Whatever you like that works. What receiver are you using? I would call and find out why those expensive, coreless servos won't take that voltage. BTW - If you put a reg/BEC (same thing) on set to 6V on the Life pack, it can only regulate as long as the input voltage is greater than 6V. I considered a regulator on my Corsair for the retract servo. I decided to just put a diode in the power lead of the extension going to it. ![]() Hitec Customer Service and Product Questions Ph: (858) 748-8440 Fax: (858) 859-2618 E-mail: service@hitecrcd.com |
Northwest Indiana
Joined Feb 2011
If you use 2200mAh lipos, here is a buddy code to get Nano-tech 2200mAh, 3S1P, 25 - 50C packs for $10.27 plus shipping, normally $17.75.
http://www.hobbyking.com/buddy.asp?c...C-1E4CD66AAF23 |
Latest blog entry: Southern Utah Huckin!
LVC soft set up and maybe one of the Lipo Warning beepers until you sort things out. I hope you can find the smoking gun, watt meter it and make sure everything is below limits, step back on the prop a little if needed. |
Latest blog entry: Weak Signals Toledo 2012
Northwest Indiana
Joined Feb 2011
Well, did some further troubleshooting at the LHS with my whole set up and brought a wing with the HS985....
Bottom line is the servo issue never went away. A regulator made it better but it was still there. Tried a new one in the box (probably from the same batch as mine...did it too. Even tried a different battery and an AR 800RX! We took a vid and sent it to hitec. Bottom line is I am exchanging them. Going with some HS5645 digitals...A bit cheaper but almost equal torque rating and very smooth. I tried several on my set up in the store and ZERO issues. Go figure. I am guessing a bad batch of servos. So, the build is on hold more or less until I get the 985's out and exchange them on Saturday. |
United States, OR, Gold Hill
Joined Aug 2005
Config(s) 3 Discharge(c) 25 Weight(g) 187 Max Charge Rate (C) 5 Length-A(mm) 106 Height-B(mm) 35 Width-C(mm) 24 am I reading this correctly a 5C charge rate "11 Amp charge" ![]() Wayne are you using these... mixed reviews... |
Once again myself being old school. I like to use an expaned voltmeter an be able to read my battery's voltage. With the Nimh I can check it anytime I want and not half to guess like you do with all the other type of batt's.
I'm running a hydramax 5cell 2000 mah on. my RX an servo's and I'm running a 4 cell hydramax 2000 mah And I can get several flight out of it with the Green Machine. Now the Green Machine has been calling my name all day but it was just one of those busy days. O Why can't I be rich an Retired, I buy one of those condo's in the AMA magzine that has it's own flying field. |
Edit: you have to be logged in to see the 10.27 price. Thanks Wayne I just ordered 3 of them
| Thread Tools | |
| Discussion New Club Thread - Northern Beaches Soaring Club | Psionic001 | Australia | 5 | Feb 24, 2011 08:19 PM |
| Help! Tower SUper Saver Club | la528it | Hot Online Deals | 9 | Jan 10, 2010 05:48 PM |
| Discussion San Francisco Model Yacht Club's multi-club Swap Meet | craig_c | Dock Talk | 17 | Oct 13, 2009 02:28 AM |
