Old Jan 17, 2010, 03:19 PM
He who flies looks to the skys
mattyfly4fun's Avatar
Toronto
Joined Dec 2009
Quick build Slow Stick
I want a slow stick to fly in my back yard, well not quite my back yard as the local school own whats beyond my fence. See the pics.
Its just not big enough to Razz a WildHawk or HawkSky about, Half a soccer field and a play area, so a slow stick is required. The yard is all lit up at night too, so i would like to step into my back garden/school and just fly while drinking my morning coffe and eating my toast....LOL....
I have come up with a quick design, and put pencil to paper, main thing is its got to be super easy to build and fly. It will be a 3 channel plane, may adapt it to 4 channel if it flies.
Ive posted a pic of the planes ruff plan and yard i wish to fly in, i will do some video on the build and post when done. Hopefully it will make my friday youtube video slot.
http://www.youtube.com/mattyfly4fun
mattyfly4fun is offline Find More Posts by mattyfly4fun
Old Jan 17, 2010, 06:04 PM
Toronto
Joined Dec 2009
Parts
Got some parts together:
Well got some electronic bits together anyhow:
Tower pro motor
25 amp Esc
9x4.7 Prop
9 gramme servos x 2
My trusty 72mhz E-Sky RX (will use the Dynam Hawksky TX box)
A plastic motor mount. (Just lazy) I did mean quick build....
Just need a stick and a bit of depron.
Old Jan 17, 2010, 06:11 PM
Wake up, feel pulse, be happy!
C₄H₁₀'s Avatar
Joined Aug 2009
Looks cool. What's the wingspan?
C₄H₁₀ is offline Find More Posts by C₄H₁₀
Old Jan 17, 2010, 06:36 PM
Toronto
Joined Dec 2009
I dont know yet, i intend having the sheet of depron dictate the span. Should be near to 40" as the whole thing is based around the Wildhawk's dimensions.
Theres always, the if it looks ok it will do.
The idea is a quick throw together plane. With plenty of room for error and very few parts. So when i break it i can build a new one fast.
Old Jan 17, 2010, 08:47 PM
Toronto
Joined Dec 2009
1 hour 1/2 done
1 hour into the build.
Got the fuse finished.
Bought a stick from Home Depot, cut to size drilled and fitted the 2 dowel pins for the wing bands.
Cut a rudder and elevator out of 6mm Depron, used hinge tape and Hot Glued in position.
Fitted the motor propsaver and ESC up front.
Cut some 1/4 inch foam and made a place to stick the wings.
Should take bout an hour to finish, cut the wings and fit servos. Then its done. May get some wheels but not sure, will see what the LHS has got.
Old Jan 22, 2010, 08:15 PM
Toronto
Joined Dec 2009
The finished item
Here is the video of me putting together my first slowstick.
We used a Hobbyking motor combo with A RCtimer ESC, and a 9x4.7 prop.
2x9 gram servos,
A stick, of course.
A sheet of 6mm Depron & 3mm doweling,
2 control rods & 2 horns (beep, beep),
Hot glue,
1000 Mah 3 cell 20c battery,
A bit of 1/4 inch foam for the wing to sit on,
And some sticky tape + 2 1/2 hours hard work....LOL ,
But will it fly, we will see...
Slow stick, quick build (5 min 28 sec)
Old Jan 29, 2010, 01:30 PM
Toronto
Joined Dec 2009
Maiden..good and bad day
The first and last time we took the Scratch built slow stick out to play that you saw us building in last weeks video, Matty had one more flight, got stuck up a tree and had to use a hammer to get it out.
Maybe a little to much flex in the wings on this one, but overall it flew great, better than we expected, and stayed within the area we wanted to fly.
Looking forward for the Mk 2 to exit the workshop, this will have stiffer wings and a better paint job.
Slow stick maiden flight & crash (3 min 9 sec)
Old Feb 05, 2010, 11:38 PM
Toronto
Joined Dec 2009
My MK2 slowstick
We tweaked the first slow stick, used 7mm depron and shortened the wings, added some red paint, and now this plane is my favorite.
I have since flown this plane 15+ times without a problem. It loops, sorta rolls, stall turns and can carry my little cam. (just don't let Matty fly it Ha Ha)
The video gets blurrier at times but it is the first flight so it got to stay in.
Slowstick MK2 Maiden flight (3 min 18 sec)
Old Feb 06, 2010, 11:39 AM
JohnsPop's Avatar
LaGrange, GA
Joined Jun 2009
Nice video! Looks like a great little plane there.
JohnsPop is offline Find More Posts by JohnsPop
Old Feb 06, 2010, 08:07 PM
Pesty351's Avatar
Tyndall AFB FL
Joined Oct 2009
I love the Mk1 floppy wings.
Pesty351 is offline Find More Posts by Pesty351
Old Feb 12, 2013, 01:02 PM
Pakistan, Punjab, Rahim Yar Khan
Joined Apr 2011
I Just saw this and would like to build one
I Just saw this thread and would like to build one. ( I am sure I am not the only one)
Would you please provide details of the mods from MK1 to Mk2 and how you stiffened the wing?
I would apreciate if yo would do a sketch with dimensions for MK2.
Tariq
tariqsaeed is offline Find More Posts by tariqsaeed
Old Feb 12, 2013, 02:30 PM
anything rc
United States, IL, Waukegan
Joined Sep 2012
try building a wing like the old fogey. it is simple to build and does not need a spar or stiffener.the first link is the plane the second is the build video
http://www.flitetest.com/articles/FT_Old_Fogey
http://www.flitetest.com/articles/FT..._Scratch_Build
microairman1 is offline Find More Posts by microairman1
Old Feb 14, 2013, 01:16 PM
Joined Apr 2011
Thankyou microairman1 for the suggestion. I have the old fogy plan but I wonder if an old fogey wing would work fot this design. Would you recomment I make this plane's fuse fit the olg fogey wing or other way around?
Old Feb 14, 2013, 09:08 PM
Joined Aug 2009
tariqsaeed - I believe what microairman1 is referring to is the type of construction of the Fogey wing, not the overall shape of the wing. The airfoil made from two bits of foam angled together, rather than a flat plate. There is no need to modify your fuse. Build a new Slow Stick shaped wing with the Fogey airfoil and put some foam in the middle of the new wing so it has a flat area to mate with your existing fuselage.
FWIW I had a GWS Slow Stick for a while and it was not at all "Slow." To really go slow you need a big elevator that can push the plane into high alpha flight and let it hang off the prop. Look at how big the control surfaces are on 3D planes. Those things can creep on by like they're barely moving, or hover like a helicopter. I went to 3D from the GWS Slow Stick and it was a much easier and better flying experience.
Jack the R is offline Find More Posts by Jack the R
Old Feb 17, 2013, 11:12 PM
anything rc
Joined Sep 2012
yeah what jack is what i was meaning just take the wing chord and go a 1/3 of way back for the LE and do the bend there. should work really well.
Discussion Will this Slow Stick build "work"? chapped Beginner Training Area (Aircraft-Electric) 36 Mar 08, 2010 06:29 PM
Discussion Nice Slow Stick Brushless Upgrade cn0rris Beginner Training Area (Aircraft-Electric) 10 Jan 20, 2010 10:11 PM
Discussion Help me with a brushless Slow Stick build chapped Beginner Training Area (Aircraft-Electric) 10 Jan 13, 2010 11:27 AM
Discussion Help a newbie build a Slow Stick ?? LouBoxer Beginner Training Area (Aircraft-Electric) 7 Nov 27, 2009 06:10 PM
Quick Stick (AKA Slow Stick) Mac8 Parkflyers 17 Jul 20, 2004 02:04 AM
