Old Feb 15, 2010, 10:22 AM
balsabuster2004 is offline
Find More Posts by balsabuster2004
balsabuster2004's Avatar
Washougal, Washington, United States
Joined Jan 2004
PC says "512 MB", System Properties says "384 MB". Guess I don't qualify as a nerd.
balsabuster2004 is offline Find More Posts by balsabuster2004
Old Feb 15, 2010, 10:31 AM
DaOldGuy is offline
Find More Posts by DaOldGuy
Flying Half Pound and Down
DaOldGuy's Avatar
United States, PA, Bellefonte
Joined Dec 2007
You can be nerdy, your PC is just having a Memory identity crisis.
Anyone looking for a Twist <Yellow and Purple> in Florida?
http://www.rcgroups.com/forums/showthread.php?t=1194306
DaOldGuy is offline Find More Posts by DaOldGuy
Old Feb 15, 2010, 10:32 AM
Joined Jan 2004
Waldo
Missing wood from the parts list - you deserve a flogging!
Old Feb 15, 2010, 10:39 AM
DaOldGuy is offline
DaOldGuy's Avatar
Joined Dec 2007
The short on 64 bit is for me is...
If you bought a PC with a lot <4 gigs or higher> of Memory, the OS will not see or use the memory without the 64 bit OS..
If you are not using applications that support and use 64 bit, nothing is gained other then the memory access.
Some applications will flat refuse to install or run of 64 bit.
There is not Flash for 64 bit IE explorer so Vimeo, Youtube and such you have to open and use the 32 bit Internet Exploder to see some media. The 64 bit OS launches 64 bit IE by default on Vista.
64 Bit really can allow applications like AutoCad to perform very well. Like me, my AutoCad 2009 is only a 32 bit install. So, since I have all this memory, I install Microsoft Virtual PC, build a Virtual 32 bit XP service pack 3 that I can run at the same time, install Autocad and all of my 64 bit unfriendly applications and with 2 gigs of ram dedicated to the Virtual OS, I am truely using all of my 4 gigs of Ram.
64 Bit really shines in high access server application.
Old Feb 15, 2010, 10:42 AM
gregory.da is offline
Find More Posts by gregory.da
ProBro, 3D
gregory.da's Avatar
United States, FL, The Villages
Joined Jul 2008
Let's change the subject...enough nerd talk. Anyone close to Miami? There is a T***T RTF in the for sale section.
gregory.da is offline Find More Posts by gregory.da
Old Feb 15, 2010, 10:48 AM
DaOldGuy is offline
DaOldGuy's Avatar
Joined Dec 2007
I just posted that too.
Old Feb 15, 2010, 11:02 AM
WTurbiasz is offline
Find More Posts by WTurbiasz
Tree Flyer
WTurbiasz's Avatar
Albany NY
Joined Feb 2005
Sorry for the noob question but perhaps someone here can point me in the right direction. I have this mount.
http://www3.towerhobbies.com/cgi-bin/wti0001p?&I=LXD628
and this engine
http://www3.towerhobbies.com/cgi-bin...&I=LXFMD5&P=ML
What I cant find for the life of me is what kind of screws do I use to mount the engine to the mount. I looked here
http://www3.towerhobbies.com/cgi-bin...rews&search=Go
and as you can see it kicks back every single screw imaginable and I have no idea what I should get. Some guidance would be very helpfull
Tek
WTurbiasz is offline Find More Posts by WTurbiasz
Old Feb 15, 2010, 11:10 AM
FIXXIN2FLY is offline
Find More Posts by FIXXIN2FLY
FLY ANGRY
FIXXIN2FLY's Avatar
United States, IL, Roscoe
Joined Jul 2008
Hey Tek, I used to have that setup and I just used four allen head screws and washers, Screws that are long enough to go thru the motor and mount and then used nylon locking nuts on the opposite end. Of course you have to carefully drill holes in the mount. Hardware store run is in order
You really dont need an expensive anti vibration mount for the 46 2 stroke but they are nice. I use them primarily for my 4 strokes that want to shake my planes apart
FIXXIN2FLY is offline Find More Posts by FIXXIN2FLY
Last edited by FIXXIN2FLY; Feb 15, 2010 at 11:15 AM. Reason: said hex head, meant allen head screws
Old Feb 15, 2010, 11:43 AM
Waldopepperaxe is offline
Find More Posts by Waldopepperaxe
Walk of Shame Season :)
Waldopepperaxe's Avatar
NY
Joined Jun 2008
Ditto ^^^^^^^
And I am aware a good flogging is in order ,,, A knights tale LOLOL
Waldopepperaxe is offline Find More Posts by Waldopepperaxe
Old Feb 15, 2010, 11:52 AM
plowboy1966 is offline
Find More Posts by plowboy1966
Do Da Dippidy
plowboy1966's Avatar
Joined Jun 2008
Yep, what Fixxin said. I also like to tap my mount for added protection if I can. It is really easy with the glass filed nylon mounts. I may have an extra one laying around for the Twist if you need it. No Sweat.
plowboy1966 is offline Find More Posts by plowboy1966
Old Feb 15, 2010, 01:24 PM
Tree Flyer
WTurbiasz's Avatar
Albany NY
Joined Feb 2005
Thanks for the help. Ill probably just go down to the hardware store and see what I can get and make it work.
Tek
Old Feb 15, 2010, 03:55 PM
waynemia is offline
Find More Posts by waynemia
A trail of smoke is GOOD!
waynemia's Avatar
USA, TX, Springtown
Joined May 2008
Hey Tek, I would save that for something else. Otherwise, I would drill/tap and put lock nuts or regular nuts with locktite on the other side. I think the bolts are #6 but I don't remember for sure.
waynemia is offline Find More Posts by waynemia
Old Feb 15, 2010, 04:27 PM
Joined Jan 2004
I've done this on many planes. Machine screws don't back out. Never had a problem yet.
Old Feb 15, 2010, 04:40 PM
waynemia is offline
waynemia's Avatar
USA, TX, Springtown
Joined May 2008
That mount has a lot of meaterial engaging the bolts. Most of the ones I see don't have that much so I use the nuts as a margin of safety.
Most of the time, I drill clearance holes and don't tap the mount. I have also seen wood screws used. I have done both the threaded mounts and bolt through. I won't do the wood screw thing though. It makes me nervous.
The motor mount broke on my TT40 on the last rough landing but all the bolts were in place.
Cool stuff
http://www.youtube.com/watch?v=sfeMLQNe57E
Old Feb 15, 2010, 05:15 PM
Do Da Dippidy
Joined Jun 2008
Tap the mount and use lock nuts when possible.
Help! Tower SUper Saver Club la528it Hot Online Deals 53 Sep 04, 2015 10:33 AM
Discussion New Club Thread - Northern Beaches Soaring Club Psionic001 Australia 13 Sep 11, 2014 07:45 AM
Discussion San Francisco Model Yacht Club's multi-club Swap Meet craig_c Dock Talk 17 Oct 13, 2009 02:28 AM
