Old Mar 04, 2010, 10:21 PM
David22 is offline
Find More Posts by David22
North vancouver, B.C. Canada
Joined Apr 2008
One day i would like to try the 123's
going back to electrics for a week or two
gliders are my real passion
chargeing up batteries now
going for f5b type flying as long as the sun don't shine
i need lots of space to zoom around and the sun makes it not worth the flight time
gets right in the way
then back to fpv
where the sun or clouds or night don't make a difference
Love to jump around from plane to plane
twist 40 with 46 is still my favorite plane
David22 is offline Find More Posts by David22
Reply With Quote  (Disabled)
Old Mar 04, 2010, 10:35 PM
3dwingnut is offline
Find More Posts by 3dwingnut
certifiably twisted
3dwingnut's Avatar
Damascus,Ar.
Joined Jan 2010
Fpolitics, lets just do some ho-down style flying!
3dwingnut is offline Find More Posts by 3dwingnut
Old Mar 04, 2010, 10:36 PM
rccardude04 is offline
Find More Posts by rccardude04
3.14159265358979323846264
rccardude04's Avatar
Wichita, Ks
Joined Jun 2005
LiFe rx packs are FTW
A little more nutz than 5-cell NiXX, and no regulator to fail on you. Pretty much awesome.
-Eric
rccardude04 is offline Find More Posts by rccardude04
Old Mar 04, 2010, 10:43 PM
David22 is offline
Joined Apr 2008
are these the ones?
http://74.125.155.132/search?q=cache...&ct=clnk&gl=ca
-Eric
Old Mar 05, 2010, 06:39 AM
bracky72 is offline
Find More Posts by bracky72
Questionable judgement
bracky72's Avatar
Charles Town, WV
I have not used those but I see no reason why they are bad. Generally though A123 is considered the best LiFe cell.
I got a great deal on a bunch of black and decker vpx batteries which use a123 so I make my own.
I would not use 5 cell or a123 rx packs with Thomas' LRS. He indicates a max of 6 volts which both of these packs exceed when fully charged. Both work great with spektrum and fasst receivers though.
bracky72 is offline Find More Posts by bracky72
Old Mar 05, 2010, 07:51 AM
David22 is offline
Joined Apr 2008
the specs for thomas' is no more than 9 volts
he indicates 5 cells is ok?
been useing thomas' system with 7.2 volts for two evenings now
no problem so far
I did not know the life rx packs were 123 type?
The problem for me is if i go to 123's i need to buy another charger
Old Mar 05, 2010, 08:32 AM
waynemia is offline
Find More Posts by waynemia
A trail of smoke is GOOD!
waynemia's Avatar
USA, TX, Springtown
Joined May 2008
All batteries charge to a higher non-loaded voltage than they are rated for. They quickly burn that off to the nominal rated voltage.
5 cell packs are well worth it in torque and speed. (We did recommend them)
Life or a 5 cell pack is a better option than an Lipo and regulator with fewer fail options.
Here is an inexpensive charger that will charge all your electron buckets. http://www.hobbycity.com/hobbycity/s...idProduct=7028
I think you will be happy with the lighter tt60. I would reconsider changing the engine until you get all the other stuff out. I recommend changing one thing at a time so you can observe the results of that change.
If you go two stroke on the TT60 a 61 probably would not be the best alternative. I have a 91FX on mine. If you want more speed on the tt60, increase the pitch. If you want super speed, then a 95AX or at least a 75 would be a better match. JMHO.
waynemia is offline Find More Posts by waynemia
Old Mar 05, 2010, 08:37 AM
David22 is offline
Joined Apr 2008
thanks for the link
Ok I will keep the engine
speed is not what i want
I was looking for the characteristics of the twist 40 and 46 combo
light and feathery
No way I could enter the twist 60 the way it is, so heavy, into the "ho down" lol
If you go two stroke on the TT60 a 61 probabbly would not be the best alternative. I have a 91FX on mine. If you want more speed on the tt60, increase the pitch. If you want super speed, then a 95AX or at least a 75 would be a better match. JMHO.
Old Mar 05, 2010, 08:42 AM
plowboy1966 is offline
Find More Posts by plowboy1966
Do Da Dippidy
plowboy1966's Avatar
Joined Jun 2008
Originally Posted by NoMatta View Post
Stirrin' the pot a bit, eh Plowboy
Once a scrapper...... I'll be good.
Yeah David, what Wayne said. Give that plane and engine combo a chance without the cg machine and the smoke system. Make it light and powerful and you will win the ho down with her.....maybe.
plowboy1966 is offline Find More Posts by plowboy1966
Old Mar 05, 2010, 08:48 AM
David22 is offline
Joined Apr 2008
I do as you recommended long ago Plow
take off the cg machine
But it would be a miracle if I ever get out of third place in the ho down lol
Old Mar 05, 2010, 08:50 AM
bracky72 is offline
bracky72's Avatar
Charles Town, WV
no problem so far
Thomas indicates a input voltage of 4-6 for every receiver on his webpage. Not sure what the kill voltage is.
http://www.webx.dk/rc/uhf-link3/uhf-link3.htm
Do Da Dippidy
Joined Jun 2008
No, it'll be a miracle if you stay in third place!! just kidding.
Old Mar 05, 2010, 08:54 AM
David22 is offline
Joined Apr 2008
HARDWARE RX UNIT (version 3.30 RX NR Normal Range for visual flights)
The RX unit is designed for 4-6V supply (4 -5 nimh cells or 5V BEC)
Full performance is expected in the 4-6V range
Supply current at 5V = 20mA
RF senstivity = -102 dBm at 10% BER (or better) Normal Range type
Damage will ocur if reverse supply voltage and if supply is higher than 9V.
The Normal range RX have no LED indicators
Wire antenna on the board.
Old Mar 05, 2010, 08:56 AM
David22 is offline
Joined Apr 2008
Thats just me being a bad boy to get others to post "ho down "vids hehehe
But it is only slowly working
waynemia is offline
waynemia's Avatar
USA, TX, Springtown
Joined May 2008
David - The Saito 1.25 is about the same weight as my 91FX but it can swing a 16x4W prop with authority and trumps my 91FX in my opinion. Give it a go before you let it go.
If you want to fire sale that 1.25, I want it.
Help! Tower SUper Saver Club la528it Hot Online Deals 53 Sep 04, 2015 10:33 AM
Discussion New Club Thread - Northern Beaches Soaring Club Psionic001 Australia 13 Sep 11, 2014 07:45 AM
Discussion San Francisco Model Yacht Club's multi-club Swap Meet craig_c Dock Talk 17 Oct 13, 2009 02:28 AM
