Holy Crapola man it just took me about an hour and 1/2 to catch back up here, It was the wifes B-day weekend so we've been busy, took down all the decorations and re arranged the Living room on her wish at the last 2nd last night LOL but all is now well and the building season can begin for me
![]() Kerwin sorry to hear of the destructions I'm sure you'll have them back up and running soon. David I always love those snow vids to watch LOL and yes the new e plane is close to to the Twirp design lol Wayne awesome vids also, you been a happy flying boy. Dad great shop for sure,, I have a long way to go lol Quote:
![]() When I built the Twirp I screwed up and sheeted the tail feathers for extra strength, just cause I thought it might need it, she came out way too tail heavy for an electric motor As I just couldn't get enough weight in the nose with the smaller fuse well I did eventually but didn't like the way it handled at all. Heres a couple vids of the Twirp in action
Yes me too LOL I plan to upgrade to 2.4 when I get the money to buy a new box but right now my old 72mhz works just fine so I plan on spending the money on planes and engines
that just took me by surprize when I heard that. My cuz just bought a new 2.4 Futaba system so I'll have to warn him about that if its true.I've always wrapped my rx's in foam for vibration/security reasons. thats a tough habbit to break I'm sure many of my 100mph straight in crashes would have damaged the rx's if they weren't protected in foam. so if thats the case I'll have to control my urge to slam my planes into the ground
I found the following post on Futaba's website regarding the foam/no foam question:
http://www.futaba-rc.com/techsupport/receiver-tips.html Quote:
So how much heat builds up in an RX anyway? I had never thought that there would be any heat build up inside an RX...? I think I'll keep wrapping my RX's in foam for now. |
Yeah already used blue loctite everywhere. The double side tape I use is strong stuff. Maybe I'll just let it ride and see how it goes. But my guy is telling to use velcro, as it should provide (although not much) some vibration dampening. Anyway use green loctite? I have a bottle and not sure if it's stronger or less stronger than Blue.
Different 2.4ghz systems work differently; I don't own a system that requires a satellite RX so I can't speak to those. For Airtronics, there are two antenna leads; they are required to be placed at a 90 degree orientation from each other. That is the only requirement. If I can't figure that out and orient the two antenna leads to conform to that requirement, then I probably shouldn't be flying an R/C airplane in the first place. Oh yeah, and then there's this thing called a field check which includes a range check? Should be done for 72mhz and of course should still be done for 2.4ghz. Yeah spektrum Rx's are mounted the same way. |
We had a Club Meeting presentation last week over 2.4 and much of the discussion was not putting RX <2.4 and 72> due to them over heating in the foam. I personally have been using the most plush pile side of the velco for the RX to sit on, not strapping it down, so the pile bleeds off the vibrations and shock. If the wires are gathered securely, in a crash this would be a second catch "if" the rx hook velco where to come loose from the pile.
Latest blog entry: Weak Signals Toledo 2012
When you look at heat disipation with hard plastic, the case could naturally bleed of the heat without venting, once in cased in foam that would limit this. I dont like the RX being located in direct sunlight through the canopy either. Again, this is all personal preference I have adobted from different sources and my feel about heat. Heat can cause so many issue both short term and long term.
| Thread Tools | |
| Discussion New Club Thread - Northern Beaches Soaring Club | Psionic001 | Australia | 5 | Feb 24, 2011 08:19 PM |
| Help! Tower SUper Saver Club | la528it | Hot Online Deals | 9 | Jan 10, 2010 05:48 PM |
| Discussion San Francisco Model Yacht Club's multi-club Swap Meet | craig_c | Dock Talk | 17 | Oct 13, 2009 02:28 AM |
