Old Jan 20, 2010, 05:32 PM
srnet is online now
Find More Posts by srnet
Stuart
srnet's Avatar
UK, Cardiff
Joined Dec 2008
Instructions ?
I have bought a BAC LMA 004 and a BAC ESJ.
What do the various beeps and flashes mean, there was no instructions ?
I cant get the LMA to work on my Corona RP4S1 RX. This is my prefered RX since its a synthesised RX, no crystals required. Once the RX has locked to the TX, it continues to send out pulses when the TX goes down, I presume its in fail safe mode although I thought only the 6 and 8 channel versions did that.
So how do I make the LMA work with this RX ?
srnet is online now Find More Posts by srnet
Old Jan 30, 2010, 08:26 AM
PLD is offline
PLD
Find More Posts by PLD
PLD
Magicsmoke maker
PLD's Avatar
Australia, QLD, Charters Towers
Joined Dec 2003
Hi there srnet,
Sorry I didn't see this post here.
The initial two start beeps are just initialization.
After that, the LED blinks out the voltage periodically, eg, 7.4V shows up as 7 long blinks + 4 short blinks followed by a larger pause.
Are you able to get the LMA aspect to trigger normally by the transmitter (eg, if you're on the throttle channel and change the stick to the opposite extreme)?
The LMA portion triggers on pulses of 1.3mS or less (including no pulses).
The RP4S1 I think /holds/ the last known good pulse when it loses signal (as apposed to going to an explicit failsafe location).
Paul.
PLD is offline Find More Posts by PLD
PLD is offline
PLD
PLD
Magicsmoke maker
PLD's Avatar
Joined Dec 2003
Hi there srnet,
Paul.
Old Jan 30, 2010, 10:21 AM
srnet is online now
Stuart
srnet's Avatar
UK, Cardiff
Joined Dec 2008
Thanks for the info.
Yep, just checked, the RX does go into hold mode.
In which case you need the TX on and hold the stick, or switch so that you get a pulse of less than 1.3ms, and that does work.
Shame the TX does not have a link you can cut, if you wanted to turn of hold mode.
Old Jan 30, 2010, 07:00 PM
PLD is offline
PLD
PLD
Magicsmoke maker
PLD's Avatar
Joined Dec 2003
Unfortunately that 'hold mode' is something integrated into the firmware on the receiver. Only way to get rid of it would be to reprogram it.
Paul.
PLD is offline
PLD
PLD
Magicsmoke maker
PLD's Avatar
Joined Dec 2003
Paul.
Discussion Flamingo 2006 Electro (Graupner/Tangent) instructions manual Nachobud Electric Sailplanes 6 Jan 25, 2010 01:06 PM
Help! Need instructions kevrock The Builders Workshop 2 Jan 20, 2010 08:11 PM
Discussion Where can I get instructions for a Flyermate 80 ESC? Tumbler Large Electric Helis 2 Jan 14, 2010 01:56 PM
Discussion Instructions maghse Coaxial Helicopters 3 Jan 13, 2010 06:34 PM
Discussion Flying truck Instructions? giveitstick Foamies (Kits) 0 Jan 13, 2010 12:51 PM
