Old Jan 16, 2010, 10:00 PM
carlsoti is online now
Find More Posts by carlsoti
hass-alfed and bass-ackwards
carlsoti's Avatar
United States, AZ, Chandler
Joined Jun 2008
Does this look like some sort of Blue Wonder all dressed up?
In a recent build thread, a member used this motor to power a Discus Launched Glider. It's the HCS Compact 380 motor listed on this page:
http://www.icare-rc.com/specialty-brushless.htm#compact
His pictures of the motor are here:
http://www.rcgroups.com/forums/showp...75&postcount=1
To me, this looks like one of the 24g motors like a Blue wonder, with a folding prop spinner mashed on the front, and a little "trim plate" on the back.
What do you guys think?
If so, I'm considering doing a home-made deal with one of the newer turnigy R&B Wonders for a similar plane that was given to me.
carlsoti is online now Find More Posts by carlsoti
Old Jan 17, 2010, 04:59 AM
Dylwad is offline
Find More Posts by Dylwad
Dylwad's Avatar
Phoenix,Arizona, United States
Joined Jun 2002
You can't tell without comparing lamination shape, thickness, material and coating, and comparing magnet size, shape, rating and flux ring thickness/material. Not to mention copper fill/temp rating.
Looks totally unique to me. Molding that spinner isnt a cheap process, much cheaper to do a small run of CNC milled aluminum parts than to make a mold for plastic.
Dylwad is offline Find More Posts by Dylwad
Old Jan 17, 2010, 12:54 PM
carlsoti's Avatar
Joined Jun 2008
I've done some prototype machine work in the past, so I'm aware of the costs involved. I wasn't even considering going to that extreme(of doing CNC work), though. I was just going to try to find a spinner that would "press-fit" over a turnigy B&RW can. Dial it in with a indicator to make sure it runs true, then CA or epoxy the spinner to the can. The plane I'm thinking of flying will have an AUW of no more than 16oz. or so. A nicely rewound motor would give better than 1-to-1 thrust to weight, and I could run it on a 1000-1300 mAh 3S lipo.
I'm pretty much just thinking out loud here. If I do it, I'll post relavant motor info for all to see.
Question Does this look right? sbeirs Power Systems 5 Jan 18, 2010 03:06 AM
Discussion What does a 64mm EDO fan look like? zach_dad Electric Ducted Fan Jet Talk 11 Jan 10, 2010 02:14 AM
What does 1860 ft look like?...like this TaylorMech Aerial Photography 6 Apr 26, 2005 09:07 PM
Attn Smart owners : does your Smart look like this? freq Electric Sailplanes 12 May 22, 2003 01:35 PM
Does this look like a good starter pylon racer? Acer High Performance 11 Oct 17, 2001 05:47 PM
