketman1092
Old Mar 02, 2010, 01:36 AM
jcstalls is online now
Find More Posts by jcstalls
Dragons, WindMills, all Same
jcstalls's Avatar
United States, IN, Indianapolis
Joined May 2002
Hi,
Perhaps having a PDF would work far better, as many do not use MS products. Plus, it is just so much of a nicer and pro way/form to illustrate your/this item.
Looking forward to this and the comment made by brother rocketman1092
thanks,
Jared
jcstalls is online now Find More Posts by jcstalls
Old Mar 04, 2010, 09:37 PM
ASSAN is offline
CHINA
Joined Apr 2005
sorry.
our website is not update recently, we are waitting for a new web master come and treat this.
for PDF manual,i will updte soon.
yours,
meng
Old Nov 28, 2011, 03:14 PM
asdfqwert is offline
Find More Posts by asdfqwert
Joined Feb 2010
Problem with doof sequencer
Hello,
Just Received the sequencer. Unfortunately i am Not able to Switch to Running Mode. I am using a futaba t8fg transmitter and an orange rx Receiver.
Nothing happens when i switch the gear switch 3 times quickly.
thanks for help in advance
asdfqwert is offline Find More Posts by asdfqwert
Old Dec 01, 2011, 09:41 PM
ASSAN is offline
CHINA
Joined Apr 2005
Originally Posted by asdfqwert View Post
Hello,
hi,i got your PM.
please try to set your three position switchs with one below -25%,middle at zero,the third more than +25%.
meng
Old Dec 24, 2011, 08:21 AM
douglask is offline
Find More Posts by douglask
Joined Mar 2006
Hello friends,
I canīt turn to running mode, i've a futaba 7cap.
I switch the gear switch 3 times quickly, but nothing happens.
douglask is offline Find More Posts by douglask
Old Jan 24, 2012, 05:46 AM
Emile is offline
Find More Posts by Emile
Emile's Avatar
The Netherlands, LI, Venray
Joined Mar 2003
Hi,
I just ordered one for my JetTeng L39.
I seems this is just what i was looking for.
Grtz,
Emile
Emile is offline Find More Posts by Emile
Old Mar 04, 2012, 09:36 PM
fabiofleal is offline
Find More Posts by fabiofleal
Airliners lover
fabiofleal's Avatar
Brazil
Joined May 2006
Airliners
Can I use this product to sequence the Main LG doors on an Airbus A330, like this:
State 1 - Gear up, door closed
State 2 - Gear up, door open
State 3 - Gear down, door open
State 4 - Gear down, door closed
Is it possible with this product ?
Thanks.
fabiofleal is offline Find More Posts by fabiofleal
Old Mar 05, 2012, 03:22 AM
ASSAN is offline
CHINA
Joined Apr 2005
Thanks.
hi,
i am not 100% sure it's worked as your described, this item controlled by a swtich, one switch with two position,which means two working mode.
if it's setted at F2, swtich ON,you will got like your wanted stage3 and 4 together, Door opend first,then Gear Down,then Door closed. when swtich turns OFF position, you will got stage1 and 2 together, Door open firs,then Gear up,then Door closed.
yours,
meng
Old Mar 06, 2012, 05:46 PM
Airliners lover
fabiofleal's Avatar
Brazil
Joined May 2006
Tks
Tks for your answer.
yeah, I read the manual more carefuly later on and understand that what Iīm looking for is covered by the mode 2 as decribed in the pdf. Bought my sequencer yesterday and hope to be able to soon install it on my Airbus A330-200.
Old Mar 07, 2012, 02:03 AM
ASSAN is offline
CHINA
Joined Apr 2005
The manual here is different from the packing current paper.
meng
Old Mar 14, 2012, 04:27 PM
TISTA is offline
Find More Posts by TISTA
Germany, NDS, Bardowick
Joined Mar 2011
Hello Meng,
today i got my Assan Door sequencer and just tested it.
i works great, but the only problem i have is when switching the receiver on.
After three times switching the control chanel and put the control switch in the "gear down"-position, the Gear still goes up, doors close, doors open and then the gear goes down in the right position.
this isnīt so great while the planes stands on the ground when switching on.
Is it possible to solve this problem, or do i have to raise the 15kg P-51 up every time i switch it on?
greetings from Germany,
Timo
TISTA is offline Find More Posts by TISTA
Old Mar 15, 2012, 04:42 PM
hussey56 is offline
Find More Posts by hussey56
Joined Oct 2011
Assan gear and door sequencer
Hi Meng,
I am unable to change to Mode 2... The instructions do not explain how to change from Mode i to Mode 2. I would appreciate any help. Thank you in advance.
Eric.
hussey56 is offline Find More Posts by hussey56
Video RCBee gear door sequencer test run ralf dvorak Electric Plane Talk 0 Dec 14, 2009 03:58 PM
For Sale BN UP3 Retract Valve with Gear Sequencer jetfan20 Aircraft - Fuel - Jets (FS/W) 1 Nov 09, 2009 05:18 AM
Question Door sequencer Daryl Wallis57 Scale Sailplanes 2 May 16, 2008 06:47 PM
For Sale EMS Gear Door Sequencer New In Packaged Tumbler Aircraft - General - Radio Equipment (FS/W) 0 Sep 25, 2006 11:24 AM
