Old May 27, 2011, 09:36 AM
SnowDog1974's Avatar
United States, IL, Crystal Lake
Joined Jan 2009
Originally Posted by kerwin50 View Post
I probably should of done the U bend on the throttle linkage when I put a magnum 70 on my brother's mustang.
I took the mummy wrappings of my thumb today. It only hurts when I put moderate pressure on it now. So I may be able to fly by sunday.
Heres some pic's of my thumb the next day after momma cleaned it up some before putting a new dressing on it.
I got 1 wing tip repaired on the MX but I still got to fix some minor cracks in the sheeting on the other wing's wing tip and an Aileron. then I got to repair a few holes in her. I'm now going to have to let the holes determine the decals.
I don't know if I can get this all done as I've been very busy. I had my grandson help me fix my brothers horn on his 260 Z and turn wrenches for me under my directions.
Now I'm getting swamped helping this guy clean carpets and flood damage. I gotta go to work later on this morning.
Kerwin,
That is a serious cut on the thumb...be sure not to rush the recovery! you don't want to get blood all over your transmitter if you get too jinky and bust open your stitches while flying.
I like the idea of the holes determining the decals! be sure to take a picture after the fixes!
Regards,
SnowDog1974 is offline Find More Posts by SnowDog1974
Old May 27, 2011, 10:21 AM
Do Da Dippidy
plowboy1966's Avatar
Joined Jun 2008
Wayne, the diaphragm is a definite possibility!
Eric, tighten that thing down while it's hot.
Why can't they get the throttles and mufflers right on four strokes? :walks away shaking head!:
plowboy1966 is offline Find More Posts by plowboy1966
Old May 27, 2011, 10:43 AM
A trail of smoke is GOOD!
waynemia's Avatar
USA, TX, Springtown
Joined May 2008
Originally Posted by rccardude04 View Post
Wayne, it's a fresh bottle of 30% heli fuel. It was much worse on 15%, to the point where I couldn't make it run an entire tank of fuel. I'm thinking about putting a check valve in the exhaust line just to see what happens. Problem is it'll flood like a mofo when the engine isn't running I'm sure.
I may just put new gaskets in everything and re-seal the crap out of the exhaust. I put some copper RTV on it the other day but it didn't seem to help. I did get anxious and fire it up before it was cured though.
brathanke: Yeah it's me. Another hobby to cost me money LOL.
-Eric
I would check the o-rings first. My Saito 1.25 never had an issue with the stock pipe.
My diaphram was OK, but the there was crap in the screen and I had to clean the needle seat.
waynemia is offline Find More Posts by waynemia
Old May 27, 2011, 10:48 AM
Cookies Good - Bacon Better
NoMatta's Avatar
Portland, Oregon
Joined Sep 2008
Plow - also check the line in the tank. Tygon will get stiff and not follow the fuel after a while. Tends to stay soft longer if kept in fuel, but most of us drain the tanks. I have seen it recommended to change the tank line each year and I think yours may be a couple old, Maybe??
NoMatta is offline Find More Posts by NoMatta
Old May 27, 2011, 11:01 AM
Death Spin or bust
Waldopepperaxe's Avatar
NY
Joined Jun 2008
RC That sure looks like fun I think you should drive it and have the passenger flying the course with a T_ _ _ T leading the way at the same time.
Welcome back David
Sorry to hear of high winds and crashes Wayne
No help from me on Saito 4 strokes YET I'm on my first one
Plow enjoy the family time.
Because the threads like this wouldn't exist.
Kerwin Good luck with all you have to do, Just don't use that Thumb for pulling out plums too soon
Brathanke It does look nice on there though
DOG When I put my Key in the OS 70 It shifted and I ended up damaging the prop hub in the back and cracked the shaft casing as I was wrenching the prop back on DOH!!! so be careful, I never had that problem ever in all my years but it only takes one time now I have to mention it. LOL
Waldopepperaxe is offline Find More Posts by Waldopepperaxe
Old May 27, 2011, 11:03 AM
Montana is Home by the Range
United States, OR, Gold Hill
Joined Aug 2005
Originally Posted by David22 View Post
I'm back
were you gone??
Just a scratch, eh plow
The half-moon thing is called a 'woodruff key' and is probably not too hard to find at a good hardware store somewhere if you look hard enough. I've never had to find one but it's a standard part usually.
Also, I went autocrossing again. http://www.youtube.com/watch?v=3ud7Q...el_video_title
I need to get this Decathlon done and off the bench so I can fix the tail on my Twist... I'm getting tired of flying the trainer with its lamesauce inconsistent Saito.
Speaking of which, anyone got ideas on that? My Saito 56 won't hold a tune. It's floating everywhere. I should probably put o-rings in it and I think it's got an exhaust leak but still... lol.
-Eric
I'm sure you have checked the valves, right?
mt_flyer is offline Find More Posts by mt_flyer
Old May 27, 2011, 11:14 AM
Do Da Dippidy
Joined Jun 2008
Kerwin did a good job on the thumb, gotta give him props!
3d NOOBular
brathanke's Avatar
USA, UT, St George
Joined Aug 2010
Ok guys so I tried to fire up the 91 FS a minute ago and it sounds like it will run but there is a fairly loud click right after the compression point that doesn't sound too good to me. It does it again a little further through the rotation. Does it need an adjustment or what? I'm afraid to really run it with that noise going on.
brathanke is offline Find More Posts by brathanke
Latest blog entry: Southern Utah Huckin!
Old May 27, 2011, 11:15 AM
Joined Jan 2009
Could be the valves need adjusting. You can find plenty of sources online for adjusting the valves.
Old May 27, 2011, 11:41 AM
Joined Aug 2005
make sure glow plug is not hitting piston...
Old May 27, 2011, 11:44 AM
waynemia's Avatar
USA, TX, Springtown
Joined May 2008
Yea, pull the valve covers and look at the rocker arms. Check the clearance and rotate it through a couple of times. Pull the plug to make it all easier. They don't make an audible click to me but I don't have the best hearing, especially at high freq.
If you don't have valve problems then you have to look at the cam/timing gear and the crank/bearings.
Old May 27, 2011, 11:45 AM
waynemia's Avatar
USA, TX, Springtown
Joined May 2008
At least the crashes were not my planes.
Old May 27, 2011, 01:02 PM
3.14159265358979323846264
rccardude04's Avatar
Wichita, Ks
Joined Jun 2005
Plowboy; I always tighten it while it's hot. It still leaks out of the muffler where it joins to the header, more than any other Saito I've owned.
Wayne; I'll prolly just go buy some o-rings. This pipe is more leaky than anything else I've seen on a Saito but you'd think it'd still be OK since I assume it's fairly consistent. Never know though. RC cars get PISSED OFF when there's even the slightest bit of exhaust leak.
-Eric
rccardude04 is offline Find More Posts by rccardude04
Old May 27, 2011, 01:08 PM
3d NOOBular
brathanke's Avatar
USA, UT, St George
Joined Aug 2010
false alarm guys it turns out I was just being dumb. The motor had been sitting for a while so it had tightened up some. Well I guess the first taste of new fuel and a kick from my starter was a little too much to ask for the first go around. It had backfired but I didn't notice that it had knocked the prop nut loose. That is what my clicking was coming from. I took the spinner cone off and tightened it up and the click is gone.
I got it running and tuned it up to the max rpms of about 10000 with a 15x4w. I feel pretty good about that... it pulls like no other. I think it ran out of fuel before I got it tuned properly and I had to run to work so next time I get it out I'll adjust it properly.
Sorry for the false alarm on the motor but thanks for all your help as usual.
-Nate
Old May 27, 2011, 02:38 PM
RC = Drama Free
DaOldGuy's Avatar
United States, PA, Bellefonte
Joined Dec 2007
Wayne... Waldo.....
Thanks for the info and tips
I took a chance at Lowes today, they have some small one, with my luck they wont fit right, had to try. To waldo's point, I aint forcing it to fit, that could be bad.
This Looks Fun!
Marugan Aero Meeting - Iberian Freestyle Championship - Teaser #1 (1 min 34 sec)
DaOldGuy is offline Find More Posts by DaOldGuy
Discussion New Club Thread - Northern Beaches Soaring Club Psionic001 Australia 5 Feb 24, 2011 08:19 PM
Help! Tower SUper Saver Club la528it Hot Online Deals 9 Jan 10, 2010 05:48 PM
Discussion San Francisco Model Yacht Club's multi-club Swap Meet craig_c Dock Talk 17 Oct 13, 2009 02:28 AM
