Old Aug 30, 2012, 07:56 PM
DaOldGuy is offline
Find More Posts by DaOldGuy
Flying Half Pound and Down
DaOldGuy's Avatar
United States, PA, Bellefonte
Joined Dec 2007
Originally Posted by waynemia View Post
I have thought of that too but I can't see any evidence that this is happening. Maybe I will get a jar, put some fuel in and a chunk of tygon and see if there is anything that looks like deterioration.
Do you use Tygon on the Clunk tube? Many dont use it since it is stiff and put in other products and those I have seen do weird things. One member had some skinny black silicon or some other product, it shrank from 6 to 3 inches... He didnt know why it would only do short flights, could not see through the Dubro tank.
Originally Posted by Wookster View Post
first thing id do if i had one of those.......probably drop my phone into it.
Isnt that the truth!
DaOldGuy is offline Find More Posts by DaOldGuy
Old Aug 30, 2012, 08:07 PM
kerwin50 is offline
Find More Posts by kerwin50
kerwin50's Avatar
winston mo
Joined Oct 2006
I'm using the small tygon on the green machine
kerwin50 is offline Find More Posts by kerwin50
Old Aug 30, 2012, 08:11 PM
mt_flyer is offline
Find More Posts by mt_flyer
Montana Transplant
mt_flyer's Avatar
United States, TX, Sealy
Joined Aug 2005
I never landed full scale with the nose down.
At least, I don't think so.
sure you did.... a 172 @ 65-70kts will approach with 5-8* nose down all the way to flare
mt_flyer is offline Find More Posts by mt_flyer
Old Aug 30, 2012, 08:24 PM
DaOldGuy is offline
DaOldGuy's Avatar
Joined Dec 2007
I knew I had a motor simular to the one Snowy was fighting with. Bought this from the good folks at HK a while back, they no longer have it listed or a link to it... all I know is the discription is C2402 Brushless Outrunner 2350kv ....
No screw heads, looks easier to get the saver on it
Old Aug 30, 2012, 08:31 PM
seeingeyegod is online now
Find More Posts by seeingeyegod
seeingeyegod's Avatar
United States, OR, Portland
I just bought a big sheet of 3mm depron and a big sheet of 6mm depron. Trying to decide what to make out of it.
seeingeyegod is online now Find More Posts by seeingeyegod
Old Aug 30, 2012, 08:45 PM
Waldopepperaxe is offline
Find More Posts by Waldopepperaxe
Walk of Shame Season :)
Waldopepperaxe's Avatar
NY
Joined Jun 2008
Ok thanks for the link and continued advice guys after all of what your all saying I definitely need to open the tank and check all lines and the carb for sure, and I always shake the gas container before fueling
Snowman that came out Awesome Good luck tomorrow
I was disapointed the bike wasn't a video of the bike flying very cool idea but with a 40K price tag you think they would show it actually working and not just a pic with the lines erased that are holding it off the ground lol
Waldopepperaxe is offline Find More Posts by Waldopepperaxe
Old Aug 30, 2012, 09:08 PM
waynemia is offline
Find More Posts by waynemia
A trail of smoke is GOOD!
waynemia's Avatar
USA, TX, Springtown
Joined May 2008
But I did't LAND with the nose down.
In don't use Tygon in the tank any more. I use a high quality neoprene. So far, no problems. I have not had any Tygon harden either. I know people have reported that but I have been lucky so far. I have changed lines but they are still flexible. I usually change the lines if I have to remove the tank for something. I don't otherwise.
waynemia is offline Find More Posts by waynemia
Old Aug 30, 2012, 09:09 PM
waynemia is offline
waynemia's Avatar
USA, TX, Springtown
Joined May 2008
A dart board comes to mind.
I have always thought one of those flying discs would be fun. You might have to layer the Depron. You thinking indoor or outdoor.
I have a pizza box and flipflop. Working on a FireFly and have a Skycart in the box.
Old Aug 30, 2012, 09:19 PM
kerwin50 is offline
kerwin50's Avatar
winston mo
Joined Oct 2006
You may want to take that question to the flat foamie section.
Old Aug 30, 2012, 09:28 PM
DaOldGuy is offline
DaOldGuy's Avatar
Joined Dec 2007
Viton seems to be the new prefered product for inside that tank, that is what I have on the tank I posted the pic of. I had not heard of it, Arron seems to be running it on all his tanks with good luck. Lots of threads on FG about it as well.
Old Aug 30, 2012, 09:30 PM
waynemia is offline
waynemia's Avatar
USA, TX, Springtown
Joined May 2008
Checked the cowl. No way it will fit with the 100 on it. It might if I mounted it upright. The balance looks good at the spar. I wish I knew what the CG is supposed to be.
While mounting the swing to check balance, I discovered three of the four aileron hinges are broken. That is another set back. Glad I found it before going to the field.
Old Aug 30, 2012, 09:36 PM
waynemia is offline
waynemia's Avatar
USA, TX, Springtown
Joined May 2008
I have used that too but it is pricey. Thankfully, I only use it for the clunk.
Old Aug 30, 2012, 10:28 PM
NY
Joined Jun 2008
Wayne the CG for the Sig Kadet 80 inch Wingspan is 3 7/8 or 99mm from the leading edge if thats the spec you were looking for
Old Aug 30, 2012, 10:48 PM
NY
Joined Jun 2008
Hey Kerwin50 thanks for asking over on FG for me I thanked them over there as they were nice enough to give you some answers.
Old Aug 30, 2012, 11:37 PM
Bill Martins is offline
Find More Posts by Bill Martins
I just want to FPV!
Bill Martins's Avatar
United States, OR, Eugene
Joined Jun 2004
Viton Tubing
Yes, I have been using Viton on the clunk line for almost 3 years now. Doesn't get stiff, but is stiff enough to not fold over to the front of the tank. Is great for hooking up smoke oil lines to the muffler, as it is heat resistant.
Here's a link:
http://www.mcmaster.com/#standard-fi...tubing/=j2zik3
Part 5119K11. I usually get 5' at a time.
Bill
Bill Martins is offline Find More Posts by Bill Martins
Help! Tower SUper Saver Club la528it Hot Online Deals 53 Sep 04, 2015 10:33 AM
Discussion New Club Thread - Northern Beaches Soaring Club Psionic001 Australia 13 Sep 11, 2014 07:45 AM
Discussion San Francisco Model Yacht Club's multi-club Swap Meet craig_c Dock Talk 17 Oct 13, 2009 02:28 AM
