Old Nov 03, 2010, 12:04 AM
Kevin Matney is offline
Find More Posts by Kevin Matney
Kevin Matney's Avatar
United States, MI, Erie
Joined Mar 2000
Hay Flyboone
What motor will Hobby Lobby sell with there Outrageous racer???
Kevin Matney is offline Find More Posts by Kevin Matney
Old Nov 03, 2010, 08:50 AM
Jason Cole is online now
Find More Posts by Jason Cole
RCG Staff Member
Jason Cole's Avatar
United States, TN, Nashville
Joined Oct 2003
We're looking at a Spring Release. Once we get a sample, we'll start working out what will be included.
Jason Cole
Jason Cole is online now Find More Posts by Jason Cole
Administrator
Old Nov 03, 2010, 12:03 PM
DaveSawers is offline
Find More Posts by DaveSawers
Canada, NS, Lunenburg
Joined Oct 1999
Jason Cole
If you need some pre-release testers, we're still very active up here with a winter program of EF-1 races going on.
DaveSawers is offline Find More Posts by DaveSawers
Old Nov 03, 2010, 02:20 PM
zedad71 is offline
Find More Posts by zedad71
Joined Sep 2008
@ Dave, really? maybe I need to come up north for a "visit" this winter
zedad71 is offline Find More Posts by zedad71
Old Nov 03, 2010, 09:01 PM
DBA-FW is offline
Find More Posts by DBA-FW
Fort Worth, Texas
Joined Nov 2002
Testers? Put me on the list!
DBA-FW is offline Find More Posts by DBA-FW
Old Nov 03, 2010, 09:49 PM
kingsflyer is offline
Find More Posts by kingsflyer
We shall serve the Lord
kingsflyer's Avatar
United States, TX, Kingsland
Joined Sep 2005
Will it be ready in time for SEFF 2011? Please let me know when it will be available for purchase. I've got the motors, ESC and batteries on standby.
McD
kingsflyer is offline Find More Posts by kingsflyer
Latest blog entry: LEDs on my T-28
Old Nov 04, 2010, 07:22 PM
bruff is online now
Find More Posts by bruff
EDF all the way!
bruff's Avatar
Gilbert, Az
Joined Jun 1999
Working on testing some Hacker motors in a Pogo. What RPM should you get with one of the approved motors and an APC 8 x 8 prop, using 4S 2600ma TP LiPo pack? Trying the A40-12S (8 pole) and the A30-8XL motors.
Bob
bruff is online now Find More Posts by bruff
Old Nov 04, 2010, 11:43 PM
mjws is offline
Find More Posts by mjws
Airdrie, AB Canada
Joined Sep 2004
You should be somewhere around 13500rpm on the stock rig. Your a40 is closer in kv to my scorpion... and a few extra grams won't hurt at all if you get similar power. It might be better as you'll be easier on your packs. I would think your a40 should tag 16500 on the 8x8, maybe better depending on how much the extra mass helps. I hope you get some good data as it may be a great 'performance' choice. Your other hacker is close to stock, but likely more efficient motor. Both seem like great choices. The A30 I'd love to see approved for the class, along with others.
Good luck. Look forward to seeing the results.
mjws is offline Find More Posts by mjws
Old Nov 05, 2010, 12:06 AM
mlee8249 is offline
Find More Posts by mlee8249
Fly R/C writer
Redlands, Ca
Joined Dec 2004
Bruff,
I am getting 13,800 on the E-flite motor and APC 8x8e prop, E-flite 4S-2500 mAh packs and aluminum spinner. Runs 2.5 to 3 minutes all out and consumes 1800-mAh of the pack.
Mike Lee
mlee8249 is offline Find More Posts by mlee8249
Old Nov 05, 2010, 07:26 AM
johnnychimpo is offline
Find More Posts by johnnychimpo
Afghanistanimation
johnnychimpo's Avatar
United States, TX, Killeen
Joined Sep 2006
Same here Bruff with stock eflight motor and Turingy 2650 4s 40c pack. Motor starts off at around 14,500 and stabilizes at the mid 13's. After 11 laps on the 2 pole course im putting back in around 1500mah to 1700mah
johnnychimpo is offline Find More Posts by johnnychimpo
Old Nov 05, 2010, 08:19 AM
c/f is offline
c/f
Find More Posts by c/f
c/f
Joined Jan 2004
Bruff,
If you really want to know if its close to an approved motor you should input 10VDC into an ESC via a power supply and then check motor rpms without a prop ie no load. It should be near 12,500 rpms. Then your in check with approved motors. ie 1250KV means 1 revolution per kilovolt. NO LOAD
One thing about cheap brand motors is when doing this test they will be all over the map as consistancy in winding is an afterthought next to piece work.
Unlike buyings Nelson for Q40/Q500 where one does'nt hear the "I GOT A GOOD ONE" , One might have to buy a dozen Turnigy to find "the good one".
The above mentioned static test should be part of a dispute protocol resolution. A whole lot simpler than blueprinting.
c/f is offline Find More Posts by c/f
Latest blog entry: Time Capsule Heli
Old Nov 05, 2010, 11:29 AM
zedad71 is offline
Joined Sep 2008
Nelsons,, yeah they do ,, I have been at races, and it is obvious that there are MORE equal ones than others,, HOwever your basic premise is very sound regarding the Turnigy and cheaper motors, If they are "the " class motor, I think you will find it neccessary to purchase 8 or 12 motors, test them to find a few decent ones, and maybe get lucky and get a good one.. that or you will see people "blueprinting" them rewinds, bearings, trueing cases,,
Hackers , I have been looking at my A30-8xl,, and at the plans for my Thuncerchicken,, hmm it looks pretty good to me,, sadly its not an approved motor,,
Old Nov 05, 2010, 07:21 PM
bruff is online now
EDF all the way!
bruff's Avatar
Gilbert, Az
Joined Jun 1999
Thanks, this is why Hacker is testing/flying the motors. They want to get one approved. Trying to see which would do better to meet the standard requirements, before sending motors in for approval. Problem is Hacker does not have 1250 kv motor, A30-8XL 1100kv & A40-12S 1350 kv.
Thanks for the input. I'll keep everyone updated.
Bob
Old Nov 08, 2010, 04:37 PM
FLYTILIDIE is offline
Find More Posts by FLYTILIDIE
Southampton UK
Joined Dec 2006
Just seen advert for a hanger 9 (i think ) smaller version Sundowner , the advert advises a EF1 set up so does this mean that we have a second kit arriving shortly .Has this model been accepted by the committe as a legal model -thanks
FLYTILIDIE is offline Find More Posts by FLYTILIDIE
Old Nov 08, 2010, 05:21 PM
Afghanistanimation
Joined Sep 2006
got a pic or link to advertisement?
Never mind i found it on hangar 9's website. Im curious as well.
Looks like it might be a little bit heavy though with the added strength needed for a glow engine.
Formula One Scale Racing El Pe High Performance 9 Sep 26, 2013 07:30 PM
Sold HPI Racing Formula Ten w/lipo speedcontrol and motor $200.00 Shipped FieldofDreamsFlyer Cars - Cars and Parts (FS/W) 1 Nov 09, 2009 01:14 PM
For Sale HPI Racing Formula Ten w/lipo speedcontrol and motor FieldofDreamsFlyer Cars - Cars and Parts (FS/W) 2 Nov 09, 2009 12:52 PM
