Old Jul 27, 2011, 04:15 PM
3DNater is offline
Find More Posts by 3DNater
3d NOOBular
3DNater's Avatar
United States, NV, Las Vegas
Joined Aug 2010
Originally Posted by mt_flyer View Post
it will fly again, just no too soon..
ouch... major bummer.
3DNater is offline Find More Posts by 3DNater
Old Jul 27, 2011, 04:40 PM
waynemia is offline
Find More Posts by waynemia
A trail of smoke is GOOD!
waynemia's Avatar
USA, TX, Springtown
Joined May 2008
Originally Posted by brathanke View Post
has anyone done a knife edge spin with their t40?
In the air?
Daniel, you KNOW you are supposed to use Integer math...
waynemia is offline Find More Posts by waynemia
Old Jul 27, 2011, 05:23 PM
3DNater is offline
3d NOOBular
3DNater's Avatar
Joined Aug 2010
Originally Posted by waynemia View Post
In the air?
Yes in the air lol. I was trying to do one with my twist but I know I don't have enough elevator throw. I was just wondering if anyone else has been able to do it. Wondering if its possible. My 48" edge did it really well on the two flights I had on it before meeting terra-firma.
I did a nice KE spin at 2:30 on this flight.
48" Edge 2nd flight and rx lockout (7 min 26 sec)
Old Jul 27, 2011, 05:29 PM
mt_flyer is offline
Find More Posts by mt_flyer
Montana Transplant
mt_flyer's Avatar
United States, TX, Sealy
Joined Aug 2005
went up 3 times... came down 2 times running, 3rd time minus a complete motor.... seized on take off with a vertical climb out 4 ft up...
with a 5.5in CG...you get the picture
I think the connecting rod is busted, crank will turn almost 360 then hits solid
Reminder to self: STOP BUYING USED ENGINES!!!
mt_flyer is offline Find More Posts by mt_flyer
Old Jul 27, 2011, 05:43 PM
3DNater is offline
3d NOOBular
3DNater's Avatar
Joined Aug 2010
I have a saito 72 I'll sell you
Old Jul 27, 2011, 06:18 PM
kerwin50 is offline
Find More Posts by kerwin50
kerwin50's Avatar
winston mo
Joined Oct 2006
Waldo I'm with Wayne, it's gotta be a cable or connector maybe a jack.
kerwin50 is offline Find More Posts by kerwin50
Old Jul 27, 2011, 06:36 PM
u2builder is offline
Find More Posts by u2builder
u2builder's Avatar
USA, NH, Alstead
Joined Oct 2007
Ha Ha, my purchased used Saito 72 has a busted crank, which of course broke during a hover, and they have been out of stock for over a year!
u2builder is offline Find More Posts by u2builder
Old Jul 27, 2011, 06:56 PM
mt_flyer is offline
Montana Transplant
mt_flyer's Avatar
Joined Aug 2005
I have a saito 72 that needs bearings. Took the YS apart...rear bearing cage came apart....
I think I'm switching to electrons or sell it ALL
Old Jul 27, 2011, 07:11 PM
waynemia is offline
waynemia's Avatar
USA, TX, Springtown
Joined May 2008
Have you tried JB Weld??
Old Jul 27, 2011, 07:19 PM
David22 is offline
Find More Posts by David22
North vancouver, B.C. Canada
Joined Apr 2008
If you always get good signal in certain areas and constant poor signal in the same areas it most likely is outside inteference.
could also be the video tx antanna or the rx antenna not being aimed in that dirrection
you would be surprised how video can be made better if the patch or yagi is aimed
sometimes actually not dirrectly at the plane but sometimes off to the side as an example or up or down.
I put the patch on my head and aim it that way for best video results, and use a 3 or 6 dbi video omni for the video tx.
your rx's for video could also be not tuned the same and act differently and mess up the divercity controler
I like to keep it as simple as possable
this video was useing a 6 dbi omni but I prefer the 3 dbi because the 6 seems to be a bit rocky for reception.
wiggle tests also are a good idea to see if feed lines or connectors are a cause of poor video.
try turning around in the opposite patern or see if video is better going back to away from you.
figureing out fpv is not an easy thing todo
http://www.vimeo.com/26854002
new place maiden with ezstar (27 min 22 sec)
David22 is offline Find More Posts by David22
Reply With Quote  (Disabled)
Old Jul 27, 2011, 07:29 PM
SnowDog1974 is offline
Find More Posts by SnowDog1974
SnowDog1974's Avatar
United States, IL, Crystal Lake
Joined Jan 2009
went out with the tt40 today.... she made 2.3 flights... no photos
Call me slow; it took me a while to get this....at first I thought you meant 2 or 3 flights in a general way...then I read DaOldGuys post and realized my error. Sorry to hear about the TT
SnowDog1974 is offline Find More Posts by SnowDog1974
Old Jul 27, 2011, 09:50 PM
Joined Jan 2009
good think I wasn't planning on doing any night flying tonight...weather map attached; we;re having a fantastic lightning storm already.
Old Jul 27, 2011, 10:08 PM
WTurbiasz is offline
Find More Posts by WTurbiasz
Tree Flyer
WTurbiasz's Avatar
Albany NY
Joined Feb 2005
David Ill give these ideas a test and see what happens. For all my flights I used to use a directional antenna with a 9db gain and of course the signal was great in front of it and the farther you went out the more to the side you could be because the cone widens. But now all bets are off now so more testing is in order. Ill try the wiggle test on connectors as its possible that something is loose or not making a connection and Im just noticing it.
Tek
http://www.vimeo.com/26411132
WTurbiasz is offline Find More Posts by WTurbiasz
Old Jul 27, 2011, 10:52 PM
DaOldGuy is offline
Find More Posts by DaOldGuy
Flying Half Pound and Down
DaOldGuy's Avatar
United States, PA, Bellefonte
Joined Dec 2007
Some 4 Strokin Help please
I got this saito 80 on a trade, has new bearings, looks good. I have never run it in the year its been here. I notice a valve cover bolt is loose so I tighten it and it dont. What is a fella to do with something like this?
I was getting some stuff together to sell, if I aint used it in a year, its got to go. I wont sell this to someone in the manner I bought it, not knowing there is an issue, no matter how small. Thoughts?
I also have this FA30 off a Whale Tail, its like a super large Plane/glider polyhydral 80 inch wing plane. It was a running plane from an estate and I am converting to electric for a 8 year old friend. Not sure what this is worth.
Thanks in advance!
DaOldGuy is offline Find More Posts by DaOldGuy
Old Jul 27, 2011, 11:56 PM
David22 is offline
Joined Apr 2008
here is a video of the twist 40 doing a flat spin at about 1800 feet
this is the first time I ever actually flew a nitro plane fpv
it is very cool to feel the power comparrd to eletric gliders
I love the twist 40, fpv is even cooler for me when a fpv set up is on it
Waldo I went out tonight just for you, you do some cool and crazy things withthe twist 40
and so do I
twist 40v2 flat spin via fpv, os 46 ax (6 min 2 sec)
Help! Tower SUper Saver Club la528it Hot Online Deals 53 Sep 04, 2015 10:33 AM
Discussion New Club Thread - Northern Beaches Soaring Club Psionic001 Australia 13 Sep 11, 2014 07:45 AM
Discussion San Francisco Model Yacht Club's multi-club Swap Meet craig_c Dock Talk 17 Oct 13, 2009 02:28 AM
