Old Jan 17, 2010, 10:35 PM
WEREE is offline
Find More Posts by WEREE
WEREE's Avatar
United States, CA, Fremont
Joined Dec 2008
Question
Hitec Aurora 9 Transmitter & FPV Head Tracking
I've been reading a lot of good things about the new Aurora 9 transmitter.
Question. Does anyone know definitively if this Aurora 9 can be used for FPV head tracking? That is, can I attach a head tracking unit into the trainer port and have its two channels mapped to any two outputs on the receiver? Typically, these two signals are then sent to the pan and tilt servos.
Futaba seems to reign supreme in this programmability aspect. I've only heard the higher-end Futabas being used in FPV head tracking. Yet, it doesn't seem to be that complex a feature -- just a software routing feature? Is there no other transmitter I can even consider other than these high priced Futaba units?
WEREE is offline Find More Posts by WEREE
Old Jan 18, 2010, 01:05 AM
A.T. is offline
Find More Posts by A.T.
Joined Aug 2002
Aurora 9 pin-out of the trainer connector and FPV
Originally Posted by WEREE View Post
I've been reading a lot of good things about the new Aurora 9 transmitter. Question. Does anyone know definitively if this Aurora 9 can be used for FPV head tracking? That is, can I attach a head tracking unit into the trainer port and have its two channels mapped to any two outputs on the receiver? Typically, these two signals are then sent to the pan and tilt servos. Futaba seems to reign supreme in this programmability aspect. I've only heard the higher-end Futabas being used in FPV head tracking. Yet, it doesn't seem to be that complex a feature -- just a software routing feature? Is there no other transmitter I can even consider other than these high priced Futaba units?
Hitech Aurora 9 pin-out of the trainer connector and the module plug in connector? thread on manufacturers forum may assist..
Aurora A9, Spectra Pro & Optima - FAQ & Undocumented Features - Mixes, Setups, Tips. {frequently updated]
Possibly some information under sub section "Photography by RC, FPV, Spraying by RC and Wireless Video RC." at
Alan's Hobby, Model & RC FAQ Web Links may also assist.
Regards
Alan T.
A.T. is offline Find More Posts by A.T.
Old Jan 18, 2010, 01:12 AM
renatoa is offline
Find More Posts by renatoa
Romania, Dolj, Craiova
Joined Sep 2007
Unfortunately, NO
http://www.rcgroups.com/forums/showt...v#post14046303
Could be the radio with the greatest range I know so far, more than 4km, but this feature lack limits it severe for FPV usage...
renatoa is offline Find More Posts by renatoa
Old Jan 18, 2010, 02:24 AM
WEREE is offline
WEREE's Avatar
Joined Dec 2008
Originally Posted by RENATOA View Post
Unfortunately, NO
Such a shame the Aurora 9 being so new and sophisticated can't do head tracking. Well the Aurora 9 is off the list as a candidate for upgrade from my current Spektrum radio. Now I have to spend a large wad of money on a Futaba radio to do head tracking. Ah well, I guess I gotta make more money.
Old Jan 18, 2010, 04:15 AM
renatoa is offline
Joined Sep 2007
If you accept my advice, the best bang for the bucks in this moment is a second hand T9C ($150-$200) with the Hitec 2.4 GHz system fitted inside ($200 for Tx module and two 9ch Rx)
At least this is my actual setup, and no ideea for an even distant future upgrade.
Also, I would avoid touch screens of any brand
Old Jan 18, 2010, 02:16 PM
WEREE is offline
WEREE's Avatar
Joined Dec 2008
Good tip. The 9C was just after the Aurora 9 on my list. Do you use the Hitec 2.4GHz system because the Hitec receivers are cheaper, longer range? I'm not familiar with Hitec radio stuff.
Old Jan 18, 2010, 02:26 PM
renatoa is offline
Joined Sep 2007
Ah, not at all, bought one set only to evaluate it. Not sure if to keep it or not.
Was a long time Hitec fan, in my local community I am the Hitec guru, but probably will make a step back.
For FPV I use 35MHz RC exclusively, and, if any switch, probably will be toward to a 433/868MHz system. FM RC and GHz video is the winner combination for FPV.
Discussion Hitec Aurora 9 Transmitter prondel Radios 26228 Today 04:54 PM
Sold HiTec Aurora 9 2.4 Ghz with two 7 ch Rx - brand new Cloud_Catcher Aircraft - General - Radio Equipment (FS/W) 5 Jan 08, 2010 11:04 PM
Discussion What transmitter are you using with your head tracking device? AgentCow007 FPV Talk 7 Nov 26, 2009 11:25 AM
Discussion Hitec Aurora 9 Manual now available. MikeMayberry Radios 31 Oct 08, 2009 06:07 PM
Discussion Hitec Aurora 9 Trainer Link jedorme Hitec/Multiplex USA 1 Aug 24, 2009 10:36 PM
