Old May 15, 2012, 08:06 PM
DaOldGuy is offline
Find More Posts by DaOldGuy
Flying Half Pound and Down
DaOldGuy's Avatar
United States, PA, Bellefonte
Joined Dec 2007
Originally Posted by snowman View Post
...and that was just plum crazy...so I'm going with a .91 four stroke.....Magnum I think. Too weak?
How about an OS BX-1 1.08?
DaOldGuy is offline Find More Posts by DaOldGuy
Old May 15, 2012, 08:10 PM
snowman is offline
Find More Posts by snowman
United States, MI, Houghton
Joined Jan 2005
*What follows is one of the stray thoughts that have become more prevalent as of late.*
The only reason why I'm hesitant in purchasing a 2.4gHz radio is that we have this HUGE tower ....that TOWERS over the surrounding area and has interfered with my 2.4gHz FPV gear in the past...will they let me return it if it don't work???? Yeah right, right?
snowman is offline Find More Posts by snowman
Old May 15, 2012, 08:12 PM
mt_flyer is offline
Find More Posts by mt_flyer
Montana Transplant
mt_flyer's Avatar
United States, TX, Sealy
Joined Aug 2005
Eric, don't be afraid to speak your mind or anything! I understand that the arc movement of the servo arm prevents a linear correlation, but my fingers don't know that....maybe I need to invest in a different radio to fully appreciate what you all are so eloquently sayin'.
The weather wasn't cooperating so the UCD got stripped to bare balsa...she's propped up against the shop wall all naked like...there's a certain beauty about her stripped of her cheap attire. The good news is there is absolutely no structural damage (that can't easily be repaired) , but now I've got to find a way to get those stubborn pieces of Monokote that are CA'd to the balsa around the hinges and everywhere assembly glue stuck to it! Any ideas.....I figure to sand a few bad spots and start covering tomorrow. I'm thinking I already had the ST2300 on her...and that was just plum crazy...so I'm going with a .91 four stroke.....Magnum I think. Too weak?
Beginning of the week....no flight reports? How many of you guys get to fly in the evenings after work? How many of you are weekend flyers? How many can only get out when their Honey-Do list is complete?
I "HAD" a mag91 4stroke on the UCD 60 originally... flew great for pattern.. WILL NOT HOVER BUT FOR a second or two... will not pull out if you get in trouble... 120 min for 3D on the UCD60
mt_flyer is offline Find More Posts by mt_flyer
snowman is offline
Joined Jan 2005
OS BX-1 1.08?????? Are you meaning....O.S. BGX-1 3500 Ringed w/Remote Needle Valve?????
Old May 15, 2012, 08:13 PM
snowman is offline
Joined Jan 2005
mt-flyer......thanks.....that's great to know!!!
Old May 15, 2012, 08:40 PM
David22 is offline
Find More Posts by David22
North vancouver, B.C. Canada
Joined Apr 2008
Now that's a chunk of lead
Tell me something......when you folks are talking exponential for 3D, are you talking about negative exponential that has the servo movement starting off "softer" and then moving greater as more "stick" is given? Dual Rates is for those that want to fly anything less than 3D no? Or is this exponential kinda like having the two without having to throw a switch? I guess to me that is dampening my inputs and is why I prefer it without.
Check out the piece of lead that had to be added to the tail to balance out the UCD with a ST2300 and 18" prop!
David22 is offline Find More Posts by David22
Reply With Quote  (Disabled)
Old May 15, 2012, 08:48 PM
snowman is offline
Joined Jan 2005
Well, David22......there was also an extra tank and accoutrements for a smoke system....I homemade smoke coil in the muffler, two 4.8v 2000mAh batteries and the 30oz ST2300 hanging off the front end.
After hearing mt-flyer's advice I'm wondering if I just shouldn't go back to the ST2300 without all the added weight and a smaller higher pitched prop...if that's at all possible. Course I would need some tuning advice from Wayne on the subject....he's the one that mastered the ST23000 was he not?
How about a UCD with floats??? Just a thought.
Old May 15, 2012, 09:05 PM
Dad_Roman is offline
Find More Posts by Dad_Roman
Twistaholic AMA 134406
Dad_Roman's Avatar
USA, TX, Teague
Joined Jul 2007
Dammit...now ya gonna make me interpret the manual
Quoted from my Tx manual: "The “exponentials” are in the same function as the dual rates. (Pressing the MODE key will take you to the next function which is End Point Adjustments). This means they function together and "EXPO" is always on! (Maybe set on -0- but on none the less) Low rates...expo is on. High rates....expo is on.
The same as dual rates, “expos” can be set for both switch positions. This is important. You can set the "Expo percentage" seperately for each switch position. A certain percent for low rates and a certain percent for high rates. Maybe -0- on low rates and -40 on high rates for 3D
Negative exponential(-) decreases initial servo movement.This is what we want....a decrease initially
Positive exponential (+) increases initial servo movement.Dont want this with Futaba
The exponential “curve” maybe set anywhere between -100% and +100%." Negative percentages with Futaba
I just don't get what they mean by" "exponentials" are in the same function as the dual rates"? Same as above. Dual rates is always on weather "low" or "high". These two switch settings are subject to expo setting applicable to each switch position be it -0- or an actual number.
I just want to see what all the fuss is about......I have had no problems flying 3D in the past with no expo and full throws. Anyone else own a Futaba T6EXA? (Don't laugh!)
Originally Posted by plowboy1966 View Post
Quoted for posterity.
That was friggen awesome wasnt it???
I give it to my wife at that point. Long fingernails and she love pickin at it all evening
Dad_Roman is offline Find More Posts by Dad_Roman
Old May 15, 2012, 09:09 PM
SnowDog1974 is offline
Find More Posts by SnowDog1974
SnowDog1974's Avatar
United States, IL, Crystal Lake
Joined Jan 2009
OK...how about this...I'll send you my Airtronics RDS-8000 and an RX...you try it in a beater aircraft...and if it works...you are good to go...you can get your own 2.4ghz system without worrying if it will work or not, and send me back my ATX system once you've got your own.
SnowDog1974 is offline Find More Posts by SnowDog1974
Old May 15, 2012, 09:17 PM
snowman is offline
Joined Jan 2005
DR, have patience with me.....remember I live in the sticks and don't get out in world much, I'm usually 5-10 years behind the times and with the exception of you good folks here in T_ _ _taholic land....misunderstanding reigns supreme, but I'm trying.
Old May 15, 2012, 09:18 PM
snowman is offline
Joined Jan 2005
SnowDog......what's this "beater aircraft" you're talking about?
That's a generous offer my friend, but I'll shell out the dough and purchase one.....if it don't work I'll sell it....I wouldn't want you to be without a spare.
How is that Airtronics RDS-8000? Does the programming take a degree in well, programming to program it?
Old May 15, 2012, 09:52 PM
jacklegchris is offline
Find More Posts by jacklegchris
Hardrock Miner
jacklegchris's Avatar
Livingston, MT
Joined Jun 2006
The one thing I don't care for on the rds 8000 is dual rate switches can't be on one switch. 2 separate switches for elev and aileron. If your looking for easy programing Snowman, you can't beat the Aurora 9.
jacklegchris is offline Find More Posts by jacklegchris
Old May 15, 2012, 10:13 PM
DaOldGuy is offline
DaOldGuy's Avatar
Joined Dec 2007
No....OS BX-1 1.08 with no remote needle.
Old May 15, 2012, 10:28 PM
snowman is offline
Joined Jan 2005
DOG...that engine isn't currently offered is it? They're going cheap on ebay. What's your experience with this engine?
Old May 15, 2012, 10:51 PM
Dad_Roman's Avatar
USA, TX, Teague
Joined Jul 2007
LOL....you must be dippin in the wine barrel today cause youve been RICH!!!!
I been laughin at you all day! (and I thank ya!)
We're gonna getcha through this bro!.....if it hairlips the kaiser!
Help! Tower SUper Saver Club la528it Hot Online Deals 53 Sep 04, 2015 10:33 AM
Discussion New Club Thread - Northern Beaches Soaring Club Psionic001 Australia 13 Sep 11, 2014 07:45 AM
Discussion San Francisco Model Yacht Club's multi-club Swap Meet craig_c Dock Talk 17 Oct 13, 2009 02:28 AM
