Old Aug 26, 2010, 08:43 PM
plowboy1966 is offline
Find More Posts by plowboy1966
Do Da Dippidy
plowboy1966's Avatar
Joined Jun 2008
Originally Posted by mt_flyer View Post
I need HELP from the expert 4 strokers...
YS F-120... inverted mounted...
I have fuel comming out of the carb throat after system get pressurized...it leaks worst at low throttle, but you can still feel raw fuel in the propwash at high speed... after shutting down it drips alot from carb until I relieve the tank pressure...
any ideas?
You can either lower the tank height or run it a full throttle all the time!!
plowboy1966 is offline Find More Posts by plowboy1966
Old Aug 26, 2010, 08:48 PM
mt_flyer is offline
Find More Posts by mt_flyer
Montana Transplant
mt_flyer's Avatar
United States, TX, Sealy
Joined Aug 2005
same tank height.. just a different motor on same mount...full all the time not an option...
mt_flyer is offline Find More Posts by mt_flyer
Old Aug 26, 2010, 09:14 PM
rccardude04 is offline
Find More Posts by rccardude04
3.14159265358979323846264
rccardude04's Avatar
Wichita, Ks
Joined Jun 2005
Don't those have a pressure regulator in the carb? Maybe it's plugged or freaking out for some reason? I'm not really a YS expert but that's what I'd look at if my OS 70 started doing that.
-Eric
rccardude04 is offline Find More Posts by rccardude04
Old Aug 26, 2010, 10:53 PM
FIXXIN2FLY is offline
Find More Posts by FIXXIN2FLY
FLY ANGRY
FIXXIN2FLY's Avatar
United States, IL, Roscoe
Joined Jul 2008
Did you guys see this???? Wow!!!! Bet you cant predict this ending
http://www.liveleak.com/view?i=ab3_1282653276
FIXXIN2FLY is offline Find More Posts by FIXXIN2FLY
Old Aug 26, 2010, 11:03 PM
FLY ANGRY
FIXXIN2FLY's Avatar
Joined Jul 2008
any ideas?
Sounds like youre getting a siphon effect, Plow hit it on the head. Is the carb at a lower level than the last engine?
Wichita, Ks
Joined Jun 2005
Gawd that video is getting around a lot.
If the guy flying the slick wasn't such a damn tool it wouldn't be such a big deal. The whole situation was handled poorly. Hopefully they resolve the rc guy from the blame. I have my opinion on what happened but it's all speculation so ... oh well.
-Eric
Old Aug 26, 2010, 11:05 PM
Wichita, Ks
Joined Jun 2005
Originally Posted by FIXXIN2FLY View Post
Youre getting a siphon effect, Plow hit it on the head, lower the tank bro if you can
I thought the YS engines had a constant pressure tank though? Tank location could be 3 feet below the gear, at the tail of the plane and it should still feed pretty well.
Should also be able to put the tank up on top of Waldo's Twipe without it siphoning.
Am I wrong?
-Eric
Old Aug 26, 2010, 11:08 PM
Do Da Dippidy
Joined Jun 2008
Same height in relation to the carb? Hmmmm. Try the blow test (that don't sound right ) where you close the HSN and the LSN all the way and try to blow through it with a piece of tubing. Maybe something is not letting it seat all the way down. Try it with the throttle both open and closed fully.
Eric could be onto something there too. Aren't most regulators adjustable?
Old Aug 26, 2010, 11:09 PM
Do Da Dippidy
Joined Jun 2008
Man you guys are fast! Slipped in on me! lol
Old Aug 26, 2010, 11:10 PM
Do Da Dippidy
Joined Jun 2008
That blew up FG for about a week. Some folks wanted to cruicify the RC pilot. I blame the airboss.
Old Aug 26, 2010, 11:18 PM
mt_flyer is offline
Montana Transplant
mt_flyer's Avatar
Joined Aug 2005
cleaned regulator, gonna turn down the pressure and try again tomorrow... this is an older motor no LSN, regulator adjusts LS mixture... none of my other YS's have this problem... you can mount the tank anywhere with in 4 feet, hi, low, doesn't matter with YS fuel systems...uses 5-6 lbs of pressure in the tank
Old Aug 26, 2010, 11:26 PM
FLY ANGRY
FIXXIN2FLY's Avatar
Joined Jul 2008
Youre right, sorry I missed the YS part there, my bad. Sure seems to be alot of those modded OS engines still out there,
Old Aug 27, 2010, 01:59 AM
Wichita, Ks
Joined Jun 2005
PFFT! Please... I've never seen an OS as finicky as every YS I've ever seen... lol
-Eric
Old Aug 27, 2010, 05:56 AM
u2builder is offline
Find More Posts by u2builder
u2builder's Avatar
USA, NH, Alstead
Joined Oct 2007
I have a YS 110 that does pretty much the same thing after a flight. Pressure builds up in the tank and forces gas to drip out through the carb. I disconnect the the pressure line from the tank to relieve the pressure. I also have to disconnect this when filling though sometimes I forget. I don't feel as comfortable with this engine as with a Saito.
u2builder is offline Find More Posts by u2builder
Old Aug 27, 2010, 08:09 AM
waynemia is offline
Find More Posts by waynemia
A trail of smoke is GOOD!
waynemia's Avatar
USA, TX, Springtown
Joined May 2008
Nothing new to add......
waynemia is offline Find More Posts by waynemia
Help! Tower SUper Saver Club la528it Hot Online Deals 53 Sep 04, 2015 10:33 AM
Discussion New Club Thread - Northern Beaches Soaring Club Psionic001 Australia 13 Sep 11, 2014 07:45 AM
Discussion San Francisco Model Yacht Club's multi-club Swap Meet craig_c Dock Talk 17 Oct 13, 2009 02:28 AM
