Old May 21, 2003, 02:48 AM
enjoycht is offline
Find More Posts by enjoycht
Joined Jul 2002
Hi, Guy,
I been talked to the Li-items maker, they make some Li items that you modeler are using. For safety, they can do some more items, but they did not make them. A switch able Li-charger is the one.
I test the switchable Li-charger prototype and it work perfectly for both 2 and 3 cell pack by correct switching, but in case any wrong set up, they knew everything is gone, even this a consumer's fault.
So they decide to produce only the fix cell version. 2 cell go to the 2 cell charger, 3 cell go to the 3 cell charger. much Less confusion (I am not going to say no confusion). Because safety is the most concern before everything.
If you worry about the same problem happen again, two cheap simple fix cell chargers may be the solution.
Good luck!
enjoycht
enjoycht is offline Find More Posts by enjoycht
Old May 21, 2003, 07:56 AM
BigDave is offline
Find More Posts by BigDave
Eat, sleep and FLY
BigDave's Avatar
Conway, Arkansas
Joined Dec 2002
Two chargers..
Originally posted by enjoycht
Hi, Guy,
Good luck!
enjoycht
I use the really simple circuit board charger which requires moving a pin jumper to accomodate the different number of cells. Very basic, but it works (as long as I set it properly). Perhaps, two different charger stations, one two cell one three cell would be a good idea.
My real point of this thread is to draw attention to the FACT that these batteries can cause a fire under the correct (or incorrect ) circumstances. They really need to be charged in a container for safety reasons.
BigDave is offline Find More Posts by BigDave
Old May 21, 2003, 08:08 AM
enjoycht is offline
Joined Jul 2002
BigDave,
It is true, I believe everybody got lots "Bomb" around, I personal have more than 30 Li packs. if any of us do not pay attention on what we are playing with, some day we will on the headline.
enjoycht
How many cells can an Astro 210 handle? Martin Irvine Electric Plane Talk 2 Jun 09, 2016 09:08 PM
Surplus 1400 Mah Li-on cells - Can I do a 3-cell pack? mrebman Batteries and Chargers 14 Aug 09, 2004 11:09 AM
how many li-po cells can i use on an original skylarkboard? fly_isse Micro Helis 1 Nov 10, 2003 02:08 PM
Can li-poly packs cause glitching? ronnath Batteries and Chargers 2 Mar 10, 2003 05:33 AM
how many cells can a b50-13xl handle? bpu6999 Electric Ducted Fan Jet Talk 4 Jan 31, 2002 05:11 PM
