Old Jan 17, 2010, 10:30 AM
jumpy is offline
Find More Posts by jumpy
smithy
jumpy's Avatar
Cornwall, UK
Joined Dec 2004
Question
SU25 Frogfoot
Hi all, im close to sending off drawings iv'e done for a SU25 to be cut into parts. Its 66inch span 63inch long with a wing area of 485 sqin. Im hoping for an all up weight of about 80oz. Originally it was designed for 2 90mm fans but i think these would take me over my ideal weight limit. I am now thinking of adjusting the drawings to use 2 69mm fans instead, thinking i could save about 900g (fan units, motors and LiPo's). Do you think 2 69mm fans will be upto this size model? Another question, keeping to this scale and using 69mm fans would mean that my intake area would be more than the fan fsa, how would this affect performance?
Any help much appreciated.
Phil
jumpy is offline Find More Posts by jumpy
Old Jan 17, 2010, 06:31 PM
hklagges is online now
Find More Posts by hklagges
hklagges's Avatar
Munich
Joined Dec 2008
Phil
Just to give you a data point for a 70mm power system:
- 2 Wemotec MiniFan Pro plus 2 HET2W25 plus 2 Roxxy ESCs plus long 4mm2 power cable all together weigh 530grams
- a 6s battery ok for that (eg Turnigy 30C 3.600mAh) weighs 580grams.
- they pull close 900 Watts each (40+ Amps each)
- thrust should be >= 2.4 kgs
Cheers,
Henrik
hklagges is online now Find More Posts by hklagges
Old Jan 17, 2010, 06:59 PM
LuvEvolution7 is offline
Find More Posts by LuvEvolution7
LuvEvolution7's Avatar
St.Catharines, Ontario
Joined Jan 2009
Phil............... nice plane to choose. I'll be following this one for sure. how about going the route I'm taking with the Jaguar and think about the WM400 MKII? great little fans, so I've read.
Rich
LuvEvolution7 is offline Find More Posts by LuvEvolution7
Old Jan 17, 2010, 11:53 PM
lavochkin is offline
Find More Posts by lavochkin
lavochkin's Avatar
Mokena,Illinois -United States
Joined Oct 2006
Well its very easy to achieve over 2 KW. in a 70mm sized fan. So say two 70mm fans at 2kw each for a total of 4kw combined. Is that enough? I would think so. I personally would stay with the twin 90's, even if you had to upscale your drawings to make work. 90's are a great cost effective sized fan vs. a 120mm size. Most who already fly 70mm fans have the lipos to run 90's and the size of the model is at a sweet spot. Bigger than a 70mm machine, but not quite as large as a 120+mm machine. Although your dimensions are around a 120mm sized jet. I think twin Tamjets 90mm 7 stator fans would be friggin killer in this jet. The frogfoot is russia's answer to our A-10. Very sweet and almost never modeled jet. I will for sure watch this thread. Great choice and I wish you the best of luck with the build!
lavochkin is offline Find More Posts by lavochkin
Old Jan 18, 2010, 04:32 AM
jumpy is offline
smithy
jumpy's Avatar
Cornwall, UK
Joined Dec 2004
Food for thaught indeed, thanks guys. The drawings are already designed for 2 Midi's and thay are a tight fit. Just thinking that if i redesign for 2 Mini's, which i already have btw, keeping it at the same size would mean that i would save weight, the tail pipe would be closer to scale and also the smaller ducting would mean i would have more room for retracts. The inlet area would be larger than fan fsa which i think would limit speed but im not looking for an all out speed 'demon'. O well, back to the drawing board
phil
Old Jan 18, 2010, 04:44 AM
monkamarm2000 is offline
Find More Posts by monkamarm2000
smug in granny panties
monkamarm2000's Avatar
NorCal Silicon Valley
Joined Aug 2002
sounds like a fun build! Frog is ne of my faves! and size wise sounds perfect for twin 70 or single 90. i biult a KP-44 version eons ago! thing to keep on the horizon is that the frogfoot can have a thrust issue like F-4's and Jags if you don't have enough length on tail pipe to hug the floor and even go up a tad on exit. Like F-4's if you have a hangin back fan or short tail pipe that aims down you'll have a plane that acts nose eavy on take off and tail heavy on throttle off.
Barry
monkamarm2000 is offline Find More Posts by monkamarm2000
Old Jan 18, 2010, 04:49 AM
Pinecone is offline
Find More Posts by Pinecone
Will fly for food
Maryland
Joined Sep 2004
I will keep an eye on this thread, no matter what size fans you figure on.
Would love to add a Frogfoot to the collection.
And the real thing was not a speed demon, high subsonic only.
I got to fly one in the Ukraine and was limited to 800 KPH.
Pinecone is offline Find More Posts by Pinecone
Old Jan 20, 2010, 03:23 AM
jumpy is offline
smithy
jumpy's Avatar
Cornwall, UK
Joined Dec 2004
Well here is were im at. Just finished redesigning for minifan setup. There is a lot more space now which allowed for much more straight through ducting, before there was quite a curve from inlet to fan inlet and also the exhaust was exiting at a slight downward and sideways angle. Now i have a 0degree outlet and straight inlet. Still got a few more bits to do but nearly ready to send of to be cut. Here's a screenshot of what i have so far.
Phil
Old Jan 20, 2010, 03:39 AM
Rainer is offline
Find More Posts by Rainer
Switzerland
Some time ago i've also drawn a Su-25, it was thought for 2 MiniFan but a bit smaller than yours.
Unfortunately i never finished this project.
Rainer is offline Find More Posts by Rainer
Old Jan 20, 2010, 06:17 AM
jumpy is offline
smithy
jumpy's Avatar
Cornwall, UK
Joined Dec 2004
Does anybody know how the mains gear retracts, ive been trawling through videos on youtube but cant quite make out how they retract. I know they retract forward but cant see if they also rotate through 90 degrees to lay flat in the wheel well similar to a Jaguar. My guess is they probably do to minimise space for ducting.
Phil
Old Jan 20, 2010, 07:20 PM
Joined Jan 2009
Frogfoot gear pics
hey Phil
I've looked at a bunch of pics on airliners.net for you and these are the best I can find. there are literally hundreds to look at on there if you are interested.......cockpit shots, paint schemes and all kinds of other things. here's a few of the gear and few cool schemes I found. there's deffinitely a twist exactly like the Jag as it retracts forward. you'll need a 90 degree rotating set, or make your own hinge point as I did with the Jag.
Old Jan 20, 2010, 07:23 PM
Joined Jan 2009
here's a few more
a few more gear pics and a really cool paint scheme.
Old Jan 21, 2010, 01:13 AM
jumpy is offline
smithy
jumpy's Avatar
Cornwall, UK
Joined Dec 2004
Hey Rich, thanks for the pics, very helpful. I've also noticed that the main gear is quite short, if i keep it to scale i could have problems with ground interference taking off from grass, but on the plus side there's less room needed in the wheel well. Great colour schemes, i think my fav is the last one from the Czech airforce, no chance of loosing site of that in the air!
Phil
Old Jan 21, 2010, 02:42 AM
Joined Jan 2009
yeah, I agree totally. LOL. it's pretty loud and I kinda like the frog on the tail fin. you may run into FOD trouble, as you say. could you not put a screen somehwere in the intake, with a trap door system, so that if something hits the screen, the door opens and throws out the heavy object? they use FOD screens on turbines and it doesn't seem to affect performance too much. how well would they adapt to EDF use, I wonder? just a thought.
Rich
Old Feb 14, 2010, 02:39 PM
jumpy is offline
smithy
jumpy's Avatar
Cornwall, UK
Joined Dec 2004
Well i think i have finished the drawings, been going over them again and again to check for anything i have missed, can never be too carefull i suppose. First thing tomorrow sending the parts drawing off to be cut.
Question Su-25 Frogfoot.... got any plans? birdlives1955 Foamies (Scratchbuilt) 7 Feb 28, 2011 07:28 AM
su-25 frogfoot Robbie d Electric Ducted Fan Jet Talk 7 Dec 03, 2009 10:02 AM
Sukhoi 39 Frogfoot Neil Straker Pusher Prop Jet Models 108 Sep 14, 2005 10:15 PM
Frog legs?? naw I'll have a Frogfoot Dragon Soaring Slope 18 May 15, 2005 01:34 PM
EDF50 SU25 Frogfoot jah Electric Ducted Fan Jet Talk 46 Mar 26, 2002 06:11 PM
