Hi Gordon
Admirable project. Try these sites: MH site - more than just aerofoils: http://beadec1.ea.bs.dlr.de/airfoils/mhfoils.htm Selig site - more 'foils than you'll ever want: http://www.uiuc.edu/ph/www/m-selig/a..._database.html and if this site doesn't work, try this: http://amber.aae.uiuc.edu/~m-selig/a..._database.html Incomplete guide to Aerofoil useage - list of 2000-odd planes and their aerofoils: http://amber.aae.uiuc.edu/~m-selig/ads/aircraft.html Cheers Gordon W |
Tucson, AZ, USA
Joined Nov 2000
Hi Gordan - Probably around 8~9 pounds fully batteryed. My Demon used Robart 15 retracts with the 1/8 gear legs with no problems. I don't see why Sprinair with aluminum frame can't match Robart plastic.
Not a short wire lead plane. Two feet from rear of fans to center of missile bay/battery box, three feet to the canopy/receiver. As the fans move forward your main gear will start to interfear and worst of all the inlets become really contorted as they move inboard and up. The inlets on this plane are not fun items. Essentialy, at this scale, the wing profile is the equivalent to a quarter inch flat plate with funky twist and camber in funny spots. I don't care about being scale in this area. I do care about the large amount of taper and the possibility of tip stall. Please ask your father about the A/F-2 "Thunderchief II" as published in the Jan 1994 Issue of IEEE AES Systems magazine. This is essentialy a single engine F-23 that the artical authors said that they wished had never been published (I called Northrop and spoke to B Bartels, one of the co-authors). He said that it went futher than just the artical (there is speculation that one crashed in Britan). I would like more info (a 3-view with sections would be nice) so that I could model this aircraft. |
Hello Gordon,
Well ,,, Yes someone has done this plane and a big one at that. Twin fans and she weighs in at 20 pounds dry. I belive this one was made from glass and carbon fiber. It hangs in our shop as this one was made by my employer and he also worked on the real ones at northrope. He goes by the name Glasairallen here on the zone. He dug out the the molds on friday and is planing to make short kits I belive. If you would like I can get him to post more pictures of it and you can pick his brain for info. You can contact him through my work at http://www.rdtechservices.com |
MicroRotors- yes I would be very interested in seeing and hearing more details. Did the big monster fly?? Thanks for the info and link. Gordon |
YF-23 Black Widdow
Hello, I'm the nut that built that huge (1/10th Scale) ducted fan YF-23. While at Northrop I worked on many wind tunnel models of the YF-23 at various scales (1/20th thru 1/8th) as well as a full scale RCS (Radar Cross Section) model.
For those that are curious about the airfoil used on the 23, forget it! It's not relevant at this scale. The actual airfoil that was used is abaout 8"-9" thick at the thickest point at the root. So for a 1/12th scale model that would mean that the wing would be about 5/8" thick at it's thickest point... this simply won't work at this scale (unless you can modify the laws or physics or otherwise tweak the Reynolds numbers of the flight envelope of your model). Keep in mind that full scale wings for supersonic fighters are designed to operate in a very different environment than our models ... the rules are not the same. The thickest point on my 1/10th scale ATF wing is about 2 1/2" thick instead of the .800" it "should" be. For those that want a great education in model aircraft aerodynamics (and aerodynamics in general) I suggest Martin Simons' book which you can get at Amazon.com by following this link. http://www.amazon.com/exec/obidos/AS...536826-9250503 On another note I am currently working on CAD drawings for 2 more YF-23, these two are for EDF: First model will be a tiny little thing for tiny 44mm (KP Aero Models) fans will have a wingspan of 13.92" and a length of 21.80" The second model is for 3" fans (WeMo) and will have a wingspan of 23.02" and length of 36.12" |
The Northrop B-2 is quoted as a "modified upercritical" section whatever that is, but no doubt the F-111 sections would do. No doubt the site owner can explain what a supercritical section is - it's probably a modified NACA 6-figure profile. You can plot any of these sections as well as designing the whole wing, including structure or foam-cutting templates, using Compufoil, which has a NACA aerofoil generator built-in. A friend of mine who's designed many GDFs, some of which have been kitted, always uses an 8-10% thick NACA 6-figure 64A0xx section, even on things like the MiG 15, and the models do have very good handling. Cheers Gordon W |
Hey GlasairAllen, there was a company in California I think back in the early 90s that offered various sizes of kits for the YF-23 and YF-22, I think in glass and foam form. Did you know those guys? I remember seeing the adds in Model Airplane News for about two years or so then they disappeared. I never did send off for any info. I'd have to dig out my old MAN issues from that time period. I think the company may have been called Starjet?
Yeah, glass kits for EDFs would be cool. |
Ed, I remember George Miller making a YF-22, but I am not aware of anyone making a YF-23. I remember George and myself eyeing each other's planes at the Arizona Jet Rally back in 1991. I'm pretty sure that there has never been a commercially available kit of the 23 ... I could be wrong, but I've never seen it. |
GlasairAllen-Sounds like you are really ahead of the game on this one. I would definitely be in line for a YF-23 if it was scaled for Midi Fans.
Currently I have a Viewpoint data model of the YF-23 that I have been converting from polygons to nurb surfaces so I can get it into Solidworks CAD. I really wanted to get everything in the computer so I could create all the ducts and parts once with out the trial fit and change design philosophy. A vendor owes me some time on a 3 axis router to cut some rim shape foam plugs. Can you give us an idea of how the YF-23 flight characteristics are? ![]() Gordon |
| Thread Tools | |
| The Start of my YF-23 Black Widow II Project | RCWorks | Foamies (Kits) | 39 | Jul 14, 2009 07:24 PM |
| Discussion Foamie Yf-23 Black Widdow II | corsair nut | Foamy EDFs | 36 | Oct 29, 2006 12:42 PM |
| Discussion YF 23 Black Widow | Eaglehawk752 | Pusher Prop Jet Models | 2 | Sep 28, 2006 01:50 AM |
| Discussion Foamie Yf-23 Black Widdow II | corsair nut | Pusher Prop Jet Models | 6 | Sep 25, 2006 09:35 PM |
| Northrop/McDonnell Douglas YF-23 Black Widow II | Esprit440 | Pusher Prop Jet Models | 12 | Jul 31, 2006 12:47 AM |
