Old Feb 25, 2010, 05:08 AM
RobertWing is offline
Find More Posts by RobertWing
Joined Oct 2009
Originally Posted by phil_g View Post
Jonathan/Chase, I've been studying the protocol document, please could you confirm if the 4800bps RS232 channel has to be framed using the "10 byte plus header" protocol?
I'm not sure because parts of the dicumentation imply that it is a free flowing, no protocol, continuous serial stream... but other parts imply that it must be framed. If framing is necessary then I have some conversions to do.
Many thanks
Phil
The serial port of the receiver(also called REMOTE), it is "NOT" 10 bytes framed, just pure data. it is RS232 level, inverted TTL signal would be ok.
But at the port of the transimitter(called HOST), it is 10-bytes framed. My understanding is that introduction of the 10-bytes-frame would facilitate to decode both user bytes and the in-built telemetry bytes.
RobertWing is offline Find More Posts by RobertWing
Old Feb 25, 2010, 05:26 AM
phil_g is offline
Find More Posts by phil_g
Who let the dogs out?
phil_g's Avatar
Pontefract, Yorkshire, UK
Joined Jul 2007
Thankyou Robert
So the framing is done within the return link, ok. Is there any buffering at the remote, or do we need to pause the RS232 stream every 10 bytes at the RX232 pin? And at the host end I will need some simple processing to separate out the telemetry channels and the user channel, based on the headers... is that correct?
Thank you
Phil
phil_g is offline Find More Posts by phil_g
PLMS is offline
Find More Posts by PLMS
Martin - AKA mr.sneezy
PLMS's Avatar
Joined May 2004
Two more small observations
Three actually...
One. The TX module uses a switching regulator to drop the battery voltage from the radio (the actual RC transmitter) down to 3.3V, not an inefficient and heat producing linear regulator. Battery life of the RC TX should be very good.
Two. The TX module has a MAX232 chip buffering the serial I/O. Nice, better than raw out of the micro.
Three. The transceiver PCB is virtually identical to the one used in the Corona units (a third party module). It looks so close I'd expect I could unplug one from a Corona module and fire it up on this one. Might do that once I've run out of other uses for it in case it smokes :-P
I guess the first step is hook the TX serial output to a PC terminal app like Hyperterm and see what is really spewing out of it.
Could be a few days before I get there. (Harder since I left the documents at work)
If anyones done that could they post a screen dump ?
PLMS is offline Find More Posts by PLMS
Old Feb 25, 2010, 05:51 AM
renatoa is offline
Find More Posts by renatoa
Romania, Dolj, Craiova
Joined Sep 2007
Originally Posted by PLMS View Post
...Maybe Mr Chase Wu would be kind enough to post the PDF here as attachments for us all. The more people see the info the faster we can get some hardware built.
I'll second this, eagerly awaiting to jump on it
renatoa is offline Find More Posts by renatoa
Old Feb 25, 2010, 05:56 PM
Joined Oct 2009
Thankyou Robert
Thank you
Phil
There should be a buffer, because the remote can not sense when to stop.
and my guess is the same as yours, based on the headers, we can separate the telemetry channels and the user channel.
Old Feb 25, 2010, 05:58 PM
PLMS is offline
PLMS's Avatar
Joined May 2004
Small video
I took a quick and short video last night showing the two way system on the bench. Just an RC functional test, nothing too exciting yet, but it does show the test box I made a while ago for making module testing and range testing much easier for me.
If any of you guys can program PIC micros you can make yourself one. I can post a link to the details if anyone would like it.
Martin
FrSky Two Way 2.4Ghz system development kit first look (1 min 47 sec)
Old Feb 25, 2010, 08:30 PM
lazy-b is offline
Find More Posts by lazy-b
Manila, Philippines
Joined Jul 2004
Martin,
Thanks for posting the video.......its a Good Idea making that Sweeping Gadgets.........one advantage of getting the High End Transmitter such as JR 10X it has a Built-in Sweeping Servo under the Servo Monitor, Futaba 9CHP has one also.........Unfortunately, the Spektrum DX7 Do not have a Sweeping servo, but has a Servo Monitor only.
I guess, We are so eager to see it you Hook it up on a PC using a simple HyperTerminal to transmit and Received......You can use Hyperterminal to Capture all Received data, then all Captured Data can easily import to EXCEL Spread Sheets in CVS format, then use EXCEL to create all kinds for Bar Graph charts
Ellion
lazy-b is offline Find More Posts by lazy-b
Old Feb 25, 2010, 08:53 PM
JMP_blackfoot is offline
Find More Posts by JMP_blackfoot
JMP_blackfoot's Avatar
United States, OH, Galena
Joined Jul 2003
[QUOTE=PLMS;14447682]If any of you guys can program PIC micros you can make yourself one. I can post a link to the details if anyone would like it.
Martin[QUOTE]
Martin, I can program PIC micros and I am interested. Thanks.
JMP_blackfoot is offline Find More Posts by JMP_blackfoot
Old Feb 25, 2010, 10:30 PM
PLMS is offline
PLMS's Avatar
Joined May 2004
Protocol PDF and discussion thread
Guy's,
This thread seems like it's best left as a very general FrSky discussion...
So I thought it was a good time to branch out to a new thread for pure discussion of the nuts and bolts of the telemetry protocol.
Both FrSky documents I was sent are there in PDF are there to download.
http://www.rcgroups.com/forums/showt...php?p=14449925
Old Feb 25, 2010, 11:09 PM
PLMS is offline
PLMS's Avatar
Joined May 2004
[QUOTE=JMP_blackfoot;14449131][QUOTE=PLMS;14447682]If any of you guys can program PIC micros you can make yourself one. I can post a link to the details if anyone would like it.
Martin
Follow the link to my homepage about this project.
http://flying.model.airplanes.isgrea...generator.html
If you have questions about it please PM me or post it in a new thread and send me the thread ID. I don't want to hijack this thread.
I really hope it's self explanatory and I don't get questions :-)
Martin
Old Feb 25, 2010, 11:22 PM
PLMS is offline
PLMS's Avatar
Joined May 2004
I didn't know that. I use two very old but very sturdy Futaba 8U radios, and also a Hitec Flash4/5. I'd like a high end TX eventually for sure, but as I do a lot of slope soaring near the sea and they do get salty and sandy, it would not be good for it. One day...
Old Feb 25, 2010, 11:46 PM
renatoa is offline
Joined Sep 2007
Get a second T9C for $150-200 and you will not look back
Old Feb 28, 2010, 07:48 AM
sebbe is offline
Find More Posts by sebbe
"The Judge"
sebbe's Avatar
Sweden
Joined Feb 2006
Originally Posted by kneedrag View Post
First run we had the aerial point directly towards the rx. First 20m were jitter filled and we lost range at about 50m. That is the worst transmitter setup scenario. (for those that don't know pointing your aerial straight at a rx is not conducive to it getting signal)
Thats strange, I dont think any 2,4ghz receiver should get 20-50 meters range in worst scenario
I did get 400 meters with a little Corona dsss 4ch receiver poiting both TX and RX at each other and with my body in the way also..
I could not imagane getting 20-50 meters with any 2,4ghz receiver I have, even if i did remove TX antenna from module.
This was a bad result I think. Are you sure after 20 meters the servo started glitching ?
sebbe is offline Find More Posts by sebbe
Old Feb 28, 2010, 08:39 AM
renatoa is offline
Joined Sep 2007
Wow... bad indeed... Hitec demo indoor without any antenna at all !
Old Feb 28, 2010, 02:59 PM
kneedrag is offline
Find More Posts by kneedrag
Joined Apr 2007
Yip it supprised me as well. However that being said as soon as the tx areial was angled no issues.
I do want to do this test again as well as with a Spektrum tx and rx.
kneedrag is offline Find More Posts by kneedrag
Mini-Review The video for FrSky 2.4Ghz Chase Wu Radios 0 Dec 16, 2009 01:18 AM
Discussion Realflight G5 Combat so far so good! splitpilot Simulators 0 Nov 22, 2009 06:36 AM
Discussion So far... So good rikks Mini Helis 35 Feb 17, 2006 12:42 PM
Aerofly Deluxe so far so good! Gary Morris Simulators 5 Aug 19, 2005 07:23 AM
Schulze 18.46K v7.02 - so far, so good! Jason M Electric Heli Talk 4 Aug 11, 2002 01:25 AM
