Old May 15, 2003, 12:02 PM
dwholler is offline
Find More Posts by dwholler
Check out my RC Video Blog
dwholler's Avatar
Medford, New Jersey
Joined Jul 2002
Help!
Help I dont know what to fix?
Hi,
My son has a new focus fm transmitter and 555 receiver. Last weekend he lost control of the aircraft and it crashed head on in to a paved parking lot.
The aircraft survived well (its a UNICORN) but the reciever had came out of the fuselage. The battery back looked like it took the brunt of the crash and was completely destroyed.
Upon getting it home I tried to bench test the receiver and ESC with a fresh battery. Nothing.
I removed the ESC and used a receiver battery to test the ailerons only.Nothing.
I took apart the receiver to make sure the antenna was still connected. It looks alright and all the electrical components look good. Crystal is seated well.
At this point I can tell if I need a whole new receiver or a crystal. Is there any way to test a crystal to see if its good?
I dont have another receiver to try it in.
Dave
dwholler is offline Find More Posts by dwholler
Old May 15, 2003, 12:14 PM
gouda is offline
Find More Posts by gouda
Is it summer yet?
gouda's Avatar
Flight Level 46 X 92
Joined Feb 2002
Other than buying a new crystal, I don't believe there is a way. I would be sure to take the switch harness out of the circuit. they can be damaged. Other than that, I'd send it in for a check. It's not worth losing another plane in my opinion. A new receiver is only about 60 dollars. I have no idea what the charges would be for a repair. Might be as much as a new one.
gouda is offline Find More Posts by gouda
Old May 15, 2003, 12:17 PM
dwholler is offline
dwholler's Avatar
Medford, New Jersey
Joined Jul 2002
I thought so. I see that the crystal is rather fragile so I will try that first. If not then I will have a crystal for the next receiver I guess.
Dave
Old May 16, 2003, 09:51 AM
Art Horne is offline
Find More Posts by Art Horne
Hemet, CA
Joined Sep 2002
Hitec normally repairs them free. I just had a 555 crystal die in a crash and they repaired it free.
Regards,
Art
Art Horne is offline Find More Posts by Art Horne
Old May 16, 2003, 10:17 AM
pda4you is offline
Find More Posts by pda4you
pda4you's Avatar
USA, TX, Trophy Club
Joined May 2002
Send it to Hitec - your crystal may be the issue, but it is much more likely the filter (I think this is one of the internal crystals) will very likely be broken.
Hitec service is awesome and fast. I have never been charged - even when I say "I crashed this my fault" They send it back with a $0.00 charge. They are awesome.
Here is the form to fill out and send:
http://www.hitecrcd.com/nsupportFS.htm
Old May 16, 2003, 06:33 PM
dwholler is offline
dwholler's Avatar
Medford, New Jersey
Joined Jul 2002
Thanks everyone! I am back in business! It was just a broken crystal!
Old May 19, 2003, 09:11 AM
dwholler is offline
dwholler's Avatar
Medford, New Jersey
Joined Jul 2002
Well I thought it was alright.....
I bench tested it again last night and I am experiencing some bad glitching.
Heres the setup:
S400 with 3 capacitors soldered
Jeti 180
Hitec Focus FM Ch 19
Hitec 555 Micro receiver Ch 19.
I tore it apart rerouted the antenna and repositioned receiver. Antenna doesnt route over itself. Still alot of glitching when the motor is run up. Sometimes the motor sometimes doesnt want to shut off or is slow to turn off when throttle is cut.
One thing I do want to note is that the antenna does run rather close to the motor. Can this affect it even though the motor has caps?
Could it be a bad receiver still or maybe the ESC?
Thanks for the help in advance.
Old May 19, 2003, 09:18 AM
pda4you is offline
pda4you's Avatar
Joined May 2002
Your receiver is still broken - it is not worth risking. Hitec will fix it - send it in....
Old May 19, 2003, 03:47 PM
mkirsch1 is offline
Find More Posts by mkirsch1
United States, NY, Spencerport
Joined Oct 2001
SEND THE RECEIVER TO HITEC.
(Yes, that was meant to be SHOUTING)
mkirsch1 is offline Find More Posts by mkirsch1
Old May 19, 2003, 04:24 PM
dwholler is offline
dwholler's Avatar
Medford, New Jersey
Joined Jul 2002
OK OK. IM SENDING IT. No need to shout.
I am just trying to avoid the downtime cause my LHS is out of HITEC receivers!
I ordered a new one but thats days away...
I guess it pays to have spares of everything.
Discussion Dont know what my himaxx is? HELP skibumsd Power Systems 6 Jan 24, 2007 10:55 AM
HELP newbie dont know what im doing :-( Oli Dude Nitro and Glow Power Cars 15 Aug 06, 2005 03:03 PM
Please help i dont know what to buy, driving me CRAZY doctor_prox Beginner Training Area (Aircraft-Electric) 12 Jun 21, 2004 05:42 AM
Need A New Plane??? Dont Know What To Get..need Help. GUAIO/USA Foamies (Kits) 3 Jan 26, 2002 01:12 PM
