Old Oct 19, 2010, 07:57 PM
k.fluney is offline
Find More Posts by k.fluney
k.fluney's Avatar
Canada, ON, Orangeville
Joined Mar 2006
Originally Posted by DaveSawers View Post
I heard a rumour that the Tomcat is quite a difficult build.
Dave I built my SuperT Toni with out and drawings, as the plans where not finish when purchased. I did have a some help from DK for the wing.
The fuselage is very easy as it is all tabs for the formers, just like building a
Q500. The wing is just like building the old F1,Q40 wings.
The Tom Cat and the Toni are built the same.
Ken
k.fluney is offline Find More Posts by k.fluney
Old Oct 19, 2010, 08:36 PM
DaveSawers is offline
Find More Posts by DaveSawers
Canada, NS, Lunenburg
Joined Oct 1999
Originally Posted by dkane View Post
Dave seriously, this coming from a guy that built the Nemesis and Outrageous. The TOMCAT is a slab side foam wing core build. You are kidding right?
DK
I only said it was a rumour. I've not seen one yet.
DaveSawers is offline Find More Posts by DaveSawers
Old Oct 19, 2010, 09:21 PM
George Parks is offline
Find More Posts by George Parks
Austin,Texas, USA
Joined Jun 2001
Originally Posted by Rsmith View Post
Question for the Group:
When I was in Muncie for the F5D worlds, George Parks advised that some guys are experiencing melt down issues with the connectors on the Turnigy 1250Kv motor. ie. the three bullet connectors that plug into the controller. I think the plugs are 3.0mm and they may not be rated for the amps we are drawing using props like the 8x8.
I think George said that guys are changing to the next size up (4.0mm ?). Has anyone experienced this issue ? I had some connector problems of my own in the early days of the Outrageous/Turnigy but I thought it was due to arcing between connectors. I since completely cover each of the connectors with heat shrink to isolate them.
Randy
BTW, it's snowing here this morning...
Randy - I think you misunderstood me - we are not changing the size of the connectors - just the design of the male part. The ones that come on the Turnigy and Eflite motors have little springs that contact the interior of the female connector and they limit the safe capacity to about 25A. Jerry Small lost a plane when one of them failed. There is a better 3.5mm connector available. Go to the Hobby King website, look under hardware & accessories, wires & plugs, page 12. Their part number is SKU:AM-1001C. The price is $3.99 for 10 pair. You might also find them at a local hobby shop that sells 450 size helicopters - most of the T-Rex crowd knows about these connectors.
BTW - the post about the soldering of the stock male connectors is right.
George Parks is offline Find More Posts by George Parks
Old Oct 19, 2010, 10:08 PM
Rsmith is offline
Find More Posts by Rsmith
Rsmith's Avatar
Calgary, Alberta, Canada
Joined May 2002
Thanks George. That clarifies it. Agreed, the little springy parts of the male connector seem to burn up.
I'll check into it.
Randy
Rsmith is offline Find More Posts by Rsmith
Old Oct 20, 2010, 04:46 PM
DHG is online now
DHG
Find More Posts by DHG
DHG
United States, CO, Arvada
Joined Jul 2010
[T]he little springy parts of the male connector seem to burn up.
Randy
Do you smoke after sex?
DHG is online now Find More Posts by DHG
Old Oct 20, 2010, 07:08 PM
Ralph Weaver is offline
Find More Posts by Ralph Weaver
Ralph Weaver's Avatar
Indianapolis, IN USA
Joined Nov 2000
Never looked.
Ralph Weaver is offline Find More Posts by Ralph Weaver
Old Oct 20, 2010, 10:44 PM
Rsmith is offline
Rsmith's Avatar
Joined May 2002
Only if we don't use lube !
Old Oct 20, 2010, 11:52 PM
Kevin Matney is offline
Find More Posts by Kevin Matney
Kevin Matney's Avatar
United States, MI, Erie
Joined Mar 2000
Race rules
I have 1 question about the motor rules.If a motor has been past by NMPRA BUT does not meet the rules size is it a legal motor? And what do I do if I was a CD at a contest and some one show said motor?
Kevin Matney is offline Find More Posts by Kevin Matney
Old Oct 21, 2010, 09:17 AM
PylonDave is offline
Find More Posts by PylonDave
PylonDave's Avatar
United States, CA, Rancho Cucamonga
Joined Mar 2003
If i were a cd i would at this point be a little flexable on the rules. If a person showed up with a plane that had parts that we not on the list and was about the same speed as the rest, i would let them participate. The current rules are still being hashed out from what i can see, so lets get people flying this class, get the class some momentum untill the rules are finalized.
PylonDave is offline Find More Posts by PylonDave
Old Oct 21, 2010, 09:47 AM
Joined Oct 1999
The EFlite motor doesn't meet the size rules, unless the rules have been changed recently.
Old Oct 21, 2010, 10:00 AM
dkane is online now
Find More Posts by dkane
dkane's Avatar
USA
Joined Jul 2002
Kevin, the rules no longer have dimensions. There is a list of acceptable motors. Currently, only the E-Flight and the Turnigy motors are approved. Therefore, if you were a CD you should publish the list of motors you are allowing prior to the contest if you are to deviate from the NMPRA rules. This has been published since 4/30/10.
dkane is online now Find More Posts by dkane
Old Oct 21, 2010, 10:38 AM
rvdb is offline
Find More Posts by rvdb
Joined Mar 2010
Originally Posted by FLYTILIDIE View Post
Still want a toni though - thanks
Here is your Tony
http://www.rbckits.com/shop/index.ph...&productId=616
Its redesigned with a modified RG14 section wing I think but better ask direct to Rob Bulk at RBCkits
rvdb is offline Find More Posts by rvdb
Old Oct 21, 2010, 04:43 PM
FLYTILIDIE is offline
Find More Posts by FLYTILIDIE
Southampton UK
Joined Dec 2006
Thanks rvdb for link - will try both RBC and also super T -one will come good - your explanation on wing section may explain why one has foam cores and the other built up - whichever its on the winter build list .. Has any one in your area built one of these kits -?
FLYTILIDIE is offline Find More Posts by FLYTILIDIE
Old Oct 21, 2010, 05:10 PM
quazimoose is offline
Find More Posts by quazimoose
quazimoose's Avatar
Winnipeg, Canada
Joined Apr 2007
Castle Creations made me laugh, read the last part of the safety section.
" Do not ingest this product, it won't make you any faster. "
Product is the Ice Lite 75 esc.
quazimoose is offline Find More Posts by quazimoose
Old Oct 21, 2010, 08:13 PM
Joined Mar 2000
I did not know we had a rule change already!!!! And I miss it.
Formula One Scale Racing El Pe High Performance 9 Sep 26, 2013 07:30 PM
Sold HPI Racing Formula Ten w/lipo speedcontrol and motor $200.00 Shipped FieldofDreamsFlyer Cars - Cars and Parts (FS/W) 1 Nov 09, 2009 01:14 PM
For Sale HPI Racing Formula Ten w/lipo speedcontrol and motor FieldofDreamsFlyer Cars - Cars and Parts (FS/W) 2 Nov 09, 2009 12:52 PM
