We just want to be careful guys. Mixing, Leccy and glow. Well ask K49. My self I'll throw alittle gasoline in the mixture. Then it's all a mind altering rush.
Waldo, Snowman I hope tings are going well. We're all waiting for some reports. Wayne are you going to post pic's and maybe a video of that set-up Eric it's great to see you posting and glad you could get that old twist out. Guys I'm getting ready to count down the days to the Slick convention http://www.rcgroups.com/forums/showthread.php?t=1487117 So Snowdog, DOG we'll see Joe Smith in action. I had a bit of an Issue on the Green Machine. I bought an RCExcel ign kill switch that was bad. I got it frome Valley ViewRC and they offered to replace it right away. The main thing is the Green Machine is on the bench getting ready for the Huck season. |
Latest blog entry: Weak Signals Toledo 2012
Larger prop, lighter bats so you can have more Mah then the 8S set up. Gas example... H9 260 35% pilot A is flying high speed aerobatics, some hovers, throttle is on full more then anything. 7-8 minutes and tank is low. Hand the same plane to Pilot B, who hovers/harriers/3D with some wide open throttle, 10 minutes flight time and still has a half tank of fuel. Those are real world number from our club. For Cramming in TONS of stick time, Gas is the Sniz, fill and go, fill and go. Most ESC's get smoked are ran at the edge of capacity. If your set up is spec'd to 75Amps and you Watt meter out at 70 amps static, you will smoke a 75 AMP esc. Installing a 90-100 amp esc will carry the spikes and things not seen in static tests. However, this is how a motor can get hot if your not careful. Prop changes... too big / too much byte a gas glow motor wont tune, a Leccy will spin it and before you know it, the magic smoke is out. Leccy is very sensitive to prop changes, even same size but different brand can make a difference. This Slick is a Leccy and on this verion the Canopy is diffent <longer> for battery access. There is a real good chance from that, Leccy will need to continue. I have heard on the other threads that the 71 AJ Slick motor box fits the Fantasy Blue older version, I may have to use one of those since the Electric motor box is not an option as a replacement right now. |
Do it DOG. If you still want to go electric you can have cmala make you some longer standoffs for your motor.
Good morning everyone
Latest blog entry: Southern Utah Huckin!
It's true that it doesn't take long to change a lipo. I'd say you are still going to get a lot more flight time on gas and probably better practice. For me, it takes longer than just changing a lipo to transition into the next flight. Having to land and change a lipo is an interruption in your focus. For some people, they want to land after 5 or 6 min anyway. For me, I would like to stretch my practice sessions out to 15 or 20 min. I think I'll be able to progress a little faster that way as I try to make a transition into learning some precision IMAC type stuff along with my regular need for down right huckin
So... that is why I want to go GAS. An of course, right now my hacker motor is giving me enough grief (Wayne) that gas is the greener grass
Leccy is great for IMAC comps, no points for noise, consistant throttle. Practice and Skill building with a gasser is great as Nate mentions, for casual flying, I get tired flying over 10 minutes any way, a proper leccy set up can get 8 minutes without a problem which is good for me.
Typically the Leccy sag as the pack starts to run dry is enough warning for me to land, gas and glow.... when its out... its OUT. |
| Thread Tools | |
| Discussion New Club Thread - Northern Beaches Soaring Club | Psionic001 | Australia | 5 | Feb 24, 2011 08:19 PM |
| Help! Tower SUper Saver Club | la528it | Hot Online Deals | 9 | Jan 10, 2010 05:48 PM |
| Discussion San Francisco Model Yacht Club's multi-club Swap Meet | craig_c | Dock Talk | 17 | Oct 13, 2009 02:28 AM |
