Old Sep 02, 2011, 11:29 PM
Outlw36 is offline
Find More Posts by Outlw36
Prineville Oregon
Joined Jan 2007
Originally Posted by NoMatta View Post
Now that I like. Always wondered about the Fox gassers. Always loved my glow engines. American made???
Don't think I could get in my Camaro, though
Just strap it on the roof after you have the rest of the car filled lol
Outlw36 is offline Find More Posts by Outlw36
Old Sep 02, 2011, 11:36 PM
3DNater is offline
Find More Posts by 3DNater
3d NOOBular
3DNater's Avatar
United States, NV, Las Vegas
Joined Aug 2010
wow guys I totally missed your posts about your new planes. Congrats!
3DNater is offline Find More Posts by 3DNater
Old Sep 03, 2011, 12:25 AM
waynemia is offline
Find More Posts by waynemia
A trail of smoke is GOOD!
waynemia's Avatar
USA, TX, Springtown
Joined May 2008
You do fine, Wayne. I presume you have either self educated yourself on electrics, or have a background in the subject. I'm an electrician of 45+ years as well as an instructor for 18. I know that sometime it seems we deal in witchcraft, but your on-off switch analogy is dead on for BLDC motors. I think some run into a confusion with brushed motors where speed is voltage (and load) determined, since the commutation is by the brushes, where our brushless motors are electrically commutated and the speed is controlled by the speed of the pulses from the ESC.
Probably won't have a new prop for the Edge tomorrow, so I'll likely fly the eYak and my T150. Go by the hobby shop on the way and pick up the prop, but won't be able to drill it without coming home to the drill press.
Later on
I have an AS in electronics, Extra class Ham ticket, completed an extensive communications electronics program, and have worked in test set design for telephone systems.
The watts is average and simply multiplies Voltage X Current for you.
Yes, the windings are inductive and they do create a counter voltage. In fact, the ESC uses the counter voltage to determine motor position. If you have ever heard of a sensored motor, it uses sensors in the motor to detect the motor position. Most of the ones we use are sensorless and use the counter voltage.
When you apply a voltage to a coil, a magnetic field starts to expand. The coil resists this expansion by creating a counter voltage. The same thing happens when you turn the voltage off. The coil creates a voltage in an effort to keep the field expanded.
Essentially, this means you don't have a neat square wave when you apply a pulse to an inductive (coil) load as you would with a purely resistive load.
I left all that out because is is a bit harder to swallow in one chunk.
Like I said, I will try to set up a demonstration with three traces on an o-scope next week.
waynemia is offline Find More Posts by waynemia
Old Sep 03, 2011, 12:39 AM
3DNater is offline
3d NOOBular
3DNater's Avatar
Joined Aug 2010
sweet... Now for a little more application... I was just wondering... since the amps/watts are averages... even though you can get a surprisingly high current as it goes along heat is the main concern. So if I'm at 10% throttle and the motor is only firing 1/10 as often as at full throttle wouldn't I also get 1/10 the heat creation as well?
My point is... if heat is the main concern I'd think the motor would function heat wise similar to a normal brushed motor. Even though one is drawing constant current and the other is pulsing the average amount of heat created should be similar. In fact the brushless motors, being more efficient should be better at NOT losing a lot of energy through heat.
Can I just figure something like limits in calculus and treat the average amps/watts my esc is pulsing to the motor as though it ISN't pulsing since it is happening so fast anyway and revert back to the basic electrical equation? A*V=W?
Old Sep 03, 2011, 05:50 AM
kerwin50 is offline
Find More Posts by kerwin50
kerwin50's Avatar
winston mo
Joined Oct 2006
Your Fox gassers are based off the sachs engine. Knowing Fox they are no doubt a fine engine. You could always do like plowboy and strap it to the top of your camaro LOL
kerwin50 is offline Find More Posts by kerwin50
Old Sep 03, 2011, 06:11 AM
kerwin50 is offline
kerwin50's Avatar
winston mo
Joined Oct 2006
Well said Wayne, it is a very compilcated subject. AC theory can be quite in depth and the math daunting especially when we start talking about impedance
Old Sep 03, 2011, 06:17 AM
kerwin50 is offline
kerwin50's Avatar
winston mo
Joined Oct 2006
Old Sep 03, 2011, 07:59 AM
waynemia is offline
waynemia's Avatar
USA, TX, Springtown
Joined May 2008
First, let me say I am not a motor expert and definitely not well versed in thermal dynamics.
We have been talking about the current and so forth in a single winding in a motor. A brushless has three winding and the voltages are fed to the windings 120 degrees out of phase from each other.
As for heat, heat is generated then it has to have a place to go for it to dissipate. The heat builds up in the motor and needs to be radiated for it to be removed. So even though you may not be continuously heating the motor, the heat builds up to high levels if there is no way to eliminate it.
One comment is that heat is an issue and needs to be removed by adequate motor design and cooling air, I don't know if you would consider it the main concern.
Many electronic components are voltage sensitive. They have barriers that can fail catastrophically if the voltage is exceeded. Electrolytic capacitors have voltage ratings for example. If you exceed the voltage, they can break down and explode when they short internally and massive amounts of current flow. Diodes also have a maximum current rating and a peak inverse voltage limit. if you exceed these, sometimes for short periods of time, they can fail and usually open like a fuse. The FET transistors that are used as switches are the same way. You can exceed their voltage limits and the transistor can fail.
Transistors and diodes work on positive and negative barriers to control current flow. They can fail by running too much current through them or by applying too much voltage which causes the barriers to fail.
I see people that say they are using a 5S pack with an ESC rated for 3S. This is asking for an ESC failure. Parts for higher voltage are usually bigger and more expensive. If my design parameters are for 3S, I may design the circuits with voltage ratings of 15V absolute maximum. A fully charged 4S lipo is typically 16.8V so parts would fail.
Years ago, our design parameters in the US were 2x. So if I needed 12V I would build for 24V. International designs may only allow for 10% or 20%. This made US designed equipment more expensive but it lasted longer and could take more abuse.
I am not sure that is the case today. The push for smaller devices limits how much you can over-build.
Also, the circuit boards have traces on them, almost always in multiple layers, that have voltage and current limits. Exceeding voltage ratings can cause arcing in high density boards. This is not a big deal for logic boards but analog boards are a concern since you can't control what a user is going to do on the input/output.
Also, there are a lot of losses in a motor and ESC that don't do anything to help turn a prop.
By the way, I found this website with a lot of rc model information I found interesting.
http://adamone.rchomepage.com/index.html
CRFan1 is offline
Find More Posts by CRFan1
Northwest Indiana
Joined Feb 2011
Well, I maidened the Extreme Flight Edge 540 yesterday and all I can is holy crap that thing is fun!!!!
On high rates it does everything you can imagine but it is such a stable plane for it's size. It is rediculous how it just keeps flying no matter how slow you get, lol. Even did a knife edge loop with it, lol
The combo from EF seems spot on. Right now, I have the timer set at 6 Minutes and after 6 minutes of aggressive flying, the battery comes out slightly warm, and the motor is not too hot to keep your finger on (although it is warm). Hooking the batteries up to the charger generally shows them at 3.82volts per cell - I don't remember how many milliamps though (I am getting old and senile, lol). I could probably go a bit longer on flight time but will stay there for now.
On a side note, I did order a watt meter so I will have dfinites soon enough
CRFan1 is offline Find More Posts by CRFan1
Old Sep 03, 2011, 08:13 AM
gregory.da is offline
Find More Posts by gregory.da
ProBro, 3D
gregory.da's Avatar
United States, FL, The Villages
Joined Jul 2008
A little off the 3D or Twisties, but have any of you guys seen this airplane? Can't believe they are selling a plane this size for $140. Looks like a nice frame for a small gasser, and would make a nice relaxing sport flyer.
http://www.advantagehobby.com/103080/SEA5525/
gregory.da is offline Find More Posts by gregory.da
Old Sep 03, 2011, 08:17 AM
Outlw36 is offline
Prineville Oregon
Joined Jan 2007
my guess is it is now on the discontinued list. Paid about the same at Horizon when I got my twist 1.50 .
Old Sep 03, 2011, 09:37 AM
kerwin50 is offline
kerwin50's Avatar
winston mo
Joined Oct 2006
Once again well said Wayne, if people only knew the 1/2 of it would they really stress thier electronic eq that way.
Try running your car engine on 1 quart of oil
Old Sep 03, 2011, 09:47 AM
DaOldGuy is offline
Find More Posts by DaOldGuy
Flying Half Pound and Down
DaOldGuy's Avatar
United States, PA, Bellefonte
Joined Dec 2007
I really hate aggitated electrons, they dont perform well, they make noise, waste energy, and kill a fella's G Factor.
"Who aggitating my dots?"
DaOldGuy is offline Find More Posts by DaOldGuy
Old Sep 03, 2011, 09:52 AM
mt_flyer is offline
Find More Posts by mt_flyer
Montana Transplant
mt_flyer's Avatar
United States, TX, Sealy
Joined Aug 2005
14 days to DOG's flyin....
mt_flyer is offline Find More Posts by mt_flyer
Old Sep 03, 2011, 11:22 AM
balsabuster2004 is offline
Find More Posts by balsabuster2004
balsabuster2004's Avatar
Washougal, Washington, United States
Joined Jan 2004
Texas guys...
Low temperature here last night at my house was 48 degrees!
balsabuster2004 is offline Find More Posts by balsabuster2004
Help! Tower SUper Saver Club la528it Hot Online Deals 53 Sep 04, 2015 10:33 AM
Discussion New Club Thread - Northern Beaches Soaring Club Psionic001 Australia 13 Sep 11, 2014 07:45 AM
Discussion San Francisco Model Yacht Club's multi-club Swap Meet craig_c Dock Talk 17 Oct 13, 2009 02:28 AM
