Old Nov 17, 2012, 08:05 PM
A trail of smoke is GOOD!
waynemia's Avatar
USA, TX, Springtown
Joined May 2008
Originally Posted by David22 View Post
Twist planes come with nylon bolts
You guys change them to steel ones
I keep the nylon wing bolts. My twists had steel landing gear bolts.
waynemia is online now Find More Posts by waynemia
Old Nov 17, 2012, 08:12 PM
waynemia's Avatar
USA, TX, Springtown
Joined May 2008
Originally Posted by DaOldGuy View Post
Mothership is semi semtrical flat bottom? Yes, delamination is very possible, that is more a lifting wing <lack or proper words> so if the cord thickness is high, going into a elevator up, much of the airflow is skipping the control surfaces.. This would be a very good test for the things Joe Smith puts on the leading edge of his planes, in slower flight it disturbs the air flow to keep flow on the wing. That would be in interesting test.
Yea Ron, I think that is the issue. I plan to talk to Coby about a different airfoil for the EP Mother ship.
That said, it flies very well and stable as long as you don't try to go to warp speed. The extra speed allows me to to have a very good climb rate. It also needs help to hit that speed. If you pull back on throttle, even in a dive, you regain control pretty quickly. On mine, I know when I hit the point by the dive that starts.
Old Nov 17, 2012, 08:21 PM
Hardrock Miner
jacklegchris's Avatar
Livingston, MT
Joined Jun 2006
This has got to be the longest I've waited for a HK order to get here. Ordered around the 23rd of Oct and it still has not got here.
jacklegchris is offline Find More Posts by jacklegchris
Old Nov 17, 2012, 08:36 PM
North vancouver, B.C. Canada
Joined Apr 2008
Originally Posted by brathanke View Post
Wow lots of discussion
David you can also reduce blowback by making sure your servos have as much leverage as possible. To do this you need to maximize the end points in your tx so the servos are moving as far as the tx will push them. Then move the pus rod into the closest hole to the center that gives you the desired throw. You should try this before getting stronger servos.
This was set up first before all tests were done
Only exception was servo hole was not first but second hole
For eleven it is like number five hole out on arm
So leverage is max more or less
This os electric motor on Wayne's video what is story with that motor
I hear it is good one but heavy on watts
Does os now make electric motors as well as fuel engines
Are os 30 motors same manufacturer as os engines
Are both made in Japan
David22 is offline Find More Posts by David22
Old Nov 17, 2012, 08:39 PM
Joined Apr 2008
Originally Posted by snowman View Post
Blowback is necessary to eject the spent round and chamber the next....
Blowback is what you get when you pee into the wind.
Blowback is when you sneeze halfway through snorting a line. (So I've been told.)
Lol
Blowback is when you lift bed covers before you fart and then drop covers to smell fart
Lol
Old Nov 17, 2012, 08:49 PM
waynemia's Avatar
USA, TX, Springtown
Joined May 2008
OS - same as the IC engines - is selling electric motors now. Mine is NOT an OS. The OS motors have Harley Davidson prices on them.
My motor is a Turnigy G46, 670Kv. I measured 850W in flight on a 4S pack. My motor was $52.70. An OS .40 is $112.
Old Nov 17, 2012, 09:20 PM
RC = Drama Free
DaOldGuy's Avatar
United States, PA, Bellefonte
Joined Dec 2007
I dont have to wait for them any longer.
I ordered the Milled feather Light Osiris, there is over 20 feet of fine carbon in the kit. I didnt know that Fancy foam had the blenderm and other things sooo fair priced. Got a S3114 there also.
I also ordered the Diamond D47 Servos from the MFG, 19.99 for 4.7gram high torque. I have the new Hcker A10-15S already. I am very excited to fly something like this. Like I said, flying Arron's sort of woke me up to why nothing I have flys like the ones used at ETOC. Not that I have those skills, just the slow and float on rail behavior.
I ordered some NGK BRM6A plugs for the US Engine, the bird dog continues.
DaOldGuy is offline Find More Posts by DaOldGuy
Latest blog entry: Weak Signals Toledo 2012
Old Nov 17, 2012, 09:51 PM
Joined Apr 2008
Some political holiday
I also wait for stuff that usually is faster
Old Nov 17, 2012, 09:54 PM
Joined Apr 2008
I wonder still where os makes the electric motor
If in Japan I would like to try it out
As I find Japan makes nice stuff
Old Nov 17, 2012, 11:16 PM
kerwin50's Avatar
winston mo
Joined Oct 2006
DOG let me know how that dymond works out.
I've got a dymond tigermoth that thier D200 servo went out on causing me to loose the aircraft.
kerwin50 is offline Find More Posts by kerwin50
Old Nov 18, 2012, 12:36 AM
3d NOOBular
brathanke's Avatar
USA, UT, St George
Joined Aug 2010
Just finished up the repairs on the 70 slick. She has a bit more epoxy and some fiberglass cloth added in a few places. The rocks reaked havoc on the bottom of the fuse in a few places so some balsa needed patching up. I also took out the smoke pump. I think we are going to end up putting it in my friend Brigg's 50cc plane. We are hoping it will end up working out a lot better there.
I went with steel bolts this time for better or worse. I also went with larger wheels but I hate them fyi. The LHS didn't have any decent ones and these ones feel pretty flimsy and the foam tires squish down way too easy. I went with a 19x8 xoar this time... it was in stock. I'll miss the protek 20x8 that was a match made in heaven but the 19x8 was also pretty nice when I was using it before. Looking for some flights soon... possibly Monday.
brathanke is offline Find More Posts by brathanke
Latest blog entry: Southern Utah Huckin!
Old Nov 18, 2012, 07:56 AM
RC = Drama Free
DaOldGuy's Avatar
Joined Dec 2007
The D47 is the Competion Servo that is being used for ETOC by many of the pilots, I am not to worried about those. However, they dont use the bigger dymond for the Aileron and use a Futaba so it sounds like there may be problems with their other servos.
Old Nov 18, 2012, 09:02 AM
kerwin50's Avatar
winston mo
Joined Oct 2006
So that 4.7 gram servo blows all the other 5 gram servos away then.
I learn somthing new everyday.
Once again the wind is picking up and after working all last week I never got the twist up an flying.
O well none of my other buddies have planes that can fly in the wind.
Old Nov 18, 2012, 10:34 AM
RC = Drama Free
DaOldGuy's Avatar
Joined Dec 2007
[QUOTE=kerwin50;23298822]So that 4.7 gram servo blows all the other 5 gram servos away then.
QUOTE]
Its hard to spend 19 dollars on a 4.7 gram servo... but Arron reminds me that all the top people competing in ETOC and indoor comps are using them. It is difficult to argue with the voices in his head at that point. Having flown the plane it makes sense too.
Old Nov 18, 2012, 12:48 PM
waynemia's Avatar
USA, TX, Springtown
Joined May 2008
I doubt I will be competing or even attending one of those ETOC thingys. I guess that is why I keep using those HXT900 and HXT500 servos.
Way to go on the steel bolts Nate.
Discussion New Club Thread - Northern Beaches Soaring Club Psionic001 Australia 5 Feb 24, 2011 08:19 PM
Help! Tower SUper Saver Club la528it Hot Online Deals 9 Jan 10, 2010 05:48 PM
Discussion San Francisco Model Yacht Club's multi-club Swap Meet craig_c Dock Talk 17 Oct 13, 2009 02:28 AM
