Old Feb 15, 2010, 08:29 PM
JRCoca is offline
Find More Posts by JRCoca
WarDog
JRCoca's Avatar
Nor Cal
Joined Jan 2010
P
Wish I could have seen mine fly, was so looking forward to seeing all the power i put into my setup,
Let us know who it goes for you
j
JRCoca is offline Find More Posts by JRCoca
Old Feb 15, 2010, 09:19 PM
mavdriver is offline
Find More Posts by mavdriver
mavdriver's Avatar
United States, CA, Apple Valley
Joined May 2002
So far the gear seems to be holding up , have a total of 4 flights two on the blue angel F18 , and two on the tiger F18 , again i`m the pilot of both aircraft not the owner , both of my friends Al and Chuck bought this at the same time AMA Show here in SO CAL. this guys have little experience with jets , I`ve flying ducted fan jets since the early 80s , therefore I was chosen to fly both aircraft lucky me , will be flying again this weekend , hopefully some more pics and video . Ed
mavdriver is offline Find More Posts by mavdriver
Old Feb 17, 2010, 04:11 PM
JRCoca is offline
WarDog
JRCoca's Avatar
Nor Cal
Joined Jan 2010
Flying day, was really looking forward to this maiden flight. Here is the damage, pretty bad for never getting off the ground.....
Old Feb 17, 2010, 04:44 PM
Jagzilla is offline
Find More Posts by Jagzilla
I fly for Beer
Jagzilla's Avatar
Chilliwack, B.C. Canada
Joined Sep 2004
It looks very fixable to me
Jag
Jagzilla is offline Find More Posts by Jagzilla
Old Feb 17, 2010, 04:52 PM
pulsery2k1 is offline
Find More Posts by pulsery2k1
6 months to finish a rtf
pulsery2k1's Avatar
upstate ny
Joined Jun 2003
Landing gear fix
I 'm getting ready to build my F-18 I got the last part the speed control,
and was getting ready to test the fan, I was looking at stock gear
and looking throught my retracts box I have a Hobbycity pair that
look like the banana hobby f-18 mains - and guess what they are
only they work 100 times better they are exactly the same but
you can see the hobby city one are made of a diffrent material
and are much stronger - made from the same molds?? the hobby city
ones use larger screws to hold it together but these have no slop
and you get a very positive lock up and down.
well that will take care of mains,
how the nose retract is the same so if you buy 2 sets you can make
a good set with positive lock up and down
link:http://www.hobbyking.com/hobbycity/s...0mm_long_(PAIR)
from the coustom comments :These retracts work flawlessly, the wire truly is 3.5mm but when you bend it i would recommend to heat the wire first because it is a blit brittle. They are "Reversible" so you can disasseble them and change the way on the controlwire, that means you can still have one servo in the middle and have the retracts retract either inwards or outwards.
pulsery2k1 is offline Find More Posts by pulsery2k1
Old Feb 17, 2010, 04:56 PM
j3tman is offline
Find More Posts by j3tman
Were..is..my..Super..Suit ..
j3tman's Avatar
United States, NE, Papillion
Joined Sep 2009
kind of stinks about the crash but i agree if you take your time its possible to fix it up
good luck with the rebuild
j3tman is offline Find More Posts by j3tman
Old Feb 17, 2010, 05:08 PM
pulsery2k1's Avatar
upstate ny
Joined Jun 2003
fan test
just ran my fan test
set up:
Hayoye 89mm turning 7 blade fan
1600 kv 37mm outrunner with internal fan
100 amp auto timming esc
zippy lightmax 6 cell 30 c 5000 pilo
results:
62-65 amps 13550- 1290 watts
1940-1860 grams thrust
now to mount in airframe and repeat the test
Old Feb 17, 2010, 05:35 PM
JRCoca is offline
WarDog
JRCoca's Avatar
Nor Cal
Joined Jan 2010
Missing / folded peices leave good size holes in the side of the fuse, gonna look at patching those with some spare foam or even expanding foam.
It took three days to stomach looking at this...... I dont mind crashing them, Its actually kinda fun sometimes, and trust me , I have. But when a silly failure causes a brand new pane this much damage, it just kicks my motivation button right in the #####...
Will try to do some work this evening, will keep you all posted......
Old Feb 17, 2010, 07:17 PM
pulsery2k1's Avatar
upstate ny
Joined Jun 2003
landing gear fix?
I decided to play with these and was able to make a a very good
set using part from both the hobby city and banana hobby gear
by using the center piece (with gear leg) from the banana hobby
set and the case and pusher plunger I was able to make a very
good set ,no play- slop positive lock up and down , I supect that
banana hobby said they up graded the retracts - but finished using
the version 1 till they ran out???. now I bought the after market
electric gear - but these now feel so good I thinking of using them.
JRCoca I can see how your accident happened , I noticed they have
2 set screw holes on both the upper and lower nose gear, on the
conecting shaft they only use 1 flat and 1 set screw??? I took it all
apart and put 2 more flats and set screws with a little green locktite
I also drilled and taped a second set screw at the top of gear
were it connects to retract unit . I also removed the little space
gear feels much better and hopefully will have fixed the problems
we are seeing
Old Feb 17, 2010, 08:59 PM
JRCoca is offline
WarDog
JRCoca's Avatar
Nor Cal
Joined Jan 2010
Pulse
Nice info, one thing is for sure, the grey is a soft material. I have to admit, I did tighten the set screw during the build, should have checked it again during flight checks.
Found these struts, thinking about them for next attemped
check them out http://www.proedf.com/index.php?p=6&...cat0=7&lang=en
Old Feb 17, 2010, 11:43 PM
shakaka is offline
Find More Posts by shakaka
Joined Jan 2010
jagzilla I noticed ur in chilliwack. I am out in agassiz But just fly in the fields out here.
Do you have one of these v2's I might pick one up.
Stumpy are you going to repair it? just glue it back together with foam etc and maybe glass it?
shakaka is offline Find More Posts by shakaka
Old Feb 18, 2010, 06:16 AM
Jagzilla is offline
I fly for Beer
Jagzilla's Avatar
Joined Sep 2004
Shakaka, yeah I'm just down the road from you. I fly from the FVRCF field, down near the river. I recently ordered this one as the bare airframe. I expected a V2, but received a V1 version. I am now modding it for strength and working rudders as I build it.
Jag
Old Feb 18, 2010, 05:39 PM
Steam28 is offline
Find More Posts by Steam28
Steam28's Avatar
United States, OH, Strongsville
Joined Feb 2009
Jagzilla,
I am surprised you received a V1; I thought they were all sold out of V1 ARFs many months ago. You should say something if you didnít start building the model. By the way, I was asking Hobby Lobby about any new 90mm jets on the horizon and they plan to make a major announcement next week on the release of a new 90mm jet.
Thanks.
Steam28 is offline Find More Posts by Steam28
Old Feb 18, 2010, 07:06 PM
RavenTengu is offline
Find More Posts by RavenTengu
RavenTengu's Avatar
Michigan, USA
Joined Dec 2009
Has anyone measured the stock setup for thrust and power? Just wondering how much better it would be to do some mods..
My gear setup is weak also... left servo just died after about 6 cycles. Others and ok so far but do not lock down (or up) well.
RavenTengu is offline Find More Posts by RavenTengu
Old Feb 18, 2010, 07:08 PM
tailskid2 is offline
Find More Posts by tailskid2
tailskid2's Avatar
USA, AZ, Phoenix
Joined May 2003
Same problem with my son's birdS - yes he has two of them
tailskid2 is offline Find More Posts by tailskid2
Latest blog entry: VQ 112" Beaver
Sold new retracts for banana hobby 90mm F/A-18...complete set java8297 Aircraft - Electric - Jets (FS/W) 1 Mar 05, 2010 12:34 AM
Sold Starmax F-18 90mm V2 jetjocchris Aircraft - Electric - Jets (FS/W) 9 Feb 16, 2010 05:22 PM
Question The new F-18 from banana hobby j3tman Foamy EDFs 3 Jan 21, 2010 07:31 PM
Discussion f-18 90mm blitz rc works edf jet by banana hobby hixallstar18 Foamy EDFs 3 Nov 29, 2009 02:20 PM
