Old Jan 21, 2010, 06:39 PM
TorkRollN is offline
Find More Posts by TorkRollN
United States, AZ, Phoenix
Joined Oct 2001
GPS not recognized
I just got a GPS xpander V3.
I have tried installing it, as per instructions, but my computer screen displays:
GPS expander not detected.
I have checked the wiring for correct polarity numerous times and have restarted both the computer and the FDR with no luck.
Any suggestions before I have to send it back?
Barry
TorkRollN is offline Find More Posts by TorkRollN
Old Jan 22, 2010, 01:12 AM
billpa is offline
Find More Posts by billpa
billpa's Avatar
Joined Nov 2003
Hi Barry,
Sorry to hear about the problem. Could you post a photo of your connections? I don't think that's the issue either, but it may give some clues.
Also, I'm assuming you are seeing the message after starting live mode, and that other parameters on the screen are changing, indicating live mode is running?
Regards,
Bill, for Eagle Tree
billpa is offline Find More Posts by billpa
Site Sponsor
Old Jan 23, 2010, 11:38 AM
zvikaf is offline
Find More Posts by zvikaf
Joined Apr 2008
i'm also having "GPS expander not detected"
it used to work with earlier Soft/Firmware.
I've tried also 8.05 beta with the same results.
tried the extended antenna waited a long time, tried reseting the system for a minute - none made any changes.
It seems that the GPS board does not heat at all.
Regards
Zvika
zvikaf is offline Find More Posts by zvikaf
Old Jan 25, 2010, 09:35 PM
billpa is offline
billpa's Avatar
Joined Nov 2003
Hi Zvika,
The problem you are seeing would not be related to software or firmware version. Can you give more details about when the "GPS expander not detected" message is appearing? In live mode?
Regards,
Site Sponsor
Old Jan 30, 2010, 02:40 PM
misfire is offline
Find More Posts by misfire
Joined Aug 2007
"Log GPS Parameters" not available
My GPS issue (I believe it's a 5Hz V3) is similar but different. My OSD recognizes and displays the GPS data no problem. In fact, the PC application will display GPS data fine in live mode. But under "Choose Parameters to Log in Recorder", the check box for "All GPS Parameters" is not available - "grayed out" I think they call it, can't be checked.
My GPS is directly connected to the e-Logger on the GPS pins. Any theories?
misfire is offline Find More Posts by misfire
Old Jan 31, 2010, 02:59 PM
pda75 is offline
Find More Posts by pda75
any calculation so far ?
pda75's Avatar
France
Joined May 2008
what is the power supply you're using ?
if it's over 5S, it is likely that you need an additionnal 5,2 V power supply
Cheers
Pierre
pda75 is offline Find More Posts by pda75
Old Feb 01, 2010, 06:37 AM
misfire is offline
Joined Aug 2007
Cheers
Pierre
Thanks for the feedback, Pierre, but no, it's a 3S setup. And when I'm on the computer trying to straighten out the logging, it's usually powered off of the USB port, whatever voltage that puts out.
It's strange, though. I can run Live Mode on the PC or watch it on the OSD display, and all the gps data is right there. But when I go into "Hardware - Parameters to Log", it's always "ghosted", as if there's no GPS Expander to select.
Old Feb 05, 2010, 07:45 PM
billpa is offline
billpa's Avatar
Joined Nov 2003
Misfire, I think this issue turned out to be the Spektrum setting being turned on? Or, I may be confusing this issue with another.
Regards,
Site Sponsor
Old Feb 10, 2010, 03:30 AM
zvikaf is offline
Joined Apr 2008
Regards,
I had the spectrum bit turned on, but still need to unhook and hook again the gps in order to "wake up"
Old Feb 10, 2010, 03:27 PM
billpa is offline
billpa's Avatar
Joined Nov 2003
Hi zvikaf, That's good news. Yes, for the GPS to work again after the Spektrum feature is turned off, power needs to be removed from, and reapplied to, the Eagle Tree components so that they will reboot.
Site Sponsor
Help! e-logger V1 "USB Device Not Recognized" Kadath Eagle Tree Systems 10 Oct 11, 2008 09:43 AM
Discussion 5Hz GPS not Detected jgproponet Eagle Tree Systems 6 Aug 04, 2008 02:45 PM
Question Phoenix 45HV not recognized by Castle Link Xnaron Castle Creations 2 Aug 05, 2006 10:40 AM
ESC not recognized by Phx-link Earthbound Castle Creations 1 Sep 05, 2004 02:07 AM
