Lamedico:
what I did was put the cheap training gear you can get (with the orange balls) on and popped it up into a hover. I took the time to make sure the swash was level, blades were tracking as good as they can get, and the prop/gain on the 4-in-1 was set. First hover I trimmed it out. I would check out Nuttcaze's video on setup for the HBFP http://www.myrcguides.com/HBFPV2.html I had been flying the mSR quite a bit and did a few minutes of hovering with my father's Blade 400 (with training gear) before I flew my HBFP - so I knew I could pop it up and control it somewhat. On to the diary 1/20/2010 - Evening Winds were calm here around 4 pm CST. I took the HBFP and the SA out in the front yard for some flying. Carnage! I was flying the HBFP way beyond my abilities..trying FF, banked coordinated turns, etc. Ended up having to chop the throttle or hit my roof - the crash from about 30' up split the frame in half! New frame ordered and on the way. I should have took this as a sign, but did not. Pack 1 on the SA was 7 minutes of tail in hovering and scooting around. I'm sliding left and right to give myself some pre-side in orientation training. I also did some very high hovering. I'm typically around head level. This pack I did some pumps up to 2-3 stories high and held the hover up there. It's quite a bit different, but manageable. Pack 2. It's darker now and without the help of the street lights, I can't see. I had forgot the street light closest to me is having issues and goes on and off every 10-15 minutes. Tail in about 30-40 feet above me and about 20 feet in front of me the light dies and I quickly loose orientation..can't tell anything about what the bird is doing. Since I'm close to houses and neighbor's cars I decide to chop the throttle some and try to put it in my yard. I THOUGHT I was level but neigh, apparently I was tail down. *SMACK* right before impact (in normal mode) i cut the throttle. SA smacks the ground and parts go flying..I hear a whirr that sounds like what you might expect after killing Robocop. Damage: Tail boom 1x Blade Grip Feathering Shaft (noticed the dampers are worn) tail linkage horizontal fin boom supports main gear main blades tail belt (no visible damage but this thing is a few years old and isn't looking great) blade holder bolt/nutx1 1x canopy mounting post Servos seem ok..and the head SEEMS ok. I plan to tear the head down just to be sure Now I'm assembling my HK450 while I wait on parts for the SA. I have the cyclic servos in, ds480 tail servo, boom with belt set the right way and right tension, Used an align tail linkage as the stock one sucks, replaced the frame hardware with Align hardware. I just need to set the cyclic servos up, put the arms on, setup the head, solder bullets on the motor/esc, put a spare rx in, continue radio setup, set the tail and tail gyro up. Should be flying this weekend EXI 450 comes in tomorrow and my Honey Bee FP / SA replacement parts come in between Monday->Wednesday. I'm going to be busy. Crashing the HBFP resulted in a busted frame, which is rare. Nothing else on the heli broke! Crashing the Trex resulted in a lot of misc broken things (and I'm sure I'll find more things broken as I tear it down). FP training definitely is quicker and cheaper. I also find the Trex easier to fly than the FP. I get the feeling that if a person can fly a FP heli to it's limits, a CP is butter. |
| Thread Tools | |
| Discussion training gear . | dazzzer1 | Beginner Training Area (Heli-Electric) | 4 | Jan 15, 2010 06:07 PM |
| Joke Dog diary vs Cat diary | Tonystott | Humor | 5 | May 17, 2007 03:42 AM |
