Old Jan 16, 2010, 06:14 PM
trappy is offline
Find More Posts by trappy
trappy's Avatar
Austria
Joined Feb 2007
Build Log
The ultimate FPV glider
Today I started the build on my FPV Supra. For those of you that don't know the plane, check out the website of Kennedy Composites or watch the movie I made of the non-FPV version
http://www.kennedycomposites.com/suprae.htm
Supra Re-Maiden (3 min 51 sec)
For me this is the ultimate FPV glider, even the ultimate FPV aircraft. It's hollow-molded full glass with carbon fiber reinforcements. The Supra travels at around 40mph, but it can be slowed down to ~10mph for landingings. The top speed should be near 130mph. The glide ratio is out of this world (~1:40), the plane can fly forever and then some on a very small LiPo pack. With the power system I have on board, it will climb at 17 meters per second (~3300 feet per minute). It will be built from the ground up for FPV.
This build includes a couple of "advanced" stuff such as frequency diversity (2.4GHz & 1.3GHz), how to use FPV gear with a 5S battery and how to install FPV gear properly for long range (noise-free) and low drag. I'll also re-build my ground-station and post pics here. There will also be some non-FPV stuff going on ranging from R/C TX programming to build tips for composite models.
I hope we can get a good discussion going because at the end of this build-log I will release a PDF with the contents of this thread in a more structured manner.
Anyways, I got started today ... nothing FPV related yet, just some normal build steps ... here's the pictures:
trappy is offline Find More Posts by trappy
Old Jan 16, 2010, 06:59 PM
jsullivan05 is offline
Find More Posts by jsullivan05
jsullivan05's Avatar
Near Saint Louis MO. (IL Side)
Joined Aug 2009
$1500 for the plane... HO-LY CRAP, on another note, the thing looks EFFING SICK!... and looks like you get to break the 4 hour flight mark i bet...
jsullivan05 is offline Find More Posts by jsullivan05
Old Jan 16, 2010, 07:06 PM
David22 is offline
Find More Posts by David22
North vancouver, B.C. Canada
Joined Apr 2008
Nice plane.
Cool thread
any reason you don't drill 4 more holes in the firewall to allow the air intake from the spinner to enter the fuse?
David22 is offline Find More Posts by David22
Reply With Quote  (Disabled)
Old Jan 16, 2010, 07:13 PM
Daemon is offline
Find More Posts by Daemon
Daemon's Avatar
Lakewood, Colorado
Joined Aug 2002
I'd be worried that that carbon wing is going to completely shadow the 1.3Ghz video antenna.
Even if you stick it out the bottom, there's going to be bank angles that block it.
ian
Daemon is offline Find More Posts by Daemon
Old Jan 16, 2010, 07:28 PM
trappy is offline
trappy's Avatar
Austria
Joined Feb 2007
David, there are holes in the fuselage, and the motor is cooled internally with a fan.
Ian, there is only a carbon spar in the wing. it will block the video at certain times, that's why I have 2 transmitters.
Old Jan 16, 2010, 08:07 PM
man2000me is offline
Find More Posts by man2000me
Mums the word.
man2000me's Avatar
St.Augustine, FL
Joined Sep 2009
I'm excited. Maybe once I sell my house I will follow in your foot steps. Awesome work.
man2000me is offline Find More Posts by man2000me
Old Jan 16, 2010, 08:14 PM
David22 is offline
Joined Apr 2008
very cool
good job
absolutely beautiful plane you have there
Old Jan 16, 2010, 09:36 PM
aviatordave is offline
Find More Posts by aviatordave
I AP'd myself again......
aviatordave's Avatar
Yawn....Iowa
Joined Mar 2005
Cool project.
This explains why you were selling your other stuff.
Is that duct tape I see on the ESC?
aviatordave is offline Find More Posts by aviatordave
Old Jan 16, 2010, 11:03 PM
Blue Sky is offline
Find More Posts by Blue Sky
It just keeps getting better!
Blue Sky's Avatar
Eureka, CA
Joined Oct 2002
Quite the dream machine!
Are you planning on using one camera and two TX's?
Any ideas yet on mounting your (camera)'s?
Blue Sky is offline Find More Posts by Blue Sky
Old Jan 16, 2010, 11:49 PM
kason is offline
Find More Posts by kason
kason's Avatar
Taiwan
Joined Aug 2009
that's really an ultimate glide ratio rate there. 1:40
tihs can travel really far!
kason is offline Find More Posts by kason
Old Jan 17, 2010, 05:33 AM
QUIKSILVER is offline
Find More Posts by QUIKSILVER
QUIKSILVER's Avatar
UK
Joined Sep 2002
V2 Supra - Just Wet My Pants Again Trappy, Keep It Up
QUIKSILVER is offline Find More Posts by QUIKSILVER
Old Jan 17, 2010, 06:07 AM
CrazyG is offline
Find More Posts by CrazyG
Israel
Joined Aug 2008
Amazing Trappy.
Good luck breaking the 4 hour barrier!
CrazyG is offline Find More Posts by CrazyG
Old Jan 17, 2010, 06:08 AM
trappy is offline
trappy's Avatar
Austria
Joined Feb 2007
BlueSky: Yes, it will be 1 camera and 2 VTx. The 2 VTx will take care of the problem arising with the carbon parts and to guarantee a good video connection even when banking the plane heavily (polarization diversity). I'm back to square one on the camera mount. Initially I planned to mount the pan servo in the fuse and have only the servo-head stick out, but that's not going to work (not enough room). My best choice so far is to glue everything on top the wing.
jsullivan/guyavitov: the 4hour mark will depend on whether I can squeeze enough battery in there. the second vtx will probably need to be turned off for a 4h flight, as I'll be flying with a 5S 2200mAh (that's all that fits).
aviatordave: No, there's no duct tape on the ESC. The whole ESC is shipped in a lightweight aluminum case (I think it's aluminum) for cooling and noise filtering. This really is the best ESC I've ever seen ... there's so much thought put into this (switching BEC with redundant outputs, for example!) ... but it comes at a price
http://www.kontronik.com/index.php?o...emid=1&lang=en
The tape you see wrapped around right now is just to keep the wires out of my way while I work on the fuse.
Old Jan 17, 2010, 06:26 AM
ommadawn is offline
Find More Posts by ommadawn
The Flying Circus
ommadawn's Avatar
Adelaide South Australia
Joined Sep 2007
Seems a shame to upset that beautiful streamlined shape with a clunky camera hanging out in the breeze.
How about a redesigned clear bubble canopy for the camera?
ommadawn is offline Find More Posts by ommadawn
Old Jan 17, 2010, 06:54 AM
trappy is offline
trappy's Avatar
Austria
Joined Feb 2007
there's absolutely no space inside, I need to put the camera outside in any case. I might add a canopy, but maybe I'll just streamline the camera itself a little.
Build Log Easy Fly Glider ST330 (Easy Glider Clone) FPV Build Thread SoMoney FPV Talk 493 Nov 12, 2012 03:08 PM
Poll Ultimate light air glider? Woodstock 1 Hand Launch 23 Jan 23, 2010 07:24 PM
Discussion FPV Easy Glider 1 - 1 Bird Cralis FPV Talk 28 Jan 10, 2010 02:10 PM
Discussion Ultimate light air glider? Woodstock 1 Slope 14 Jan 04, 2010 04:36 AM
Discussion Ultimate light air glider? Woodstock 1 Multi Task F3X 3 Jan 02, 2010 02:17 PM
