Espritmodel.com Heli Air
Old Jan 19, 2010, 06:02 PM
Carlyle Harper's Avatar
Joined Feb 2007
Practical difference between 1.2ghz and 2.4ghz LM 1 watt TX
What are the practical differences of the Lawmate tx/rx combos at 1 watt between the 1.2ghz and 2.4ghz band?
I only want to compare Lawmate to Lawmate and only same power to same power. Aside from the band they operate in, keep all other variables the same.
Carlyle Harper is offline Find More Posts by Carlyle Harper
Old Jan 20, 2010, 09:15 AM
Don't disturb the pilot !!!
saucisse's Avatar
Canada, QC, Quebec
Joined Jun 2008
I would be curious too to know the answer!
saucisse is offline Find More Posts by saucisse
Old Jan 20, 2010, 10:43 AM
Questionable judgement
bracky72's Avatar
Charles Town, WV
I own both. I get much greater range with the 2.4 system. My 1.2 tx also seems to get hotter. They look identical to one another so don't remove the sticker or you can get them mixed up.
bracky72 is offline Find More Posts by bracky72
Old Jan 21, 2010, 05:46 AM
RC Wannabe!
areis81's Avatar
vercelli, ITALY
Joined Dec 2009
would be interesting to know why the 2.4 gets more range... i was thinking about the 1.2 (1.28) but this news makes me re-think about it!
areis81 is offline Find More Posts by areis81
Old Jan 21, 2010, 06:06 AM
bracky72's Avatar
Charles Town, WV
My only explanation is that frequency set isn't as clean in my area or the receiver isn't as sensitive.
Old Jan 21, 2010, 06:16 AM
RC Wannabe!
areis81's Avatar
vercelli, ITALY
Joined Dec 2009
reading thru threads (i'm not expert) i agree with sensitivity of receiver, which in 2.4g has been better developed. but only my opinion from thread reading
Old Jan 21, 2010, 03:02 PM
Netherlands, NH, Edam
Joined Jul 2004
Just going to post the below quote, to point out obvious issues with 1.2GHz Txs.
Warning!
Important note for US and Canada customers:
Please note, channels 1,2,3,4,5,6,7 of this transmitter are outside of the allowed frequency spectrum for US and Canada. These channels cannot be legally used even if you have a Radio Amaterur or HAM license. Please make sure that you obey your countries rules and regulations around use of these devices and use them only on channel 8. New Generation Hobbies cannot be held responsible for using these transmitters on channels which are outside of the legal allowed frequency ranges.
For all other countries please check the regulation around amateur use and frequency spectrums before ordering this product
Cheers,
Sander.
ssassen is offline Find More Posts by ssassen
Reply With Quote  (Disabled)
Old Jan 21, 2010, 03:43 PM
RC Wannabe!
areis81's Avatar
vercelli, ITALY
Joined Dec 2009
i've neen told before and i must apologize again. i always refe t 1.28g (legal) writing simply 1.2
Old Jan 21, 2010, 09:50 PM
Joined Feb 2007
Somehow long ago I had dismissed the 1.2ghz systems as poor performers compared to the 2.4ghz systems by the same manufacturer and so the reason for this post was to see if my myth on the performance was true or not. So far the myth I believed in is plausible, including more limited range and lower sensitivity.
I'm aware of the legal channel limitations of both transmitters. Maybe I should clarify that this thread is about practical performance differences. So let's leave the legal discussion alone.
Old Jan 21, 2010, 10:16 PM
North vancouver, B.C. Canada
Joined Apr 2008
leaving the legal things out
certain frequencies are not used, and not legal for a reason
out of allowed use
that is why they are so clear
its that simple
Carlyle in your case 1.36 would work the best
with a great video tx and rx that are set to that frequecy
ie antenna length and specific tuneing
but with gps not so
David22 is offline Find More Posts by David22
Old Jan 22, 2010, 08:43 AM
Joined Feb 2007
out of allowed use
its that simple
but with gps not so
Are you saying the 1.2 tx/rx inherently performs better on some channels than others?
Old Jan 22, 2010, 08:50 AM
Joined Apr 2008
yes some frequencies will work better than others
depending on the enviroment
including the area you fly and what is installed in your plane and ground station
Old Jan 22, 2010, 02:11 PM
KF5LDN FPV Junkie!!!
Wizzard033's Avatar
United States, TX, Lubbock
Joined Nov 2009
opps sorry. wrong thread
Wizzard033 is offline Find More Posts by Wizzard033
Old Jan 22, 2010, 11:03 PM
JettPilot's Avatar
Miami
Joined Apr 2005
In theory 1.2 GHZ should go further than 2.4 GHZ, but the theory does not take into account that the 2.4 GHZ video equipment is made better, and that the receivers are better.
So in reality, the 900 MHZ and 1.2 GHZ equipment has shorter range than 2.4 GHZ. Its not a matter or theory, or clean or dirty frequencies, it comes down ot the capability of the electronics. 2.4 GHZ video equipment has bee much better developed with better receivers and the range is much better.
JettPilot is offline Find More Posts by JettPilot
Site Sponsor
Old Jan 23, 2010, 01:29 AM
Joined Apr 2008
The difference is
what is being used in your area
and what equipment you use for fpv
and which 1.2 or 2.4 sytem you use and antnnas etc.
Question 900mhz, 1.2ghz, 2.4ghz, 5.8ghz ? Freakazoid Video Piloting (FPV/RPV) 77 Feb 20, 2010 12:18 AM
Discussion 1.2GHz or 2.4Ghz Video? Koby Video Piloting (FPV/RPV) 14 Nov 21, 2009 07:53 AM
Discussion whats difference between mode 1 and mode 2? ccflier Radios 19 Oct 26, 2009 02:53 AM
Cool For sale, cheap 1 watt 2.4ghz tx/rx reznikvova Aircraft - General - Miscellaneous (FS/W) 6 Nov 28, 2006 07:19 PM
WiFi (802.11) 2.4GHz antennas for 1.2GHz receiver? dw1122 Aerial Photography 1 Feb 02, 2003 01:39 AM
