Old Jan 19, 2010, 10:33 PM
maiden-crash is offline
Find More Posts by maiden-crash
R/C Airplane Executioner
Melbourne, Australia
Joined May 2006
Build Log
Hyperion EXTRA 330SC 20E 3D
Hi guys,
Hyperion's newest addition to the 3D and scale market has just been released.
I'll be doing a build log on the 20E and will cover some of this new 3D monster's numerous features.
Some brief info:
The 20 E has a 41.5" wingspan with 370 square inches of wing area.
It's made to accommodate Hyperions Atlas DS09 servos. I'll be using 3 HP-DS09 SCD's (elevator/ ailerons) and a DS09-AMD for rudder. It uses a 35 amp ESC (Hyperion Atlas 35A LBEC) and the upcoming Hyperion ZS-3007B-24 brushless motor (an absolute jewel of a motor.)
In terms of batteries, I'll be using the Hyperion G3 1600 VX and 2100 CX, recommended are the Hyperion G3 1800 up to 2200.
The build is very, very simple. Please note I will not necessarily cover the build in the same steps as the manual, but either way will work just fine.
A link to the Extra 330SC 20e box label, in 1200 pixels wide.
Price of the 20e is $169.95, with Zs3007B-24 motor included.
http://www.aircraft-world.com/shopexd.asp?id=7212
Cheers
MC
maiden-crash is offline Find More Posts by maiden-crash
Old Jan 19, 2010, 11:04 PM
AllBread is offline
Find More Posts by AllBread
Like a boss!
AllBread's Avatar
United States, CO, Denver
Joined Sep 2007
What size is the 90e airframe?
AllBread is offline Find More Posts by AllBread
Old Jan 19, 2010, 11:46 PM
Joined May 2006
Hi Allbread, sorry mate I don't know, the 90E won't be out for another few months.
Old Jan 20, 2010, 12:01 AM
NipponDave is offline
Find More Posts by NipponDave
NipponDave's Avatar
American in Japan
Joined Mar 2001
Hi Everyone,
If you take a close look at the fine print on the large box label pic, you will see that there is a disclaimer stating that the 330 20e has a flat-plane tail surfaces to keep the model as light as possible. We had a Chicken-egg problem as a final 20e wasn't ready in time for photographing for the box label (decals were late), but we did have the 330SC 35e. The big pic in the middle is actually the 330SC 35e, and it does have the airfoiled rudder and elevator. I photoshopped those to make them look as "flat" as I could, but the junction of fuselage and rudder still gives it away...
Otherwise, the two models look pretty much identical... The smaller pics are all of the 20e, fyi...
David
NipponDave is offline Find More Posts by NipponDave
Old Jan 20, 2010, 12:15 AM
BoneDoc is offline
Find More Posts by BoneDoc
Team 3DHS
BoneDoc's Avatar
San Antonio, TX
Joined Sep 2004
Looking good Dave. I'll be following along.
BoneDoc is offline Find More Posts by BoneDoc
Old Jan 20, 2010, 02:08 AM
Joined May 2006
Unpacking...
Some pics showing the SC in in the box, un-boxed and some others.
The foam it's wrapped in is very protective- and ideal for over exited individuals who have to tear parts out rather than use scissors.
Old Jan 20, 2010, 02:34 AM
Joined May 2006
Pre-assembly
I always open up all openings in the fuselage before really starting assembly. You can choose to use a sharp hobby knife or soldering iron- I use a soldering iron because it seals up the covering and is generally just easier IMO. Make sure to open up cooling holes in bottom of fuse, CF spar opening, wing servo opening, anti rotation pins, rear servo pushrod exits and wing screw.
As a precautionary step, you may also choose to run over the joins on the motor box with glue. I always use carpenters glue in favor of thin CA, but both ways work just fine.
Old Jan 20, 2010, 03:22 AM
Joined May 2006
Next step is hinging the ailerons. Very simple, two drops per hinge per side.
-Make sure to move the aileron up and down until you can get the full throw the bevel allows before dropping CA into the hinges though. Sealing the hinges helps in surface efficiency and high alfa flight, but is completely up to you. I will seal mine a little later down the track.
Onto the control horn.
Firstly locate the two larger control horns out of the accessory bag. I Roughen the base with sandpaper (this lets the glue "grab"). I've always been happy with CA, slow curing epoxy and Poly Urethane- but I decided to go with polyurethane for the Extra.- If you do decide to use PU- drop one drop of water into each hinge slot, lightly coat the control horn base's with PU, place a bit of PU in the hinge slots, and simply push the horns into the slot until it seats all the way. The bond will be super strong but PU sets slow so the wings should be put away to allow the PU time to set.
Old Jan 20, 2010, 07:58 AM
RC4x4 is offline
Find More Posts by RC4x4
Fly Low or you'll never know!
RC4x4's Avatar
Thornton, Colorado
Joined Jul 2002
Model looks nice. Looks like there's alot of new stuff over the older models.
Does anyone know if the larger models will have Ultracoat covering on them.
I can see using the cheaper stuff on this model.
Cory
RC4x4 is offline Find More Posts by RC4x4
Old Jan 20, 2010, 10:06 AM
1Radioflyer is offline
Find More Posts by 1Radioflyer
Luvin' Life
1Radioflyer's Avatar
United States, MI, Portage
Joined Apr 2007
Is the landing gear and wing tube aluminum or carbon fiber? Are the wheel pants fiberglass?
Blessings,
Jay
1Radioflyer is offline Find More Posts by 1Radioflyer
Old Jan 20, 2010, 01:50 PM
ronin8451 is offline
Find More Posts by ronin8451
E-Flight Addict
ronin8451's Avatar
Weatherford, Tx.
Joined Oct 2003
Sweet ! Looks like a winner to me !
ronin8451 is offline Find More Posts by ronin8451
Old Jan 20, 2010, 05:14 PM
Joined May 2006
Blessings,
Jay
Hi Jay, wing tube is carbon fiber, landing gear is a high grade aluminum and wheel pants are fiberglass. I'll probably move onto landing gear next.
Old Jan 20, 2010, 05:23 PM
Luvin' Life
Joined Apr 2007
Thanks for the reply. She's beautiful and I can't wait for some flight video
Blessings,
Jay
Old Jan 20, 2010, 06:19 PM
wahrhaftig is offline
Find More Posts by wahrhaftig
Sebastopol, CA, USA
Joined Dec 1996
Price????????????????
wahrhaftig is offline Find More Posts by wahrhaftig
Old Jan 20, 2010, 06:23 PM
Joined May 2006
Check the first post. I'll update the update the first post once it's set.
Discussion Electrifly Extra 330SC george@dream-flight 3D Foamies 95 Sep 06, 2014 07:48 PM
Discussion slick 51" verse the extra 330sc 57" qman 3D Flying 6 Oct 13, 2009 03:54 AM
Video 3DHS 57" Extra 330SC w/ Reaper Gr-60 blucor basher Electric Plane Talk 6 Oct 09, 2009 08:42 AM
Alert 3D HobbyShop 57" Extra 330SC MLT67 3D Flying 1085 Sep 23, 2009 07:05 AM
