Old Jan 16, 2010, 07:52 PM
heliav8r is offline
Find More Posts by heliav8r
Fly like nobody's watching!
heliav8r's Avatar
USA, IL, Tinley Park
Joined Dec 2009
Question
Easy star prop and adapter for new brushless motor
OK, I got a B2835-2200 brushless inrunner (from Hobbycity) to replace the stock motor and bought a prop adapter to fit the 3.2mm shaft...(the kind with the hex nut). Except that the motor will spin the nut off when power is applied. I am confused....
Looking at the motor, from the tail, the motor should spin clockwise to get the correct wind direction.
I guess what I am asking is..
What prop adapters is everyone using and what props?
Also, where to get them.
Joe
Sorry, I know this has been covered, but in reading some of the posts it gets more confusing......
heliav8r is offline Find More Posts by heliav8r
Old Jan 16, 2010, 09:00 PM
outngo is offline
Find More Posts by outngo
E-Gliders
outngo's Avatar
South Carolina
Joined May 2009
Motor spins something off??? Any pics?
outngo is offline Find More Posts by outngo
Old Jan 16, 2010, 09:02 PM
Xpress.. is offline
Find More Posts by Xpress..
Team Hitec, Customer Support
Xpress..'s Avatar
United States, CA, Poway
Joined Oct 2007
AND make sure the prop nut is TIGHT
BTW, the motor should spin counter clockwise when looking from the front, towards the tail.
Xpress.. is offline Find More Posts by Xpress..
Old Jan 16, 2010, 09:25 PM
heliav8r is offline
heliav8r's Avatar
Joined Dec 2009
I have the prop adapter tightened to the shaft with the two grub screws and I have tightened the hex nut to the prop.... but.... It seems to me that if the nut was to come loose....somehow... it would spin off. Shouldn't there be a left hand thread on the prop adapter so that technically it would always be tightening?
e.g. motor spinning clockwise, left hand thread would be working against the prop.
right?
Old Jan 16, 2010, 09:27 PM
heliav8r is offline
heliav8r's Avatar
Joined Dec 2009
Am I just over thinking this? If you tighten the prop down with the hex nut, is that sufficient to keep it in place despite vibrations...etc?
Old Jan 16, 2010, 09:36 PM
Jeremy Z is offline
Find More Posts by Jeremy Z
Senior User
Jeremy Z's Avatar
Northern IL
Joined Oct 2005
It is the tendency of a pusher to loosen the nut. It turns clockwise, looking from the rear, so that would tend to loose the prop nut. I've never had a problem, but if you are, just use blue thread locker lon it.
I've got an EZ* and I'm about to put the 2700 kv version of the same motor in it.
Remember that with most props, that would tend to tighten them, so it is smart that they're that way.
Unless you've had something fly off, I do think you're overthinking it.
Where in Chicagoland are you, by the way?
Jeremy Z is offline Find More Posts by Jeremy Z
Old Jan 16, 2010, 09:42 PM
heliav8r is offline
heliav8r's Avatar
Joined Dec 2009
Jeremy,
Thanks. I guess I was just erring to the careful side!
Thanks for your suggestions.
Yes, I live just South of Chicago. (Tinley Park) about 50 miles from RLB (I think).
Joe
Old Jan 17, 2010, 03:00 PM
Rickochet is offline
Find More Posts by Rickochet
Card Carrying Old Fart
Rickochet's Avatar
Central Kentucky
Joined Oct 2006
I use a collet type prop adapter. I get mine from HeadsupRC. $2 flat rate shipping for any size order. Shipping is super quick also.
http://www.headsuprc.com/servlet/the...-3.17mm/Detail
Rickochet is offline Find More Posts by Rickochet
Old Jan 17, 2010, 04:32 PM
heliav8r is offline
heliav8r's Avatar
Joined Dec 2009
Great!
What props do you guys use? 6x5.5, 6x4?? APC? Master airscrew? Generic?
Old Jan 17, 2010, 05:33 PM
outngo is offline
E-Gliders
outngo's Avatar
South Carolina
Joined May 2009
Originally Posted by heliav8r View Post
Great!
with your motor B2835-2200 either of those will work great.
Old Jan 17, 2010, 08:28 PM
Jeremy Z is offline
Senior User
Jeremy Z's Avatar
Northern IL
Joined Oct 2005
I have the 2700 kv version of the same motor in my EZ*, running on 2S LiPo, and the APC 6 x 5.5 E prop yields 21.5 A, 170 W static. It is within limits, but you didn't say what battery pack you're using. If you're running 2S LiPo, a 6 x 5.5 E is about right. If you're running 3S LiPo, start with 6 x 4E and see where you are, current wise.
Here's a good calculator to help you decide where to start.
http://brantuas.com/ezcalc/dma1.asp
You won't find Turnigy motors in there, but you can usually find something similar enough to give you a good estimate.
Old Jan 18, 2010, 06:23 PM
heliav8r is offline
heliav8r's Avatar
Joined Dec 2009
I am using a 3s 2200 lipo. So I guess a 6x4E is the way to go with the 2200kv?
Old Jan 18, 2010, 08:54 PM
Jeremy Z is offline
Senior User
Jeremy Z's Avatar
Northern IL
Joined Oct 2005
That sounds about right. It will still be faster than mine, so be careful. I just maidened mine today, and it climes really fast at full throttle, but is nice for just cruising around at 1/2 throttle.
Old Jan 19, 2010, 12:07 AM
Jurgen Heilig is offline
Find More Posts by Jurgen Heilig
Jurgen Heilig's Avatar
53859 Niederkassel, Germany
Joined Sep 2000
The SeaBee from Robbe (Pusher) comes with a 3.17mm prop adapter which tightens counter-clockwise.
Jürgen
Jurgen Heilig is offline Find More Posts by Jurgen Heilig
Old Jan 21, 2010, 01:19 PM
skyhawk1 is offline
Find More Posts by skyhawk1
United States, OH, Corning
Joined Nov 2004
I use a standard Master AirScrew 6 x4 prop. The prop is put on the shaft backwards. I just use a cheap collet type prop adapter. I run 3 cells on a Mega 16/15/4 and after many a flight have never had the nut come loose. Great performance.
I assume that you are using a washer between the prop and the nut. If not that could be your problem.
Good luck.
Todd
skyhawk1 is offline Find More Posts by skyhawk1
Sold Multiplex Easy Star w/ BL Motor and Servos ($60.00) VasMan Aircraft - Electric - Airplanes (FS/W) 4 Jan 12, 2010 07:56 PM
For Sale EASY STAR CLONE-WILD HAWK with Brushless AVEOX MTR LIKE NEW mechengineer03 Aircraft - Electric - Airplanes (FS/W) 7 Dec 25, 2009 12:08 AM
Sold New Feigao 1208436L 12x30mm Brushless Motor with prop adapter and GWS EP-4530 prop JohnM Aircraft - Electric - Power Systems (FS/W) 1 Jan 26, 2008 10:17 AM
Question Easy Star Brushless Motor/Prop flyer_2 FPV Talk 14 Jan 25, 2008 11:53 PM
For Sale New Easy Star Speed 400 motor with prop. $12.00 himeros Aircraft - Electric - Power Systems (FS/W) 0 Jul 16, 2006 10:53 PM
