Old Jan 18, 2010, 11:50 PM
bri6672 is offline
Find More Posts by bri6672
bri6672's Avatar
San Diego
Joined Jul 2009
Lost over 90mm Midi Fan and Motor combo???
Hey Guys,
So I am a bit lost on what motor I should match up with my Midi Fan.
So I am getting ready to build my Pro Design F-18 and I have been reserching setups for weeks now looking for that balance of decent speed and power but tollerable flight times (6-7 min mixed throttle) and I am kind of stuck! Rough estimates have the jet coming out at about 7lbs with 6s and 7.5lbs with 8s. I want to keep the motor budget at a reasonable price (would like to stay under $100). I really am thinking 6s so I have the convience of charging 1 battery not 2 (2) 4s's to make up 8s) soooo Battery will most likely be 6s 5000 30c. I am going with a CC ICE 100 ESC so I can run 6 or 8s.
Neumotors are just to expensive, Medusa is out of buisness sooo I am looking at: (with some flightcalc specs on 6s 5000mah 30c)
HET Typhoon 600-37 (1700kv) 4.1lbs of thrust and 162 watts per lb (pretty weak but good flight times) $89
Great Planes Electrifly Ammo 36-56-1800kv 4.4lbs thrust and 184 watts per lb (better but not great but still good flight times) $49
The Scorpion motors (hk3026) are outrunners and needs quite a bit of Fan Modifications to make work so not sure about that but the price and specs are decent, not sure I want to hack up the fan!
Hobbyking has this:
KD36-74-09XL (1900kv) 5lbs of thrust and 220 watts per lb and still ok flight times the $31.95 price tag is just dosent seem like enough money for a motor of this size???
So can anyone make some suggestions and please dont just throw out a brand with out a model # that would work on the Midi fan.
Keep in mind if I have to I could go 8s but trying to stick with 6s
Thanks for any help,
Brian
bri6672 is offline Find More Posts by bri6672
Old Jan 19, 2010, 12:50 AM
iamzoli1 is offline
Find More Posts by iamzoli1
iamzoli1's Avatar
Joined Jan 2009
Originally Posted by bri6672 View Post
Hey Guys,
Hobbyking has this:
Brian
if you read the discussion of this motor on hobbyking you will see that this motor is not good even on 5s
under 100$ i dont have any suggestion
iamzoli1 is offline Find More Posts by iamzoli1
Old Jan 19, 2010, 01:01 AM
bruff is online now
Find More Posts by bruff
EDF all the way!
bruff's Avatar
Gilbert, Az
Joined Jun 1999
I have a 6S midi fan with Hacker motor listed in the jet for sale section.
Bob
bruff is online now Find More Posts by bruff
Old Jan 19, 2010, 06:19 AM
reinhoud is offline
Find More Posts by reinhoud
reinhoud's Avatar
Joined Sep 2004
8s setup
I am wondering the same for the f-18, although i do keep the NEU 1415 1.5Y on 8s as an option, but dont know the amp draw and flight time on 4000mah. I have a CC 85HV. I am also thinking of the Jepe 8s fan/motor combo.
I have a 6s midi setup which produces like 2 kg of thrust initially. Also seeing the video i think i wont go with 6s.
Regards,
Erwin
reinhoud is offline Find More Posts by reinhoud
Old Jan 19, 2010, 06:38 AM
LJE4357 is offline
Find More Posts by LJE4357
Closed Account
Joined Jun 2002
Take a look at the ARC motors, you'll get the best bang for the buck.
Larry
LJE4357 is offline Find More Posts by LJE4357
Old Jan 19, 2010, 07:10 AM
GregG is offline
Find More Posts by GregG
Speed Demon
GregG's Avatar
Antioch,CA,USA
Joined Dec 1999
ARC motors from http://www.lightflightrc.com/ ?
Carl Rich's 90mm testing thread
http://www.rcgroups.com/forums/showthread.php?t=846287
Edit:
Ya beat me to it while I poured a cup
GregG is offline Find More Posts by GregG
Old Jan 19, 2010, 08:03 AM
reinhoud is offline
reinhoud's Avatar
Joined Sep 2004
I saw the data from Carl, but can not find the 36-60 for sale. This one seems to draw max amps the cc85 hv can handle. I did find the ARC 3675-1.5 1360Kv and ARC 3675-1 1680Kv (which looks like draws close to 100 amps?).
Regards,
Erwin
Old Jan 19, 2010, 08:15 AM
gundamnitpete is offline
Find More Posts by gundamnitpete
Team White Llama!
gundamnitpete's Avatar
United States, TX, Houston
the 36-65-1 is out of stock right now. The 36-55 series are good to around 2kw.
gundamnitpete is offline Find More Posts by gundamnitpete
Old Jan 19, 2010, 08:47 AM
Ed Waldrep is offline
Find More Posts by Ed Waldrep
Ed Waldrep's Avatar
Las Vegas, NV
Joined Dec 1996
I've been flying the Mega 22/30/2 on 6S 5000 (74 amps max draw, 1600 watts HOC) for a couple of years now. I use half of an MPI heatsink (cut in half lengthwise) to keep temps down to 135 degrees max. Works great on a 6 lb balsa and ply F-18, with another pound from a polyester(?) fuselage not as great but should still be ok, you don't really need insane watts per pound to put on a good show.
Ed Waldrep is offline Find More Posts by Ed Waldrep
Old Jan 19, 2010, 09:04 AM
MattinAZ is offline
Find More Posts by MattinAZ
MattinAZ's Avatar
United States, AZ, Gilbert
Joined Jan 2005
Did you order it with the Fan?
If so the Prodesign 90mm fan has a molded in cut-out for the install of the outrunner motors. No mods to the fan needed - Nice touch.
I have tested the Scorpion in this fan on 6S I get 1550 watts at 50 something amps and the motor is nice and cool. I plan on testing it on 7S tonight and getting temps and numbers.
Also have the Het motor and I believe you can run 7S on that one with heat sink installed. Yet to test it
Will post them on my F-18 thread.
Matt
Hey Guys,
Hobbyking has this:
Brian
MattinAZ is offline Find More Posts by MattinAZ
Old Jan 19, 2010, 11:15 AM
bri6672 is offline
bri6672's Avatar
San Diego
Joined Jul 2009
Thanks for the replys guys!! Matt it is the Pro Design fan and thats great to hear that outrunners are an option. The Scorpion wtih 1900kv should be decent on 6s but i am guessing that is pushing the limits of that motor, I will keep an eye on your F-18 build!
I am not completely opposed to 8s but just thinking I want to avoid recharging 2 packs at the field.
I will look closer at ARC (I havent looked at all they offer yet) I wonder if that 36-65-1 can handle the 6s, that would be a great watt per lb ratio for sure!!
Mega seems to have to low of a kv to really get 6s moving I want to be around 1900kv.
I am not really taking that video seriously, who knows what motor and setup they went with, MattinAZ's Mig on 6s was really impressive so I dont think a good 6s setup is out of the question.
Old Jan 19, 2010, 02:14 PM
SteveC68 is online now
Find More Posts by SteveC68
Oh Yeah!
SteveC68's Avatar
League City, Texas
Joined Sep 2006
Yes the ARC 36-65-1 can handle 6S in the midi fan. You could also run the ARC 36-55-1.5 on 6S or the 36-75-1 on 8S. The 65-1 and 75-1 are out of stock though.
SteveC68 is online now Find More Posts by SteveC68
Old Jan 19, 2010, 02:56 PM
bri6672 is offline
bri6672's Avatar
San Diego
Joined Jul 2009
Any ideas of when they will be back in stock?
Old Jan 19, 2010, 03:19 PM
Oh Yeah!
SteveC68's Avatar
League City, Texas
Joined Sep 2006
Nope
Old Jan 20, 2010, 05:15 PM
speleopower is offline
Find More Posts by speleopower
Hey Now
Cocoa Beach, Florida
Joined Feb 2004
8s is ideal with a Mega 22/30/3. I've been running this in my 90mm Bob-E-Cat for a few years and it's perfect.
I know it's not 6s but I didn't have much luck with 5-6s in Midi's. The amp's just go up to high and flight times and batteries suffer.
-Scott
speleopower is offline Find More Posts by speleopower
Discussion BAE Hawk motor question w/Midi fan....edit: anyone using 90mm Midi fan??? CSI Foamy EDFs 25 Mar 15, 2010 10:01 PM
Sold Midi 90 mm fan with Hacker motor bruff Aircraft - Electric - Jets (FS/W) 2 Jan 18, 2010 10:35 PM
Yippee! canceled marcofly Foamy EDFs 0 Jan 12, 2010 08:27 AM
Sold Neu Motor 1415/WeMotec Midi fan Combo aaflyer60 Aircraft - Electric - Power Systems (FS/W) 1 Oct 26, 2009 09:03 AM
Found used 90mm midi fan to test a motor MustangAce17 Aircraft - Electric - Jets (FS/W) 9 Dec 12, 2007 03:25 PM
