View Poll Results: What is the best lipo setup for a 70z or less (AUW) park flyer?
180 mah (15 grams) 0 0%
350 mah (20 grams) 4 100.00%
500-600 mah (30-35 grams) 0 0%
Voters: 4. You may not vote on this poll
Old Jan 22, 2010, 02:31 AM
m25 is offline
m25
Find More Posts by m25
m25
m25's Avatar
Joined Oct 2009
Poll
What is the best (2s) LiPo pack for a 7oz slow flyer?
I was thinking about a 23" depron bipe (roughly 1300 sq cm/ 200 sq in wing area) but have to get ready with the electrics first. What is the best capacity for one that weights roughly 7oz (200g) or less? The main, rough options I can think of are 180mah, 350 mah and 500-600mah but chosing one before flying/building is not so easy. I already have a couple of 610 mah rhino but isn't 35 grams too much?!
m25 is offline Find More Posts by m25
Old Jan 22, 2010, 12:28 PM
m25 is offline
m25
m25
m25's Avatar
Joined Oct 2009
Nobody has something to say on this ...
Old Jan 22, 2010, 12:32 PM
Xpress.. is offline
Find More Posts by Xpress..
Team Hitec, Customer Support
Xpress..'s Avatar
United States, CA, Poway
Joined Oct 2007
Thunder Power 325mah 2s 45C.
Xpress.. is offline Find More Posts by Xpress..
Old Jan 22, 2010, 02:22 PM
Butch777 is offline
Find More Posts by Butch777
Livermore, CA
Joined Sep 2004
Its really not that simple.
Build the airframe, add the servos and weigh it.
Then see what motor/prop will supply the wanted power level.
Next decide on the flight duration wanted.
The motor, with a certain size prop, will draw a certain amount of amps and will need a certain size batter to make it fly for the desired time.
Butch777 is offline Find More Posts by Butch777
Old Jan 22, 2010, 02:59 PM
rafe_b is offline
Find More Posts by rafe_b
Joined Jan 2009
Yeah, what Butch said. Your question is a bit vague. But offhand, for a 7 oz. plane, a 2S battery in the 350-500 mAh range sounds about right. Once you know the motor current you expect to draw, you can easily figure out the minimum C rating for the battery as well.
rafe_b is offline Find More Posts by rafe_b
Old Jan 22, 2010, 04:23 PM
m25 is offline
m25
m25
m25's Avatar
Joined Oct 2009
The reason I put the 7 oz limit is that I have all the other stuff already, I weighted all the raw materials: amount of depron needed (probably some extra), fiberglass, 20g 2300 kv motor motor, receiver, wheels, 2 9g servos, 10amp esc, propeller and all the rest (except battery) weights 155g (5.5 oz). I calculated the thrust of this motor with a 6x3 gws prop to 290 grams with 6.5 amps @ full throttle but half of it ( about 100 grams) or even less will be sufficient to fly around.
If I use the 610 mah rhinos I have the calculator gives me more than 20 min of flight with half throttle and this battery weights 35 grams (total should come around 190 g.
I know I could better use a 10 gram motor and 4 gram servos for my needs, to bring down the weight, but I already have this stuff and was wondering it the 610 mah lipos fitted with all the rest or I needed something else.
Discussion What Is The Best Lipo Pack You Own? LipoMythBuster Batteries and Chargers 19 Dec 29, 2009 08:52 PM
Alert best inexpensive 2s lipo for slash??? jettrooper02 Electric Power Cars 5 Nov 27, 2009 02:26 AM
Discussion What's the best OUTRUNNER for 2S Gaui 100 robinflyer Micro Helis 2 Oct 25, 2009 02:34 PM
Yippee! What's the best lipo setup for MPJET blue Outrunner ? 2s or 3s ? kookboy Power Systems 1 Mar 31, 2005 11:49 PM
Best Non-Lipo Pack for Slow Stick or e-Starter rutat Batteries and Chargers 5 Jun 19, 2004 01:49 AM
