Started work on attaching the pods to the hull. I'm using some bearings from VXB ball bearings who actually sell small enough bearings for the pods (5mm inner x 2.5mm wide). To get full 360 (or really only 180) degree turning for the pods I'm using a geared steering system (using some gears I found in a VCR which someone threw away
recycle!).Perhaps at this point I should explain that i am not planning to use any conventional remote control systems. Instead I have decided to use PIC micro-controllers (or about 7 of them) to control and automate all of the ship's hardware and lighting systems. Then, using a digital radio link I will be able to send instructions (or direct commands) to the ship from a separate board of switches or maybe even a computer (when I learn enough programming... hopefully...) This method has been used a lot by people working with remote controlled robots, and although I've never worked with robotics, I don't see why I cant do a similar thing for a ship.I am, however, treading mostly into uncharted territory and I doubt that it will be a smooth build. I may resort to a conventional RC system if all else fails. As the wise man said "hope for the best and prepare for the worst"
Engine test complete!
I am very impressed by the acceleration that I get from these motors! I have no idea how fast it can actually go because it only gets about 50cm of room in the bath. Also as the hull is still in two halves, and held together with tape and rubber bands I only got about 20 seconds before it started flooding (so not really much of a float test! ) However, in calm weather, I may be able to sail it outdoors as well.I have uploaded a video at http://www.rcgroups.com/forums/showthread.php?t=1180889 |
| Thread Tools | |
| Discussion On the Queen Mary | toesup | Dock Talk | 9 | Sep 21, 2009 10:01 PM |
| Discussion Question about Revell Germany's 1:400 Queen Mary 2 | tugboater | Scale Boats | 3 | Nov 12, 2008 02:41 PM |
| Question Queen Mary 2 1:400 scale R/C conversion | stevedurrant | Scale Boats | 71 | May 12, 2008 04:50 AM |
| Discussion Queen Mary Meets Queen Mary!!!!!! | greenseaships | Scale Boats | 38 | Sep 01, 2007 08:15 AM |
| Question Queen Mary 2 1:400 scale R/C conversion | stevedurrant | Dock Talk | 2 | Jan 02, 2005 09:01 PM |
