Old Aug 30, 2010, 11:59 AM
waynemia is offline
Find More Posts by waynemia
A trail of smoke is GOOD!
waynemia's Avatar
USA, TX, Springtown
Joined May 2008
I think the airflow helps keep the burn rate slower. It also keeps the heat around the plane to a minimum. They designed this stuff for rc planes. Anyway, it was interesting to test it out. The switch I used is around $8. RC Switch
The switch needs a common ground with the output battery and receiver signal. The problem is, they don't give you ground connections for the switch side. Some people try to rig y-connectors and stuff but they are not current carrying wires and this switch can handle 10A. I take the shrink off the switch and add two ground wires on the PC board. This gives me a source ground and a load ground. I then shrink wrap it then put the label back on. I can then add a battery connector for the source and gound and the lead to the receiver. The receiver wire only needs signal and ground.
I made one of these as a remote ignition cutoff but we have not tested it yet. It is NOT optically isolated. If it were, the common ground would not be necessary.
waynemia is offline Find More Posts by waynemia
Old Aug 30, 2010, 12:07 PM
NoMatta is offline
Find More Posts by NoMatta
Cookies Good - Bacon Better
NoMatta's Avatar
Portland, Oregon
Joined Sep 2008
Originally Posted by harttvboy View Post
Hi all!
I posted a few days ago with what I should put in my 60 Twist (electric motor wise). I decided to go the Turnigy 50-55 580 KV route swinging (for starters) a 14x7 prop.
I am having a weird issue trying to use a watt meter though. See the pic with two batteries in series to reference. For some reason, ( I have not tried another pack yet) when I attempt to get a reading from my Astro Watt meter, its stops at 12.45 amps and around 240 watts. It will read batter voltage, and the motor will get to full throttle, but I can't get a reading. Any help here would be great- I am sure by guessing that I am within my limits ( I have another setup with this motor and a 13x8 prop that pulls about 70 amps-I dropped a pitch and increased length each by an inch-the worst is a 5 amp ish increase I would think...).
Enjoy these photos of the completed build-she doesn't get any stickers until AFTER a successful maiden day, hopefully tommorow!
Do you guys thing that with the above noted issue that it would be safe to fly? Let me know. I also could not seem to get the plane to balance with the 3.3 aH pack- I could just barely get it to 6 inches with the Hyperion 6s 5000 pack pictured as well. The Thunder Power pack is just another that is a hair lighter and will be more fun to fly with once I am used to the airframe. Let me know guys!
Best,
Chris
Another thing to check out would be to put a smaller prop on that setup temporarily and check again. If you are close to 70 amps on a 13-8, the 14-7 may exceed the limits on your wattmeter if it is rated at 70 amps. On larger props, it does not take much increase in diameter to add a lot of load. Sometimes I have found the increase to be suprising.
NoMatta is offline Find More Posts by NoMatta
Old Aug 30, 2010, 12:12 PM
waynemia is offline
waynemia's Avatar
USA, TX, Springtown
Joined May 2008
I agree. My thought was you would see the current increase as you added power and it would reach a limit point and maybe fall back to some value after it reached maximum. So mid throttle you would see some high amp reading like 30 to 40 and it would fall off as you continued to increase and passed 70A.
I would test the meter first. If it is OK, then the battery, connections, ESC, or motor is causing the problem. You could temoporarily plug in a different ESC to test that, I assume you tried more than one battery pack, the motor is hitting the RPMs? Anyway, that was my thinking.
Old Aug 30, 2010, 12:22 PM
plowboy1966 is offline
Find More Posts by plowboy1966
Do Da Dippidy
plowboy1966's Avatar
Joined Jun 2008
What's up fellas? What did I miss? I see a bunch of deleted posts.
Dave, nice flying. Sorry about the loss. What prop are you using?
plowboy1966 is offline Find More Posts by plowboy1966
Old Aug 30, 2010, 12:26 PM
DaOldGuy is offline
Find More Posts by DaOldGuy
Flying Half Pound and Down
DaOldGuy's Avatar
United States, PA, Bellefonte
Joined Dec 2007
Wayne, excellent info on the smokers! What would you say the % chances are of accidentally causing a "flaming ship"?
PB...um...your back already? What deleted posts?
DaOldGuy is offline Find More Posts by DaOldGuy
Old Aug 30, 2010, 12:36 PM
mt_flyer is offline
Find More Posts by mt_flyer
Montana Transplant
mt_flyer's Avatar
United States, TX, Sealy
Joined Aug 2005
Who is back....
Was someone gone??
mt_flyer is offline Find More Posts by mt_flyer
Old Aug 30, 2010, 12:42 PM
waynemia is offline
waynemia's Avatar
USA, TX, Springtown
Joined May 2008
Probably 0% if you install it correctly. There was no evidence of heat on the EZ*.
Old Aug 30, 2010, 12:43 PM
waynemia is offline
waynemia's Avatar
USA, TX, Springtown
Joined May 2008
What? I thought you moved?
Old Aug 30, 2010, 12:46 PM
Dave_45 is offline
Find More Posts by Dave_45
Joined Jul 2010
Plow,
13-4 APC sport
Dave_45 is offline Find More Posts by Dave_45
Old Aug 30, 2010, 12:48 PM
DaOldGuy is offline
DaOldGuy's Avatar
Joined Dec 2007
That is good to know. The price isn't too bad for the set up, Blenderm tape is the fix all for everything, it is the new DuckTape!
Thanks for putting this together, I shale provide video results. I am curious about the indoor ones, it really never said <that I noticed> if there was an required amount of indoor space, proper venting, and such...little nervous with that.
DaOldGuy is offline
DaOldGuy's Avatar
Joined Dec 2007
Originally Posted by Dave_45 View Post
Plow,
13-4 APC sport
I have grown to respect the APC Sport, even on my E - Twisted.
Old Aug 30, 2010, 02:28 PM
NoMatta is offline
NoMatta's Avatar
Portland, Oregon
Joined Sep 2008
Plow - The cowl is baffled, I'm confused, got to do a shut down in the middle of the night tonight, but I can bring you Extra over later in the week, like Wed or Friday evening. Got a Buckaroo meeting Thurs night. Patching my Edge now.
Later on.
Old Aug 30, 2010, 02:30 PM
mt_flyer is offline
Montana Transplant
mt_flyer's Avatar
Joined Aug 2005
ELECTRIC GURU'S QUESTION
I HAVE:
turngy 4240-900 rated 44amp
turngy 60amp ESC
4 cell 2200mAh 20C 44amp cont
with 12.25 x 3.75 prop, WOT is 36Amps
OK should work good
when i throttle up quickly from 1/4 to full I get a horrible squeal and no power, bogs down. When I go up slow it works fine.... any ideas??
i have tried changing timing no difference except for amp draw and rpm
Old Aug 30, 2010, 02:37 PM
Do Da Dippidy
Joined Jun 2008
Oh you boys are a regular riot! That's okay, if you're messing with me then that means you're leaving others alone. Consider it a public service.
Dave, I like that one too, but I also like the MAS 12 x 7 S2. I wish someone else would try it and let me know what they think.
Old Aug 30, 2010, 02:40 PM
DaOldGuy is offline
DaOldGuy's Avatar
Joined Dec 2007
I upped my timing to high and got rid of most of the squeal but not all. Then I jerked the APC-E Style prop off and went to a wood one and it was GONE. Then I switched to the APC Sport, no Squealing there either. I was supprised how much better things got after the prop change.
I HAVE:
turngy 60amp ESC
OK should work good
Help! Tower SUper Saver Club la528it Hot Online Deals 53 Sep 04, 2015 10:33 AM
Discussion New Club Thread - Northern Beaches Soaring Club Psionic001 Australia 13 Sep 11, 2014 07:45 AM
Discussion San Francisco Model Yacht Club's multi-club Swap Meet craig_c Dock Talk 17 Oct 13, 2009 02:28 AM
