Old Jan 18, 2010, 09:34 PM
krexken is online now
Find More Posts by krexken
smoke is my wattmeter
Longview, Tx
Joined May 2008
How does a heli esc differ from a plane oneż
Or is there any difference.
krexken is online now Find More Posts by krexken
Old Jan 18, 2010, 09:52 PM
Truglodite is offline
Find More Posts by Truglodite
Registered Aircraft Offender
Truglodite's Avatar
Carmichael, CA
Joined Feb 2007
Not really. Most plane esc's have a governor mode which can be enabled (via programming) for use mostly for helis, and sometimes on variable pitch planes. Some companies have H and A esc's, like Coolrunning. For example they have an H-25, which has governor mode, and an A-25 that doesn't have governor mode.
On a side note, I haven't tried my H-25 on an airplane, but I have tried using governor mode on a Phoenix 10 esc with "normal mode" on my heli. That didn't work out well... the RPM surged all over the map. Might be ok using governor mode on a plane though, since you don't have to worry about tail control and jumps in RPM.
Kev
Truglodite is offline Find More Posts by Truglodite
Old Jan 18, 2010, 10:02 PM
Steph280 is offline
Find More Posts by Steph280
1.21 Gigawatts!
Steph280's Avatar
Irvine, CA, USA
Joined Oct 2000
you don't need the governor mode to have a heli ESC. The more important feature of a heli capable ESC are slow start and brake disable. Both features are needed to prevent the sudden jolt to the drive train during start up or spool down. If you have those two then you can pretty much use the ESC on a helicopter using throttle curve. While governor is nice, they rob away power, and in some bad implementations, will cause oscillations to tail gyro.
On the other hand, since the helicopter spend a lot of time at mid to upper throttle, helicopter ESC with higher resolution will give you much smoother hovering or forward flight transition. Some ESC's are so bad that a tick on your throttle stick will make the heli jump. This is a less noticeable phenomenon on airplanes, as props are less affected by suddent throttle changes.
Steph280 is offline Find More Posts by Steph280
Old Jan 18, 2010, 11:52 PM
Longview, Tx
Joined May 2008
That makes sense. Thanks, guys.
Old Jan 19, 2010, 04:41 AM
slipstick is offline
Find More Posts by slipstick
Staffs, UK
Joined Nov 2003
And don't forget that quite a few heli ESCs don't have an LVC. It's usually easy enough to tell that voltage is low with a heli and the last thing you want is the ESC cutting all your motor power for you .
Steve
slipstick is offline Find More Posts by slipstick
Discussion How does one know? KIDGLOVES00 Beginner Training Area (Aircraft-Electric) 9 Nov 10, 2009 08:11 PM
Question How does one submit reviews? MGBGTRacer Site Suggestions / Complaints 6 Oct 13, 2009 03:30 PM
Question How does a 22x8-14 Prop Differ from a 22x14? FlyingW Power Systems 9 Feb 01, 2007 01:52 PM
Build Log What is PCS, and how does it differ from PSS? jludwick Slope 18 Mar 07, 2006 09:03 PM
